Linksys SPA942 VOIP phone, screen flashes briefly about every second
  • dokma
    • Aug 2017
    • 39
    • Croatia
    My office VOIP phone Linksys SPA942 died a few minutes ago. The symptoms are as stated in the title:
    - the screen flashes very shortly, goes blank about 1 second and repeats the same
    - I can hear a clicking sound in the handset in the same pattern
    I have measured the voltage on the adapter and it is as stated on the adapter: 5.2V. The adapter is labeled: INPUT: 100-240V~, 50-60Hz, 0.35A OUTPUT: 5.0V 2A.
    I have opened the phone up and disconnected everything I could: handset, screen, speaker, case and the voltage all over the motherboard varies at the same rate as the screen flashes: from about 0.5V to about 1.9V. I cannot find 5V anywhere on the motherboard.
    Everything on the motherboard looks absolutely pristine under visual inspection.
    I don't have a replacement adapter to test if the adapter is failing under load.
    My guess is the obvious:
    #1 adapter is failing under load OR
    #2 motherboard is going into some sort of a boot loop.
    What would be the easiest way to figure out if it is actually the phone that is dead?
  • dokma
    • Aug 2017
    • 39
    • Croatia
    Re: Linksys SPA942 VOIP phone, screen flashes briefly about every second
    Truns out the adapter died. I've managed to fiddle the bench power supply probes into the connector and the phone booted.
    • SluggerB
      Help with trying to fix phone that is not charging (Pics inside)
      by SluggerB
      I have two TCL A30 phones.
      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
      New Phone: Works fine, bought as a donor board to try and repair Old Phone
      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
      08-12-2024, 08:11 AM
    • keeney123
      new OS on a Sonim XP5s phone
      by keeney123
      To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
      I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
      05-13-2022, 07:19 PM
      HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 430 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
      09-06-2024, 08:10 PM
      HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 450 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
