CF-53 mk1 password
  • tmaciejs
    • Oct 2018
    • 11
    CF-53 mk1 password
    I guys I looking for my CF-53 mk1 unlocked BIOS dump, can I ask somebody to help me in getting it. However, will it be better if I post my bios dump and someone decodes it?.
    Thanks Matt
  • peste
    • Dec 2016
    • 13566
    • ROMANIA
    Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    Thanks Matt
    post it ...
    • tmaciejs
      • Oct 2018
      • 11
      Originally posted by peste
      post it ...
      Please help me remove the password from the CF-53 mk1.
      I will be thankful.
      • peste
        • Dec 2016
        • 13566
        • ROMANIA
        I will be thankful.
        try..
        • tmaciejs
          • Oct 2018
          • 11
          Re: CF-53 mk1 password
          Hi Peste - I tried you modificate dump but unfortunately password still is available. Big thank you for help. Correct Bios I finded here :
          https://www.badcaps.net/forum/attach...0&d=1627750435
          • oaktreelimb
            • Jun 2022
            • 5
            • usa
            I got a same Panasonic CF-53 mk1. It does have BIOS password. I can boot the laptop to Windows log on fine without entering required to enter any password but if I hit F12 or F2 at boot up to try to get into BIOS setup, it will ask for password.
            I believe the hard drive is also password protected. If i pull the hard drive and install in other laptop as a secondary drive, at power up, a password screen pop up. If i enter Hard Drive password wrong 3 times, the laptop will shut down.
            When i installed the HD from the Panasonic in other laptop, it can see the HD but no Partition. I did use DISKPART and other 3rd party HD software but i can't partition or format it.
            Do you think i can use the BIOS file that you posted and use it in my Panasonic ? Or I should get and upload my laptop BIOS's file and ask for help.
            Thank you.
            • peste
              • Dec 2016
              • 13566
              • ROMANIA
              Thank you.
              post the original bios here ..
              • oaktreelimb
                • Jun 2022
                • 5
                • usa
                PANASONIC CF-53 MK1 BIOS file
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12322
                  panasonic cf-53 mk1 bios file
                  panasonic cf-53 mk1
                  ​https://www.badcaps.net/donate
                  • oaktreelimb
                    • Jun 2022
                    • 5
                    • usa
                    Thank you so much for your help but I need the Supervisor Password.
                    The Boot hard drive is protected by Supervisor password so when I erase the password in BIOS, it doesn't boot up.
                    I can now boot from USB flash drive and run DISKPART. The DISKPART can see the physical drive but it is unable to partition it. GOT I/O error.
                    • Mancity9320
                      • Jul 2023
                      • 5
                      Panasonic Toughbook CF-53 Mk1 BIOS Password Removal
                      Hi, please can you remove the bios password or if possible just let me know the password, thanks.
                      • peste
                        • Dec 2016
                        • 13566
                        • ROMANIA
                        Re: Panasonic Toughbook CF-53 Mk1 BIOS Password Removal
                        the bios is almost empty... read the bios chip again, check it and post again..
                        • Mancity9320
                          • Jul 2023
                          • 5
                          Okay, I desoldered the bios to read it this time so hopefully this one is okay.
                          • lapfix
                            • Mar 2020
                            • 2764
                            • my workshop
                            Try and give feedback
                            • Mancity9320
                              • Jul 2023
                              • 5
                              reflashed the changed bios, all looked good, resoldered the bios in but it still asks for a password.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Here you are
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                • Mancity9320
                                  • Jul 2023
                                  • 5
                                  Hi, I didn't get to try the new bios as I messed up soldering the bios chip back onto the motherboard and destroyed a couple of traces. luckily I have a parts cf53 mk1 coming next week that I can swap out the system board from and there is no bios password on it, we live and learn. Thanks for your help.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    Upload good quality image of the damaged area. There's no need to swap the motherboard for that, traces can be restored - it's not a big problem, and it's doable even with basic soldering skills.
                                    • perzyk23
                                      • Mar 2017
                                      • 31
                                      • Poland
                                      Good morning.
                                      I bought a Panasonic CF-53. Unfortunately, it has a bios password and I can't do anything with it. I don't know the password and I can't boot from USB. Can anyone help me download this password?
                                      Thank you in advance!​
                                      • volinakis
                                        volinakis commented
                                        Editing a comment
                                        serial number?
                                    • perzyk23
                                      • Mar 2017
                                      • 31
                                      • Poland
                                      1HTCA15831
                                      • Buzzfuzz2k
                                        Bios password removal on a Unowhy dump
                                        by Buzzfuzz2k
                                        Hi Everyone,
                                        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                        the Computer is a Unowhy small pc
                                        N° UYM6524702229
                                        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                        My first attempt was to get the bios dump from windows...
                                        11-13-2023, 07:37 AM
                                      • dell_bios
                                        Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                        by dell_bios
                                        Hi everyone,
                                        I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                        The board has three SPI flash chips:
                                        - W25Q64FV (main BIOS)
                                        - W25Q32FV (EC/TPM)
                                        - W25X10CL (configuration)
                                        I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                        The dump contains protection that needs to be removed.
                                        If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                        I’m also happy to share my dump for comparison if needed.
                                        Laptop model: [please specify, e.g....
                                        10-16-2025, 04:28 PM
                                      • ArkzG
                                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                        by ArkzG
                                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                        What I currently have available:
                                        - Model: FA506NF (2021)
                                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                        - Tools: CH341A programmer ready to use
                                        Does anyone have either a clean 2MB .bin dump of this model,...
                                        09-26-2025, 09:34 PM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
                                      • iwu
                                        Dell Latitude 5520 - dump bios to obtain password
                                        by iwu
                                        I am not experienced in electronics, but I really want to check if my idea is possible.
                                        I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                                        BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                                        There was no computrace activated.
                                        I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                                        1. I do not know how thebios...
                                        04-14-2024, 04:10 AM
