Hisense 32K20DW missing LED voltages and 6 blinks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hisense 32K20DW missing LED voltages and 6 blinks
    150v is for the 40" size, Tv, this is the 32" so it will be 90v at start then 70 running.
    • steves7839
      • Nov 2014
      • 200
      No, no flash from the backlights. I can, barely, see the "Highsense" emblem with a flashlight.
      Has anyone tried wiring up a test backlight LED string? From other posts it looks like if even one LED fails open, the TV senses no current and shuts down.
      There is ~85V on the high pin LP, and less than 24 VDC on the LN pin. When I unplug the LED string LN goes to 0.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        So wait do you get brief Led voltage of about 90v ?
          'When I unplug the LED string LN goes to 0'
          How about LP without LED connected?
          If the meter is fast enough:
          85V- 24V = 61V Total Vf.
          61V/3V = about 20 LEDs, does not sound right for 32 inch panel, may be some of the LEDs are shorted which may have cause the original MOSFET to be bad in the first place.
          What is the panel model number?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8326
            You can capture this what budm asked easily with the min/max function of you DMM (if yours has that).
            • steves7839
              • Nov 2014
              • 200
              Are LED strips from a 40" Hisense the same length, so compatible to use in this 32"? I have a chance to buy a non-working 40".
              • steves7839
                • Nov 2014
                • 200
                I finally got up the nerve to open the panel and test the backlight strips. Two test fine on all LEDs with diode check. The third has two dead LEDs. I see a few incompatible strips on ebay. Where can I buy the little square diodes? Do you pros have a part number?
                The identical strips have several numbers. I've gotten hits for keywords E227809C but not for HE32VLEAK14010503847 , 1130209 or 89ma062L-B1.
                • steves7839
                  • Nov 2014
                  • 200
                  Persistence paid off!
                  I replaced the open LEDs with 3 types before I got one in that does not die instantly. And only 1mm thick like the originals. The panel has been all lit up for 15 minutes so far; I'm going for an hour before I put it back together.
                  In case anyone reading wants to try this repair, the led ic's that work are Digikey 1516-1050-1-ND AKA Brightek QBHP686-IWK-CW. An entire 3mm by 2.5mm by 1mm thick.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #29
                    Thanks for the update and glad the tvs repaired also with the new led fitted and the tv back together can you notice any diffrence in colour/brightness of the new led when watching the tv?
                      http://www.digikey.com/product-searc...1516-1050-1-ND
                      https://cdn.badcaps-static.com/pdfs/...28bd5c6399.pdf
                      Only 75mA max current, I hope you will keep an eye on them.
                      • steves7839
                        • Nov 2014
                        • 200
                        What is the least maximum current I should look for? I have 61 VDC lighting 18 LEDs.
                          300mA or higher.
                          • steves7839
                            • Nov 2014
                            • 200
                            K, thanks!
                            I ordered these:
                            MXA7-PW65-H001 Lumilite from Digikey. The 'working' replacements worked about an hour before one went out.
                            To Vince_Rodgers, The two replacements looked slightly yellower without any diffuser, essentially the same. I won't reassemble the panel until the LED strip works for an hour or more.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Awesomeness
                                BTW, you should also turn down the backlights level down to as low as possible.
                                • steves7839
                                  • Nov 2014
                                  • 200
                                  Here's a pic of the exposed LED strips powering 300mA smd LEDs. If these stay on a full hour I will put the panel back together. The color is a bit yellower than the originals, similar to the earlier replacements that lasted about an hour. But the LED is described by its manufacturer as "Luxeon Cool White 6500K 2SMD". Perhaps a better match would be obtained with daylight color, 7000K or so. I hope the filter panel will absorb the color difference.
                                  No more fault codes, at least!
                                  • rylos
                                    • Aug 2016
                                    • 1
                                    • usa
                                    #37
                                    The LEDS I've used in several LG & Vizio sets are # LATWT470RELZK, 400 ma., cool white. Several places sell them an Ali Express. I bought a lot of 500 for about $23. They were a drop-in replacement. Procedure I use is remove the light diffuser domes, being careful to number each one for location & orientation (if you don't get them back on just right, the backlighting will be blotchy). Remove original LED (I replace the entire set, in case others are getting close to failure), scrape coating off board next to the end that's more accesible (between two posts) heat both ends alternately with soldering iron while prying at LED with small screwdriver, LED will probably break apart into 2 pieces. Remove solder from board pads with soder-wick. Put a small amount of solder on the smaller pad. smaer a small amount of rosin flux on LED terminals. Melt the solder blob on the smaller pad while placing LED into position. Check for short, in case LED not positioned quite right. The diode test function on a DVM will probably make the LED glow slightly. If no short, then flow a bit of solder at the other terminal, making use of the scraped-off area of pad to halp conduct heat, the solder will wick into place under the larger LED terminal. Check again for short / light up LED. After all LEDs replaced, glue diffuser domes back on, taking care to position them as original. I use JB weld in a syringe, use new batch of glue every 15 minutes or so to maintain stickyness.
                                    • smalltownguy
                                      • 127
                                      • US
                                      #38
                                      Rylos, would you be willing to send me a handful of those LEDs? I'm in the middle of repairing a 32" Insignia TV that has a shorted LED and I'm not finding any local supplies of LED's easily. Unless you can point me to something maybe on DigiKey or Mouser?
                                        You have to make sure if the large solder pad of the original LED is Cathode or Anode which you have to match that with the replacement LED. otherwise the heat will not be dissipated properly to the strip.
                                        https://www.badcaps.net/forum/showpo...&postcount=282
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • lilo2400
                                          Sony PS5 EDM-020 MIssing voltages near HDMI encoder
                                          by lilo2400
                                          Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
                                          Thanks in advance
                                          09-02-2025, 03:58 AM
                                        • mat2k
                                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                                          by mat2k
                                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                                          12-01-2024, 11:00 PM
