ASUS A7V8X-X No Post
  • derkraken
    • Jun 2007
    • 9
    Hello everyone.
    I have an ASUS A7V8X-X motherboard. Last night I left the computer on. When I came back to it it appeared to be in sleep mode but wouldn't reactivate.
    I turned it off and then tried to reboot and I had no POST beep, although the green power LED was lit, the drives all span and the CPU fan started up. The monitor remained blank with its LED flashing.
    I have tried resetting the CMOS, and replacing the CMOS battery. I have tried reseating the Video Card and RAM, and swapping RAM around the slots. Lastly I tried another CPU and while I was doing that I noticed a component near the CPU seems to have blown. Here is a picture of it - one of the square chips with 9915H on it.
    Does anyone know what it is, and if replacing it (assuming I can locate another and do so successfully) is likely to revive my motherboard?
    Thanks.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ASUS A7V8X-X No Post
    been there done that.check for bad psu/ram.
    thats the vdimm regulator.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by derkraken
      Hello everyone.
      That was my favorite motherboard in 2004,(mine was purchased on November 6, 2003) good for the T'bred 2400+s. (Got my T'bred 2400+ KIXJB in August, 2004) (IIRC, on August 3) It never let me down in 2004 (except for if I get greedy for higher than 180 Mhz FSB, or about that)
      (And the max was 160 Mhz FSB for the T'bred 2400+, because I could only use 15.0 for the multiplier)
      It always POSTED for me and didn't have too much extras. Those were the days.
      Woah, a fried MOSFET!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • derkraken
        • Jun 2007
        • 9
        Thanks for the replies.
        I think possibly the reason for this failure was that I put a stick of 400MHz RAM in along with the two 333 MHz sticks that were already in there. I had FSB set to 333MHz, and I just noticed in the motherboard manual that DDR400 RAM is not supported at 333MHz (only at 266 and 200).
        I was running an Athlon XP 2400+ in it, at 13.5x multiplier, 166 FSB.
        • c_hegge
          • Sep 2009
          • 5219
          That shouldn't matter. I use DDR400 in DDR266 and 333 motherboards all the time. It never causes problems. DDR400 RAM is fully backward compatible with 333 and 266 motherboards.
            • 30997
            i think your getting a bit confused,
            i have the deluxe version and some similar ones.
            the warning is that you cant use all 3 slots if you run faster than 333.
            it wont run stable.
            it's the same for other motherboards running with a VIA KT400 chipset too.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              is that like the a7v8x where you can only use 3 slots if you use pc2100, 2 for 2700, and one for 3200?
              if so, you have to go by the chip's label, it will not slow the chips down for you.
              i just sold my friend one and it took him some time to understand that concept...
              sigpic
              (Insert witty quote here)
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                As was said, that wouldn't be likely blow the MOSFET.
                You pretty much need a short somewhere to blow a MOSFET.
                A bad [w/short in] stick of RAM or CPU might do it.
                A shorted to ground cap might too.
                Mann-Made Global Warming.
                - Dr Seuss
                • Dammon
                  Ensign
                  • Jun 2010
                  • 36
                  The A7V8X-X is a good motherboard. Mine has been running 24/7 since I bought it six years ago and it's showing no sign of any problems. I'm looking at retiring it soon though, since it's really too slow to do much nowadays.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    have you heard of ubintu or even linux in general? my friend's a7v8x does ubuntu without any problems. granted i loaded it with a tbred 2400+...
                    sigpic
                      • 30997
                      no, it's 3 slots upto and including 333 and 2 slots at 400.
                      i suspect it's because it's dual-channel so the first 2 sticks are mapped as 64bit.
                      it's never restricted to 1 slot.
                      and it's the a7v8x-e deluxe and the a7v8x-x that i have here.
                      • Dammon
                        Ensign
                        • Jun 2010
                        • 36
                        The A7V8X-X is single channel. According to the manual it can use PC3200 with 2 banks, and PC2700 with a max of 4 banks.
                        • Dammon
                          Ensign
                          • Jun 2010
                          • 36
                          I'm running mine with a tbred 2200+ and it's fine with WinXP. My biggest complaint is that it can't run HD video without stuttering. I don't think it'd be any different under Linux.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Correction, Not likely to blow THAT MOSFET.
                            That one is for main RAM power. [Basically Vcc]
                            It [too fast of RAM] might blow the Vtt regulator and that might be a MOSFET [vice some other kind of VR] but it would be a much smaller part than the one you circled.
                            The Vtt regulator being weak is part of why those boards have restrictions on RAM.
                            Vtt is the logic signal voltage.
                            - Vtt applied = high = a logic "1"
                            - Ground [or nearly] applied = low = a logic "0"
                            The higher the frequency the more load on the Vtt regulator.
                            - Dr Seuss
                            • Dammon
                              Ensign
                              • Jun 2010
                              • 36
                              Looking at my own board, I notice there's nothing but OST caps around the vdimm regulator. Maybe they've gone bad? The CPU vrm uses Nichicon caps.
                                • 30997
                                your manual is wrong - so is mine.
                                the manual does say that, but there are only 3 physical banks on the board!
                                look at page 1-7
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Yep, same here. If it fails to boot, you need to raise the latencies, please try 2.5-3-3-7.
                                  DO NOT USE 2.0-2-2-6! (Except that with underclocking, it appears that quality RAM can do this)
                                  Arc A770 16 GB
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    That may be your video card and I don't recommend having the resolution higher than 1280x1024.
                                    Also, check the video driver setup.
                                    Arc A770 16 GB
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      IIRC, your motherboard is the nForce2 version, the A7N8X-E Deluxe, IIRC, A7V8X-E don't exist.
                                      And the nForce 2 typically gets higher FSBs than the Via KT400, because you don't have the issue with the PCI and AGP going over.
                                      Arc A770 16 GB
                                        • 30997
                                        could be, not seen it in a while.
                                        i'll try & find it later.
