CF-53 mk1 password
  • tmaciejs
    • Oct 2018
    • 11
    CF-53 mk1 password
    I guys I looking for my CF-53 mk1 unlocked BIOS dump, can I ask somebody to help me in getting it. However, will it be better if I post my bios dump and someone decodes it?.
    Thanks Matt
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    Thanks Matt
    post it ...
    • tmaciejs
      • Oct 2018
      • 11
      Originally posted by peste
      post it ...
      Please help me remove the password from the CF-53 mk1.
      I will be thankful.
      • peste
        • Dec 2016
        • 12792
        • ROMANIA
        I will be thankful.
        try..
        • tmaciejs
          • Oct 2018
          • 11
          Re: CF-53 mk1 password
          Hi Peste - I tried you modificate dump but unfortunately password still is available. Big thank you for help. Correct Bios I finded here :
          https://www.badcaps.net/forum/attach...0&d=1627750435
          • oaktreelimb
            • Jun 2022
            • 5
            • usa
            I got a same Panasonic CF-53 mk1. It does have BIOS password. I can boot the laptop to Windows log on fine without entering required to enter any password but if I hit F12 or F2 at boot up to try to get into BIOS setup, it will ask for password.
            I believe the hard drive is also password protected. If i pull the hard drive and install in other laptop as a secondary drive, at power up, a password screen pop up. If i enter Hard Drive password wrong 3 times, the laptop will shut down.
            When i installed the HD from the Panasonic in other laptop, it can see the HD but no Partition. I did use DISKPART and other 3rd party HD software but i can't partition or format it.
            Do you think i can use the BIOS file that you posted and use it in my Panasonic ? Or I should get and upload my laptop BIOS's file and ask for help.
            Thank you.
            • peste
              • Dec 2016
              • 12792
              • ROMANIA
              Thank you.
              post the original bios here ..
              • oaktreelimb
                • Jun 2022
                • 5
                • usa
                PANASONIC CF-53 MK1 BIOS file
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11735
                  panasonic cf-53 mk1 bios file
                  panasonic cf-53 mk1
                  Mį»i khoįŗ£n quyĆŖn góp cho badcaps đều được hoan nghĆŖnh, hĆ£y nhįŗ„p vĆ o liĆŖn kįŗæt nĆ y Ä‘į»ƒ quyĆŖn góp. Cįŗ£m Ę”n tįŗ„t cįŗ£ những ngĘ°į»i į»§ng hį»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
                  • oaktreelimb
                    • Jun 2022
                    • 5
                    • usa
                    Thank you so much for your help but I need the Supervisor Password.
                    The Boot hard drive is protected by Supervisor password so when I erase the password in BIOS, it doesn't boot up.
                    I can now boot from USB flash drive and run DISKPART. The DISKPART can see the physical drive but it is unable to partition it. GOT I/O error.
                    • Mancity9320
                      • Jul 2023
                      • 5
                      Panasonic Toughbook CF-53 Mk1 BIOS Password Removal
                      Hi, please can you remove the bios password or if possible just let me know the password, thanks.
                      • peste
                        • Dec 2016
                        • 12792
                        • ROMANIA
                        Re: Panasonic Toughbook CF-53 Mk1 BIOS Password Removal
                        the bios is almost empty... read the bios chip again, check it and post again..
                        • Mancity9320
                          • Jul 2023
                          • 5
                          Okay, I desoldered the bios to read it this time so hopefully this one is okay.
                          • lapfix
                            • Mar 2020
                            • 2721
                            • my workshop
                            Try and give feedback
                            • Mancity9320
                              • Jul 2023
                              • 5
                              reflashed the changed bios, all looked good, resoldered the bios in but it still asks for a password.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria šŸ‡§šŸ‡¬
                                Here you are
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                • Mancity9320
                                  • Jul 2023
                                  • 5
                                  Hi, I didn't get to try the new bios as I messed up soldering the bios chip back onto the motherboard and destroyed a couple of traces. luckily I have a parts cf53 mk1 coming next week that I can swap out the system board from and there is no bios password on it, we live and learn. Thanks for your help.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria šŸ‡§šŸ‡¬
                                    Upload good quality image of the damaged area. There's no need to swap the motherboard for that, traces can be restored - it's not a big problem, and it's doable even with basic soldering skills.
                                    • perzyk23
                                      • Mar 2017
                                      • 31
                                      • Poland
                                      Good morning.
                                      I bought a Panasonic CF-53. Unfortunately, it has a bios password and I can't do anything with it. I don't know the password and I can't boot from USB. Can anyone help me download this password?
                                      Thank you in advance!​
                                      • volinakis
                                        volinakis commented
                                        Editing a comment
                                        serial number?
                                    • perzyk23
                                      • Mar 2017
                                      • 31
                                      • Poland
                                      1HTCA15831
                                      • Buzzfuzz2k
                                        Bios password removal on a Unowhy dump
                                        by Buzzfuzz2k
                                        Hi Everyone,
                                        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                        the Computer is a Unowhy small pc
                                        N° UYM6524702229
                                        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                        My first attempt was to get the bios dump from windows...
                                        11-13-2023, 07:37 AM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • adil12
                                        Panasonic toughbook cf53-as-50de bios password removal help
                                        by adil12
                                        hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
                                        thank you...
                                        09-14-2021, 10:39 AM
                                      • iwu
                                        Dell Latitude 5520 - dump bios to obtain password
                                        by iwu
                                        I am not experienced in electronics, but I really want to check if my idea is possible.
                                        I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                                        BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                                        There was no computrace activated.
                                        I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                                        1. I do not know how thebios...
                                        04-14-2024, 04:10 AM
                                      • medinfo
                                        We can modify the "SecureBoot" state on Lenovo laptop from bios bin dump ? if bios password password on ?
                                        by medinfo
                                        03-07-2024, 07:28 AM
