There are so many 'Help me identify this' threads we need a single stickeyed thread and TC has agreed
Post help identifying capacitors here
This is a sticky topic.
^If you have datasheets not listed PM meTags: None- Stuck
Re: Post help identifying capacitors here
Probably need to combine a lot of these others into one and FAQ it.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
I think just starting fresh would help and we can do the rest later. Actually I think there is so many it might be pointless to combine all those thousandsCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
It's stickied. Perhaps just link some of the many in here, so there's some reference material.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Or just a link that does a search on this forum for the word "identify"Cap Datasheet Depot: http://www.paullinebarger.net/DS/
ok let me start by contributing to this thread, the famous japanese website link that is used to identify many brands of polymer/solid capacitors: http://capacitor.web.fc2.com/solidcapacitor.html
and to the newbies reading this, just use google translate by copy-pasting to translate the japanese text on the webpage to understand what they are saying in japanese.Comment
Please could someone help me identify what the capacitance, voltage, tolerance and package of this cap is please?
Written on the cap's head:
470
jFK
6K3
Many thanks in advanceComment
Can anybody identify these "ELFL" ones? Found them bulged in a 15 years old office table motor controller with a blown bridge rectifier. Looking for a datasheet but couldn't find anything with "ELFL".Attached Filesif you find these attachements useful please consider making a small donation to the site
look for more writing like uf and voltageComment
Other than being from china, I can find no original company manufacturer. Like, noneCap Datasheet Depot: http://www.paullinebarger.net/DS/
The basic values are there, but no (known to me) manufacturer, no series name, no date code.
Me neither, found an old useless mfrbee.com entry pointing to China and nothing else. Ok, I think it is necessary to take a closer look at the circuit to find suitable replacement types. Will do that later in the power supply forum.
Thanks for commenting.Attached Filesif you find these attachements useful please consider making a small donation to the site
Can anyone identify this component for me please? It's from an Asus US425IA motherboard. The writing on the component reads "ML KABK EKBD"
https://ibb.co/Smgr01T
https://ibb.co/8n3CV3XComment
That looks more like a MOSFET or DC-DC converter IC to me, from the little I can see.PeteS in CA
****************************Comment
I have an Alienware Area 51m laptop that blew a surface mount aluminum cap.
I've attached an image showing the following lettering:
8 N
100
EZY
I know it's 100uF 25V series ZY but I'm coming up dry on locating the manufacturer.
Any ideas?
Thanks,
-vencainAttached Filesif you find these attachements useful please consider making a small donation to the site
Looks like Panasonic to me, maybe some vendors special series, but if you'll look close to letter E, it's slightly bigger then other letters, like in Panasonic caps, but this is only thing that reminds me of panasonic caps
http://capacitor.web.fc2.com/ idk where i found this site, but there is so much info, especially on cheap chinese caps, and also there is info on ELFL, but it's in japanese, but translatable
Official company name: Changzhou Anyway International Co., Ltd.
Headquarters: China
Comment: Changzhou has two brands of capacitors, "HZC" and "ELFL", so please also refer to the HZC item. ELFL is related to self-made PCs and there is no report of installation, but ELFL is also posted because there is a capacitor item of the brand HZC of the company.
About HZC: It is said that it is used in recent cheap USB cards and NICs. There is also a report that Scythe's sickle bay amplifier Rev2.0 is also installed. Changzhou has two brands of capacitors, "HZC" and "ELFL".Comment
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... - Loading...
- No more items.
