Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • betonel
    • Nov 2015
    • 32
    • romania
    Here we try to figure out a way to bypass activation lock (FMM) and password lock. Until now there is no method available, but we're working to figure it out.
    What we know so far:
    1. There is a W25Q64 8Mb 3x4mm wson8 chip on the back of the board with part of NVRAM ( some strings can be seen in its dump, eg: iBoot-6723.50.2, boot-args=.nonce-seeds=, luetoothInternalControllerInfo= bt mac, InstallPhase -> Boot 1 ) but no serial number in clear.
    Other strings: Apple Secure Boot Root CA - G21.0, AppleStorageProcessorANS2-1161.40.21~221
    2. Some suggest SN might be stored in ssd first nand, on hidden partition, some say it is tied to M1 processor itself ( which I doubt ).
    3. Checkra1n / MinaTool / CheckM8 solution does not work on these devices, as there is newer iBoot version (T2 bios chip is just 4Mb vs M1 8Mb). An idea would be to downgrade iBoot so can be accessed on ssh. Good dump would be required here, maybe there are older versions we can use.
    4. I have discovered a way to browse with safari if you boot into diagnostics mode ( hold on power until startup option is shown then press and hold Command-D, let it finish checking then click on find out more ), but from here you can't run any app, even if you can see it on usb mass storage attached. You can also download app but couldn't find a way to run it.
    5. Now I have W25Q64 outside of locked macbook, wired to the board with long cable, so tests can be performed easier.
    If you have dumps for 13"/14"/15" ( locked /unlocked ) please share them here for testing and comparation. Dump with secureboot disabled might help.
    6. Other way around can be writing SN from locked M1 into unlocked T2 mac, register it to mdm/icloud then get code. Looking for volunteers.
    Once we find out more interesting things will edit this first post to keep it simple. There is no doubt we'll find solution soon.
  • curiositymaster
    • Apr 2021
    • 45
    • Nigeria
    Re: Macbook M1 bypass FMM / EFI Unlock
    Do you have boardview file/schematics for any 13" M1? I need to know where the w25q64 is located and how did you manage to read it?
      • 22021
      Schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41 .Use the forum search as well,it might be posted already
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        You are on to something, however, the M1 Soc Rom chip does not have Serial Data on it. We have verified this with an MBA M1. No actual serial data on that, now I would not be surpised it is on the M1 itself...or the nand as you suggest, but why would it be in the nand is my question. It may be on something, if we can track that down, we just solved M1 locked devices that are MDM locked. Easy peasy
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Why would it be in the nand? Have you seen iPhones and iPads? Apple has done it before so it might be same with M1 macbooks.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Where would it be then? For sure not the nand I am sure...
            sigpic
            • heatorious
              • Apr 2020
              • 2
              To add on this would be MDM locks with fmm off. Is there a bypass or full removal option. I wrote a script back for 2015-2017 models before the usb thing to bypass the mdm prompts upon boot. Will be looking into getting a M1 and tweaking to see if i can get it to work on a M1.
              • LEOMORALES
                • Dec 2019
                • 2
                • tuxtla gtz
                It's the Nand. The info is in the nand. We have lowered the nand and tried to read with irrepair 12 but it does not let me read, it is hidden in some way. If you could access that hidden info, it would be there like the iPad info.
                • betonel
                  • Nov 2015
                  • 32
                  • romania
                  What if you remove nand and run diagnostic mode, I guess you will be able to see SN there. Funny will be that SN is generated from bt mac + wifi mac, and we're looking for something that doesn't exist.
                  Need to compare dumps from SOC rom of M1, @Stephen, can you share some? Will upload mine tomorrow.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    Sure I can get some M1 info for a locked device.
                    sigpic
                    • betonel
                      • Nov 2015
                      • 32
                      • romania
                      Winbond chip is located on the back side of the board similar with T2 models. Attached you can find some pictures of what I've done. Be careful, it's 1.8V chip, so you need to use appropriate programmer adapter.
                      If you wonder what kind of wires I've used.. it's old pc IDE cable
                      Instead of wasting money on T203 (~$200) and get stuck with uson4*3 or DS809SE (~$200) which is exactly an R809F i use this:
                      64$ RT809F + 15 adapters ( 1.8V adapter required!)
                      https://s.click.aliexpress.com/e/_A6uAnD
                      Programmer ( same as DS809SE )
                      25$ MacBook Apple Notebook Maintenance Serial Number Modification Tool T2 Chip Unlock BIOS Read Adapter Board
                      https://s.click.aliexpress.com/e/_ApVJfz
                      Let us program USON2*3 U3750+U3710 Wifi+BT ROM, XSON4*4, Apple T2 ROM USON 4*3 and Macbook M1 SOC, WSON6*5, WSON**6 and WLCSP 16 ball used on A1534 bios or SSD rom.
                      $52 Sam Connector with Seat Socket Serial Line for DS809SE
                      https://s.click.aliexpress.com/e/_A0aPKx
                      Small mod is required to work with RT809F: undo all pins from connector and put it reverse way -> red will be on opposite side , and run a wire from PIN 8 (+) to pin 8 on the board , which you can hold it by hand, without needing to power on MB machine.
                      • betonel
                        • Nov 2015
                        • 32
                        • romania
                        Attached is my SOC chip dump and multiple tests.
                        SN from this dump is FVFDV113Q05P.
                        Please upload yours..
                        Unlocked with Secure boot disabled is wanted.
                        btw: if you re not a bot, to get correct SN, xor all 1 with 1
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          How did you get the serial number from the dump besides the bottom case from the MacBook? Was this from the chip or bottom case? This information will make M1 unlocks a piece of cake with a serial number change for MDMs.
                          sigpic
                          • betonel
                            • Nov 2015
                            • 32
                            • romania
                            Unfortunately SN is from bottom case and/or from Diagnostics mode. Can you share your M1 SOC dumps ?
                            • imranromi
                              • Jan 2015
                              • 1290
                              • Pakistan
                              Here both file is M1
                              Mdm locked.
                              • heatorious
                                • Apr 2020
                                • 2
                                Does any one have a working M1 FMM off and MDM locked. If so can ya pm me i want to try to see if i can do a decent bypass of the prompts thru updating until we have a more perm solution. I've only seen some things about editing the host file don't know how that would go thru updates.
                                • betonel
                                  • Nov 2015
                                  • 32
                                  • romania
                                  Mdm locked.
                                  Please tell us SN for each dump and machine type. BTW..
                                  Couldn't start my MBP M1 13" 2020 with your dumps. It will start DFU mode at least.
                                  M1.bin -> iboot-6723.61.3
                                  M2.bin -> iboot-6723.41.11
                                  my.bin -> iboot-6723.50.2
                                  • Nico Latour
                                    Banned
                                    • Sep 2019
                                    • 52
                                    • france
                                    m1 bin is encrypt! when you decrypt you see serial!!! but change serial in this bin is not working for unlock icloud)
                                    • curiositymaster
                                      • Apr 2021
                                      • 45
                                      • Nigeria
                                      Thanks for this info. I have the DS809SE and t203.
                                      • ebaymonster
                                        • Dec 2021
                                        • 0
                                        • Ukraine
                                        I have 5pcs MBA 2020 m1 and 1 MBP 13 m1 + t203. if you want i can desoldering and make dump.
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
                                        • oxonater
                                          Apple MacBook Pro A2141 16" IC BYPASS
                                          by oxonater
                                          Hi everyone hope all are well
                                          I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                          I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                          The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                          I suppose it's worth noting googling the part package brings up various...
                                          10-23-2024, 11:21 PM
                                        • keats11
                                          T2 Macbook MDM Unlock by S/N change.
                                          by keats11
                                          I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                          05-15-2023, 06:46 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • Flasman90
                                          Macbook Pro DFU Restore Issues
                                          by Flasman90
                                          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                          08-30-2025, 10:27 AM
