Dead Vestel 17IPS71 power board
  • fnets
    • Oct 2017
    • 23
    Re: Dead Vestel 17IPS71 power board
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #102
      Originally posted by fnets
      would this be safer? "could you measure the dc voltage on CN3-CN4 (black connector) with the mainboard disconnected and see if there is at least a standby voltage"? but not sure where to put the probes.
      Sorry yes we all test things differently so i edited my last post im just going too look a schematic and will find test points.
      • fnets
        • Oct 2017
        • 23
        you're probably much more capable than I am. can you also tell me which leads plug in and which to leave unplugged?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #104
          plug all leads back in and screw the psu back down turn your tv on put your multi meter on dc volts then put the black probe on one of the psu mounting screws then with the red probe test the voltages on that connector are they numbered? pin 9 is 5v stby there are two rows of pins on that connector so maybe easier to push the red probe down the side of each wire where it goes into the connector it should read voltages ok doing it that way.
          • fnets
            • Oct 2017
            • 23
            the black connector (above) has CN4 & CN3 on the right (but no pin 9)
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #106
              basically cn4 and cn3 means two different connectors can be fitted to that pcb yours is classed as cn4 if you cant find pin 9 for now just test all the voltages i have added a picture so you maybe able too work out pin 9
              • fnets
                • Oct 2017
                • 23
                ok great, where is the picture?
                • fnets
                  • Oct 2017
                  • 23
                  ok yes I see the pins are on the side ...
                  do I need to put the black probe on ground?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #109
                    my guess its fith one down on the row you can get too.
                    • fnets
                      • Oct 2017
                      • 23
                      back tomorrow. thank you very much.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #111
                        yes black probe on ground a mounting screw is the easiest
                        • fnets
                          • Oct 2017
                          • 23
                          tested this morning. 240V AC going in and 0V DC going out on pin 9.
                          • fnets
                            • Oct 2017
                            • 23
                            if possible I'd like to know how you word this correctly?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #114
                              do you get any voltage on any of the pins? of cn4
                              • fnets
                                • Oct 2017
                                • 23
                                nothing, tried pins 1,3,5,7,9
                                sorry to cause confusion but I also started https://www.badcaps.net/forum/showth...064#post781064
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #116
                                  start from basics get a new battery a aa or 9v one and check your meters working fine on dc measurements i will have a look in the schematic while your testing that as i have not worked on one of these boards before
                                  • fnets
                                    • Oct 2017
                                    • 23
                                    just tried on 1.5v "C" Duracell and meter ok on DC setting?
                                    I also tried testing the diodes and I think they're ok (but this is the first time I've tested a diode).
                                    the capacitors look ok but haven't tested them.
                                    the TV wouldn't switch on and had no standby light.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #118
                                      thats ok then start with page one of this thread and follow each step, my guess its the same ic thats failedin this thread, see how far you get and what voltages you get etc but if that ic has failed its probably why you are getting no voltages on that connector
                                      • fnets
                                        • Oct 2017
                                        • 23
                                        ok thanks
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #120
                                          a common failure on these power supplies U202 FAN6300 SMPS IC if this ic is cheap enough and you can solder ok i would probably just change the ic but if i was fault finding this board i would just follow this thread step by step and see if it points too that ic being faulty.
