Nintendo DS (not DSi) not supporting WPA
  • japlytic
    • Oct 2005
    • 2086
    As some of you may be aware, the Nintendo DS only supports WEP security for wireless connections.
    The Nintendo DS has been released after WPA came out.
    I still wonder why the DS did not support WPA when it was released...
    One other thing: The DSi supports WPA and WPA2, but only with DSi games.
    • 31025
    Re: Nintendo DS (not DSi) not supporting WPA
    most ds games are point2point not internet designed anyway.
    however, someone may hack it, there are custom firmwares about.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      the only games i can think of that would be internet based might be mariokart... thats all i know of... its not like i own one...
      sigpic
      (Insert witty quote here)
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        It only supports 802.11b which didn't support WPA.
        • retiredcaps
          • Apr 2010
          • 9271
          You must mean it is specific to this system? My Cisco 350 PCI 802.11b card supports WPA with Windows XP.
          --- begin sig file ---
          --- end sig file ---
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            I've never seen any consumer equipment supporting WPA on 802.11b equipment.
            • japlytic
              • Oct 2005
              • 2086
              This is true for B-only access points and older B-only clients.
              • Funkimunk
                • Sep 2010
                • 7
                When the DS was designed WEP was viewed as being acceptable so Nintendo designed the hardware to support only this mode of WiFI Security.
                The Ds + Ds Lite have only 4MB of RAM , a 67 MHz ARM9 and 33 MHz ARM7; this is enough capability to process the Simple RC4 Encryption of the WEP standard.
                This Spec does not have enough working area or processing power to allow use of WPA (and play games as intended) which is RC4 + TKIP based nor does it allow use of the AES based WPA2.
                An oversight on the part of Nintendo that has annoyed me personally for years, the newer DS designs (DSi + XL) have 16MB of RAM, a 133 MHz ARM9 and 33 MHz ARM7 in part to facilitate use of better encryption (as all DS games must be made to run identically as on the lowest common denominator HW there would be no other legitimate reason to up the specs - the camera can operate on the older HW).
                On a Happy note: WEP is now planned to be removed from the WiFI Spec
                • stevo1210
                  • Oct 2006
                  • 4156
                  I have the PCMCIA version of that card and it doesn't support WPA... I even had to go through the trouble of having an extra wireless router with WEP to support that card.
                  • dilashyaa
                    • Feb 2014
                    • 1
                    • gjhkighjgh
                    What Is A Nintendo Event? THis might sound stupid to some people but wth is a nintendo event? What i mean is like, is it a thing to put on your game, a wireless thingy, or i dunno a applcation to put in ur game like a AR?
                    fun video ~ video clips ~ funny video
                    • Elysarian
                      • Mar 2013
                      • 200
                      • United Kingdom
                      I've been to a couple of "Nintendo Events" - they were for the Pokemon games...
                      I went with the wife so she could catch some super-rare (i.e. only available at events - e.g Mew) Pokemon - early ones used the wired connection but later ones utilised the wireless capabilities of the DS/DSi/DS Lite (IIRC more recent ones are "virtual events" over the internet via WiFi).
                      As far as I'm aware the Pokemon and Animal Crossing (Don't ask!) games are the only ones to make a lot of use of the internet aspect of the DS - there are probably others though.
                      • jscott5150
                        • Jul 2016
                        • 4
                        • canada
                        • fab13
                          Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
                          by fab13
                          Hello everyone
                          After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
                          I specify that there is no other short circuit or heating component(Vu thermal camera)
                          First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
                          Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
                          08-23-2023, 10:54 AM
                          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                          10-01-2024, 12:46 PM
                        • survivalbloke
                          Xbox Series X - crashing to dashboard shortly after launching games
                          by survivalbloke
                          Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                          09-18-2024, 11:54 AM
                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                          10-02-2024, 08:52 AM
                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                          10-02-2024, 07:51 AM
