Algo Duet-Plus 1825(p) not warbling repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Got one of these Algo Duet-Plus 1825(p) in for repair. Complaint: Not making any noise anymore.
    Yeah... and nope it wasn't the LM384N audio amp. The warbler IC is the MC34017A-1P. In short, if you press that test button a warble sound comes out that speaker. In my case I injected a tone with my tone generator on pins 2 and 3 on MC34017A and sure enough... sound was getting to pin 6 of the LM384N and amplified out to the speaker.
    Hmm... o.k. is the IC getting turned on pin 4 when I press the button? Yep. Is really that warbler IC bad? Sure enough... dead like a door nail.
    It's an interesting device. Weird enough for this section.
    • 31197
    Re: Algo Duet-Plus 1825(p) not warbling repair
    interesting chip,
    too bad most of the western world is going to switch to voip soon to save money (at their end, not ours)
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Talking about VOIP. My work place just switched over to VOIP. For my line of work, it's for the better, since I can take the phone where I need it. I just need an internet connection and that's it. Matter effect I tried it today using Starlink on a remote site and I had phone and internet, where previously only satellite phone worked. It really depends on the line of work.
      Other than that, price wise, the landlines were actually cheaper as work had a contract with the phone company. BUT: Now we need only 25% of all the phone lines we had before.
        • 31197
        i remember when you could use the fone if the power failed.
        even if you have a ups type of setup, how long will voip run? not days i'm sure
        with copper pair dialup all you need is a handset or linemans fone and access to the wires
        no extra power required.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          I remember those rotary phone days… I also remember making a little charger that plugs into the phone line and charges the batteries. I also remember other things that worked back in the 90’s. Kinda was fun. Or how about repairing modems and fax machines! Oh boy… I am getting old!
          • redwire
            • Dec 2010
            • 3912
            I once made a telephone ringer using I think AMI Gould S2561A.
            It was fun until the fancy IC croaked, something to do with the piezo capacitance holding too much charge and the IC output stage blew. After all that work it lasted maybe 10 rings
            https://datasheetspdf.com/pdf-file/5...uctor/S2561A/1
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              Hmm... interesting, that the S2561 failed the same way that this MC34017, just with an extra short life span. lol. Apparently this MC34017 sounded different (probably like a cat dying) before it died. When I got it, it was absolutely dead, no audio at all. I found some of these MC34017's at futurelec.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                To round it all up, I never got the order from futurelec. Reordered at Ali, put the new MC34017 and the unit is working once more. A fourty cent part… lol.
                • SluggerB
                  Help with trying to fix phone that is not charging (Pics inside)
                  by SluggerB
                  I have two TCL A30 phones.
                  Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                  New Phone: Works fine, bought as a donor board to try and repair Old Phone
                  My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                  08-12-2024, 08:11 AM
                • keeney123
                  new OS on a Sonim XP5s phone
                  by keeney123
                  To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                  I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                  05-13-2022, 07:19 PM
                • dokma
                  Linksys SPA942 VOIP phone, screen flashes briefly about every second
                  by dokma
                  My office VOIP phone Linksys SPA942 died a few minutes ago. The symptoms are as stated in the title:
                  - the screen flashes very shortly, goes blank about 1 second and repeats the same
                  - I can hear a clicking sound in the handset in the same pattern
                  I have measured the voltage on the adapter and it is as stated on the adapter: 5.2V. The adapter is labeled: INPUT: 100-240V~, 50-60Hz, 0.35A OUTPUT: 5.0V 2A.
                  I have opened the phone up and disconnected everything I could: handset, screen, speaker, case and the voltage all over the motherboard varies at the...
                  05-26-2020, 05:34 AM
                • redwire
                  Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                  by redwire
                  My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                  Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                  Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                  The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                  The tone caps are green film caps I left alone. Newer...
                  07-30-2023, 08:21 PM
                • mikey5791
                  Help with Samsung Galaxy J7 Prime phone
                  by mikey5791
                  Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                  Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                  Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                  Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                  If tested the...
                  09-15-2021, 07:54 PM
