Asus x571lh daxktdmb8c0 rev c - xktd
  • djcristian28
    • Jun 2022
    • 27
    • Perú
    Hi
    Dear I need help with a bios for the ASUS X571LH DAXKTDMB8C0 REV C - XKTD.
    I thank you very much. Cheers
  • djcristian28
    • Jun 2022
    • 27
    • Perú
    Re: Asus x571lh daxktdmb8c0 rev c - xktd
    Old bios
      • 21692
      Originally posted by djcristian28
      Hi
      Can you post a picture of the small white QR code on the motherboard
      • djcristian28
        • Jun 2022
        • 27
        • Perú
        (y)
        • hoaca388
          Badcaps
          • Jan 2022
          • 12281
          (y)
          Take a close-up photo, so that the characters on the QR code can be clearly seen.
          • djcristian28
            • Jun 2022
            • 27
            • Perú
            • djcristian28
              • Jun 2022
              • 27
              • Perú
              What is the code used for?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12281
                QR code is required to identify the exact device model but the picture you posted is not what we are looking for.
                • djcristian28
                  • Jun 2022
                  • 27
                  • Perú
                  The QR code is: QCCXKT5MC02500228,L625NBCX007KPCMB,X571LI,60NB0QI0-MB2400,200,244BFE868314
                  It is the same image that they requested of my motherboard
                  • cacla
                    • Apr 2015
                    • 444
                    You have sn form unit ?
                    • djcristian28
                      • Jun 2022
                      • 27
                      • Perú
                      Sn? what do you mean friend?
                      It didn't work my friend 😞 only the keyboard lights turn on and nothing else and the fans don't turn, what do you think is happening? thanks for your answer
                      • djcristian28
                        • Jun 2022
                        • 27
                        • Perú
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12281
                          Try with clean ME file
                          • djcristian28
                            • Jun 2022
                            • 27
                            • Perú
                            Thanks for the file but it didn't work, why is that?
                            In the QR image of the SN that I sent, the model is x571LI and not x571LH, is that why? I placed LH from the beginning because I only found information with the same motherboard number "daxktdmb8c0 rev c - xktd" I appreciate your support in advance. I need the laptop to be able to work
                            PD. As you can see in the images, it only turns on the keyboard lights and the battery charge light.
                            • satishkumar
                              • Sep 2015
                              • 164
                              • India
                              Upload ur laptop original bios
                              the file that u have uploaded in post #2 is not matching with ur laptop serial number
                              • cacla
                                • Apr 2015
                                • 444
                                I will sent your bios in 15min I need time to get home
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12281
                                  Vivobook 15 X571
                                  • djcristian28
                                    • Jun 2022
                                    • 27
                                    • Perú
                                    a query, for this to clean the bios I think that in "type" it should say: "region stock"? check the bios and it says "extracted" it's supposed to be clean right?
                                    • djcristian28
                                      • Jun 2022
                                      • 27
                                      • Perú
                                      dear friend, if it is the bios that was by default in the notebook, when updating windows 10 it crashed and it no longer started, that's why we chose to reprogram the bios
                                      • djcristian28
                                        • Jun 2022
                                        • 27
                                        • Perú
                                        Thank you very much dear friend for the support, I will wait.
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                          by grimacelord
                                          I have spent the last hour on this and I guess this is just over my head, so here I am.
                                          I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                          The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                          Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          Asus vivobook s510ua bios changed to x510un
                                          by lrouw84
                                          Hi there,
                                          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                          01-28-2023, 01:31 PM
