Samsung UE32eh5450 no backlight (LEDs OK)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Pretty strange issue with this TV here: the backlight won't come on despite the LEDs being OK. I lit them up all individually with a power adapter and they all come on really well, however when I try it with the power supply, nothing happens - not even a glow - NOTHING ! One interesting thing I noticed is that if I use my finger to touch the points where I scraped the track to reveal the copper trace for testing the LEDs, the LEDs light up faintly. The same goes for my meter: when I put my positive probe on the "return" (minus) end of each of the strips (the negative probe being on chassis ground) that strip would glow slightly. This "method" also allowed me to confirm that the LEDs appear to be OK, since if I keep my finger in the top right, the whole TV is lit - very dimly, but lit nonetheless. This doesn't mean that the LEDs are OK though: it could be one is failing under load, but it's not even making a flash or something - nothing turns on at all...
    There are 4 LED strips in series and the connector going to the PSU (CNL802) has 4 wires, but it's really just two wires, since the colors are in parallel to increase the current capacity, so we've got blue "send" or OUT let's call it, and black "return". The blue wire is connected to the + of the bottom strip. The - of that strip goes to the + of the one above and so on until the top one which has the - "output" connected to black return. I get around 170v on the blue wire of the PSU and this corresponds to the + pin of the bottom strip, so there IS something going there (not a dodgy connection). After the whole series, I get around 70v on the black wires....is this a PSU issue or is one of the LEDs failing ? I read another post where the chap indeed replaced the PSU....wouldn't really want to do that, so perhaps someone has had this issue and managed to fix it. No shorts on the PSU btw. The resistors are also OK (low value). I posted some pictures of the driver area. We're assuming the rest of the PSU is of no interest, since the TV DOES come on. Just a quick thought: every Samsung PSU I've worked on so far turns on the backlight by default when it's not connected to the main board....could this one be the opposite like many inverter-based TVs and actually require an ON signal applied to the BLU_ON pin to turn it on ? I highly doubt it, since there is voltage present on the strips...VERY strange.
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Samsung UE32eh5450 no backlight (LEDs OK)
    The IC on the back is a slc1012c which is apparently equivalent to FAN7340...
    Wattevah...
    • thoma
      • Sep 2012
      • 268
      reSolder the smps carefully especially the transformers
      take a hairdryer and coldspray is there a reaction on the smps?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Sounds like bad connection at strip connectors
        • thoma
          • Sep 2012
          • 268
          https://www.youtube.com/watch?v=KHBdZqGhMTg
          http://www.berlin-repariert.de/samsu...270-kein-bild/
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Nope sadly. I powered the strips at the connector with my variac and they turned on perfectly at around 110v...
            Wattevah...
              09-07-2024, 05:50 AM
            • sansanpartida
              Samsung QE82Q70RAT no backlight
              by sansanpartida
              Hi everyone!
              Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
              My issue: No backlight.
              Model: QE82Q70RAT
              Type No: QE82Q70RAT
              The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
              So hopefully, I can fix this cheaper.
              05-22-2024, 06:56 AM
            • Xristakis795
              samsung ue55ju6800 change backlight strip
              by Xristakis795
              hi to all i want to change the backlight strip on the above model
              do you know if there is someone helpful video with similar model whith mine ?
              thanks on advance
              04-18-2023, 01:17 PM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
            • Warrensmith
              Samsung BN44-00807E Low Backlight
              by Warrensmith
              Symptom is dim backlight - this set came in with almost no backlight.
              Samsung UN55JU6500FX2A
              1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
              2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
              Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
              10-27-2022, 07:09 AM
