I was fortunate enough to be given bvr and schematic files for these two boards yesterday. The board files are not available unfortunately, so please do not ask. Both FBV and OBV will open bvr files. Happy repairs and thanks to our benefactor who is generously supplying the community with these very late model files.
820-02100 and 820-02382 bvr and sch files
My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SATags: None -
Re: 820-02100 and 820-02382 bvr and sch files
Same board outline fix as for 820-2098/820-02443, who knows why it's not the same as before.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
This really comes down to if the BVR3 is an implied closure or wants explicit closure of the exterior polygon; ie, a->b->c->a vs a->b->c[->a implied].
FBV implementation checks if the head == tail, if not it performs the closure.
I think it's time I wrote an explicit specification of my format, at least that way other people can make their own implementations too.YouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbvComment
reservedLast edited by Pedro147; 09-29-2022, 09:34 AM.My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SAComment
Hello friends.
anyone have Macbook a2485 boardview in working. i checked that some is not working its showing error when i was run the file.Comment
by eccerr0rJust want to post here:
Sorry for not adding anyone as "friends" ... unfortunately it's the same policy I have with fsckbook. No third parties need to know my acquaintances. If you're an acquaintance we both know it.
I don't post anything worth following anyway :-(
Note: If you're wondering why I post PDFs of homemade schematics, it's because I'm too lazy to convert to GIF as it requires effort to make sure you scale it to a size where all text is still readable.
BTW anyone trying to productize any of my schematic designs: Other than the obvious...-
Channel: Visitor Messages
by plummmmI am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just... -
by redoxyLaptop is not charging and not powering on.
Model details is AN515-55-517T
Board is FH51M LA-J871P
The circuit diagram and the boardview were generously posted by satishkumar.
I have tried following the Beginner's guide to laptop troubleshooting and started by taking measurements on the charging system.
I get 19V on the PQB3 MOSFET input and nothing on the output (pardon my ignorance of the proper terminologies)
Does this point to a bad MOSFET or could it be another component?
I have attached the charging diagram... -
by EasyGoing1I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
So I decided to implement UPNP...-
Channel: Troubleshooting & Designing Networks
by SnownomowHello!
I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into... - Loading...
- No more items.
