backlight issue Samsung UE32EH5000
  • Rashid36
    • Aug 2014
    • 65
    • Saudi Arabia
    Re: backlight issue Samsung UE32EH5000
    Dear All member i need help about this chip with number "2n=2m" or any website where i can find this code
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      Pin 1 - B13V - 13.10v
      Pin 2 - P_Dim - 0.90v
      Pin 3 - B13V - 13.10v
      Pin 4 - B13V - 13.10v
      Pin 5 - VAMP - 13.10v
      Pin 6 - BLU_ON - 4.88v
      Pin 7 - VAMP - 13.10v
      Pin 8 - GND - 0v
      Pin 9 - GND - 0v
      Pin 10 - GND - 0v
      Pin 11 - B5V - 5.27v
      Pin 12 - A5V - 5.29v
      Pin 13 - B5V - 5.27v
      Pin 14 - PS_ON - 3.5v
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So BLU-On and PS_ON look fine. It does look as though you may well have a fault around the led driver IC or associated circuitry.
        What is the part number of IC9101S?
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          will report back with that part number tomorrow dick_barton. so its the PSU at fault ? i have put screen back together so hopi g its nkt LEDs.
            Post #13: "IC P/N is PC1AC SLC101 0
            I did not have the time to look up that P/N yet.
            Also need to verify if it is SLC1010 or not, some other SAMSUNG's use MagnaChip SLC2012, SLC5012.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #26
              Sorry for hijacking, but I'm having the exact same issue so I want to keep up with this thread also The only difference is that I might've made a boo-boo: not getting any voltage on the BLU_ON pin, I decided to force it on by putting 5v on it...the backlight DID come on when I did so, but then I saw some smoke coming out of the PSU :| I quickly unplugged it and as it was discharging, the backlight flashed like every 1-2 seconds. I'll be honest, I cannot see what smoked there...there's no visible damage, but now I somehow DO get 3v on the BLU_ON pin....not sure whether that should be happening or something indeed shorted and let out the smoke...sucks there's no schematic for this...
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                Ok I believe I found out what blew: it's a small SOT-23 transistor on the back. It's located just about the FET driving the coil for the LEDs. It's labeled as Q9005 and under extreme magnification it seems to have a slight bulge and a burn mark on it. It's also not giving any reading on my meter in diode mode, in any direction so it could be that was causing the issue all along. Now I'll have to kindly ask you to look on your board and tell me what's written on it, since it's extremely small to begin with and mine's also slightly charred so I can't possibly see what's on it. Cheers.
                Wattevah...
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  #28
                  its deffo the SLC 1010 Budm
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    #29
                    part number is in Post 13 dick_barton
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      #30
                      i cant seem to find Q9005 but if you send me a picture of your board and to where i look i can certainly get P/N for you
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        #31
                        sorry. found Q9005. will get it under magnifier and report back
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          #32
                          Thanks. Please do that ASAP, would really appreciate it - it's for a client :| If I get that replaced, perhaps I can get back to working out why it's not working.
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #33
                            Is it by any chance 704 ? Would that make it this ?
                            Wattevah...
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              DannyX has the same power supply as you and he says that the IC is an SLC1012C equivalent to FAN7340.
                              Can you measure the voltages on Pins 1 to 16 of the IC with leds connected.
                              https://www.badcaps.net/forum/showthread.php?t=63684
                                Check the Voltage on the ADIM, BDIM, VCC, and ENA pins.
                                • Doc38343
                                  • Apr 2015
                                  • 402
                                  ok i flipped up PSU to read voltages on C9111. when i plugged in it went to 14, 17 then 19 then 1 displayed. i unplugged tv and voltage appeared 180 or so tjen gradually dropped. took 2 minutes for it to go back to 0v after switching off from plug.
                                  Was reading thru and this helped me on one recently that was driving me crazy. those LED testers will fire up lights that could be failing normally.
                                  I tested each little strip separately by disconnecting the connectors. on mine there were two strips per row and about 6 or 7 rows, the point is all of them had the same readings on my tester except one. the one that was low was my problem.
                                  The IC CS is set to shut off if the current/voltage is not within a pre-set tolerance.
                                  Just trying to help you may have already done this.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    I have also used my multimeter set to amps in series with the output lead of the led tester so that it also shows the current being supplied to the stip.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #38
                                      Yes, I confirm once again that's its the SLC chip Can't really test anything until I get that friggin' transistor replaced...I'm afraid something else might blow if I keep pushing it. The IC itself appears to be functioning correctly though, since the LEDs DO flash on and off, but they're very unstable since that control transistor is open-circuit and the enable pin is likely floating. I'm also not too sure what that array of 5 large resistors on the side of the board does....
                                      Wattevah...
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        #39
                                        just looked there under magnifier. it looks like 704 however my 7 has the top piece not printed properly but for what i can make out its 704
                                        • Mikeyboy2007
                                          • Mar 2013
                                          • 745
                                          • Scotland
                                          #40
                                          checked those voltages. im now suspecting failed IC ?
                                          Pin 1 - VCC 13v
                                          Pin 12 - ENA 0v
                                          Pin 15 - ADIM 0.8v
                                          Pin 16 - BDIM 0.8v
                                          • Kjell
                                            Samsung Series 9 - BIOS issue
                                            by Kjell
                                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                            08-01-2025, 09:15 AM
                                            09-07-2024, 05:50 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
