HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
  • loser18
    • Nov 2013
    • 274
    Re: HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
    You should have 28V on pin 1 i think...check voltages on PR118, PQ18, PQ17 & PR127 PR129...
    • farrazi
      • Jul 2013
      • 11
      • Indonesia
      thanks for schematic and bios file.., JOOOOSSSSS GANDOSSS (ferry nice )
      • ryogadan
        • Apr 2012
        • 6
        • Italia
        where I can find PQ12?
        • loser18
          • Nov 2013
          • 274
          It should be around PU12...
          It's a high driving FET for CPU CORE voltage...
          If you won't find it I'll take a pic when I'll have a time...
          • osman458
            • Feb 2014
            • 1
            • turkey
            ec & main bios plase !!!
            hp part 650199-001
            daor13mb6e1 rev.e
            • loser18
              • Nov 2013
              • 274
              Osman...there's main BIOS dump,just check 1st page...if You won't get EC pm me & will upload (if I've got it)
              • atlas.tech
                • Feb 2015
                • 2
                • iran
                #27
                hi tank you for this suport
                • atlas.tech
                  • Feb 2015
                  • 2
                  • iran
                  #28
                  i want to reed kb9012 program plz hep me
                  • mohamedalepgig
                    • Nov 2014
                    • 6
                    • egypt
                    #29
                    thanks a lot
                    • angel-boy
                      • 550
                      • Romania
                      #30
                      i need bios file but my board is with en25f32 , kb3930qf is this programable ? , if yes, what can i use to read this
                      i found bios and ec, but i did not find ec i.c.
                      • bishnu
                        • Jan 2012
                        • 5
                        #31
                        chenge pu3
                        • Nasir Raja
                          • Mar 2014
                          • 21
                          • United Kingdom
                          #32
                          Thanks for sharing
                          • and555
                            • Apr 2016
                            • 36
                            • Indonesia
                            #33
                            Originally posted by loser18
                            Also checked PU9 pin9 & getting 3.25V - This is not right, is it???
                            It's ok.
                            ACIN mean active high, while high : AC power adapter plugged.
                            in other schematic there is ACIN# mean active low, while low : AC power adapter is plugged.
                            note: # mean active low.
                            Reflashed, but got no led however all pins read 3.3V except pin4...
                            , pin4 is GND.
                            BTW, did your problem solved.
                            • nts28
                              • Nov 2015
                              • 33
                              • türkey
                              #34
                              thankyou
                              • mesdova
                                • Oct 2015
                                • 24
                                • algeria
                                #35
                                This
                                • mbertaina
                                  • Jun 2016
                                  • 7
                                  • Argentina
                                  #36
                                  Also noticed that hex of your file is different so flashed it back with original dump & got led back on & BIOS voltages are OK...
                                  BTW mine is 4mb...
                                  ATTACHING MY DUMP, SOMEONE MAY FIND IT USEFUL, BUT PLS BEAR IN MIND THAT'S UNTESTED...
                                  hi everyone, i tested the bios dump posted by LOSER18 and his working fine!
                                  really thanks!
                                  • king ripper
                                    • May 2017
                                    • 6
                                    • russia
                                    #37
                                    hi, can anybody help with bios to hp 17-g132nw, is very hard to find, my laptop started to 0,31A, with dark screen, there is no tension on cpu coil, my mb:
                                    cpu: sr2eu
                                    mb: dax1admb6f0 rev: f
                                    gpu: 216-0864018
                                    kbc: it8987e - bxa
                                    laptop has flooded keyboard so i think that firmware on kbc is damage, so i need main and ec dump, thx for any help, i post my BIOS mayby somebody can check
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      #38
                                      If the fan spins and there is no CPU VCore, the BIOS shouldn't be the issue here. You would need to trace out why there is no CPU VCore.
                                      • boss juben
                                        • Oct 2016
                                        • 37
                                        • philippines
                                        #39
                                        thanks
                                        • enversefa
                                          • Oct 2016
                                          • 25
                                          • istanbul
                                          #40
                                          thanks
                                          • zlr8r
                                            Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01 - need all bios files checked
                                            by zlr8r
                                            hey guys,
                                            i have been working on for days a Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01.
                                            Doesn't Boot - only thing working is an LED flashing orange on/off, that's it
                                            - have tried cleaning the Main bios (ME region) which seems to have gone smoothly enough, and have re-soldered it back onto the board, but then I spotted an almost identical Bios chip near the EC on other side, but I don't know what is needed to be done with that bios ?
                                            - i have attached my original Main and EC bios's (they are both 32mb! chips)
                                            - i have...
                                            10-21-2025, 09:39 AM
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • Anooc7
                                            Samsung UN75NU6950 no backlight but leds works when checked individually!
                                            by Anooc7
                                            Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
                                            09-16-2021, 06:16 PM
                                          • lpraderi
                                            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                            by lpraderi
                                            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                            In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                            11-25-2023, 09:31 AM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
