Asus x571lh daxktdmb8c0 rev c - xktd
  • djcristian28
    • Jun 2022
    • 27
    • Perú
    Hi
    Dear I need help with a bios for the ASUS X571LH DAXKTDMB8C0 REV C - XKTD.
    I thank you very much. Cheers
  • djcristian28
    • Jun 2022
    • 27
    • Perú
    Re: Asus x571lh daxktdmb8c0 rev c - xktd
    Old bios
      • 22293
      Originally posted by djcristian28
      Hi
      Can you post a picture of the small white QR code on the motherboard
      • djcristian28
        • Jun 2022
        • 27
        • Perú
        (y)
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          (y)
          Take a close-up photo, so that the characters on the QR code can be clearly seen.
          • djcristian28
            • Jun 2022
            • 27
            • Perú
            • djcristian28
              • Jun 2022
              • 27
              • Perú
              What is the code used for?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                QR code is required to identify the exact device model but the picture you posted is not what we are looking for.
                • djcristian28
                  • Jun 2022
                  • 27
                  • Perú
                  The QR code is: QCCXKT5MC02500228,L625NBCX007KPCMB,X571LI,60NB0QI0-MB2400,200,244BFE868314
                  It is the same image that they requested of my motherboard
                  • cacla
                    • Apr 2015
                    • 444
                    You have sn form unit ?
                    • djcristian28
                      • Jun 2022
                      • 27
                      • Perú
                      Sn? what do you mean friend?
                      It didn't work my friend 😞 only the keyboard lights turn on and nothing else and the fans don't turn, what do you think is happening? thanks for your answer
                      • djcristian28
                        • Jun 2022
                        • 27
                        • Perú
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          Try with clean ME file
                          • djcristian28
                            • Jun 2022
                            • 27
                            • Perú
                            Thanks for the file but it didn't work, why is that?
                            In the QR image of the SN that I sent, the model is x571LI and not x571LH, is that why? I placed LH from the beginning because I only found information with the same motherboard number "daxktdmb8c0 rev c - xktd" I appreciate your support in advance. I need the laptop to be able to work
                            PD. As you can see in the images, it only turns on the keyboard lights and the battery charge light.
                            • satishkumar
                              • Sep 2015
                              • 164
                              • India
                              Upload ur laptop original bios
                              the file that u have uploaded in post #2 is not matching with ur laptop serial number
                              • cacla
                                • Apr 2015
                                • 444
                                I will sent your bios in 15min I need time to get home
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12441
                                  Vivobook 15 X571
                                  • djcristian28
                                    • Jun 2022
                                    • 27
                                    • Perú
                                    a query, for this to clean the bios I think that in "type" it should say: "region stock"? check the bios and it says "extracted" it's supposed to be clean right?
                                    • djcristian28
                                      • Jun 2022
                                      • 27
                                      • Perú
                                      dear friend, if it is the bios that was by default in the notebook, when updating windows 10 it crashed and it no longer started, that's why we chose to reprogram the bios
                                      • djcristian28
                                        • Jun 2022
                                        • 27
                                        • Perú
                                        Thank you very much dear friend for the support, I will wait.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
