HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
  • eniac22
    • Jun 2012
    • 124
    • Greece
    #41
    Re: HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
    I have the same board, i change the HDMI port but by mistake i lost the R786 resistor, is marked as *100/F_4 what this meaning? 100 Ohm 0402?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      #42
      Yes
      • tsounakas
        • Nov 2018
        • Ελλάδα
        #43
        i have the R13 Rev E
        Its turns on but i dont have signal on HDMI
        Evrithing looks Good
        Fun turn on and cpu it gets warm any idea what i have to check
        Thanx in advance
        • tsounakas
          • Nov 2018
          • Ελλάδα
          #44
          pl 25 1.13v
          pl 26 0v both sides somthing is shorted but where ?
          pq43 4pin 0v
          pl13 20v
          5volts seems ok
          19 volt allmost everywere
          electrlitic caps pc 246 ,pc254 ,pc 248 no volts at all... it looks like pq43 is shorted
          https://clip2net.com/s/3Y65VtR
          Can some one guide me to trace the line or what happent here?
          • antony.ag
            • Nov 2019
            • 59
            • Italia
            #45
            Hi, I'm new and it's just that I'm trying my hand at micro components. I hope someone can help me. I have the same card da0r13mb6e1 r13 by mistake I removed the component c26 and the component c20 ... I don't know which capacitors to put ... besides now the component pr 12 heats ... to specify that the card gave no signs of life no ignition no led ... who could help?
            • antony.ag
              • Nov 2019
              • 59
              • Italia
              #46
              I attach my motherboard
              Last edited by antony.ag; 11-28-2019, 10:59 AM. Reason: Cambio lingua da italiano ad inglese
              • Techtiger
                • Oct 2014
                • 1601
                • france
                #47
                Was the MB working earlier if no lights of on connector that means your adapter is not recognized by MB are you using 90W original HP adapter you have to trace back AD ID , what voltage you get PR158 CLR 19V ? And for the Caps put it back it doesn’t matter One side is GND are they supply
                • antony.ag
                  • Nov 2019
                  • 59
                  • Italia
                  #48
                  the mb previously funzuonava ... after not having used it for quite a while I went to turn it on but no sign of life .. I still have its original power supply but nothing ... no led ... that resistance marked with the red circle pr12 to the touch warms a lot ... regarding the capacitors can I leave it without? as for the value pr158 as soon as I have the possibility the text ... thanks a lot for the answer I will let you know as soon as possible
                  • KvnTM
                    • May 2018
                    • 434
                    C26 = 0.1uF / 10V
                    C20 = 220pF / 50V (Can be left unpopulated, just for EMI)
                    PR12 heats up? Measure resistance between the left side of it (side facing the chip) and GND. If shorted then remove PC16 and measure again.
                    Also resolder PC48. The soldering of it looks really bad. Just to prevent further issues down the line.
                    • antony.ag
                      • Nov 2019
                      • 59
                      • Italia
                      #50
                      pr12 seemed to be short and I thought I'd remove it to put another one but I can't find a 220 resistor of that small size ... can I put a 220 resistor with a bit bigger size by connecting it to the ends with a copper wire? ?? I enclose an example
                      • antony.ag
                        • Nov 2019
                        • 59
                        • Italia
                        #51
                        Example
                        • KvnTM
                          • May 2018
                          • 434
                          Sure!
                          What's the resistance of the old burned 220 ohm resistor ?
                          I don't think that the resistor would be shorted. Wouldn't really make a difference though.
                          Please measure resistance to gnd on both pads where the resistor was before.
                          EDIT: It is a 22 Ohm resistor. Not 220! I wasn't paying attention to the values... the first 2 digits are the value (22) and the 0 is multiplier. (In this case: 22*10^0 = 22 Ohm)
                          • antony.ag
                            • Nov 2019
                            • 59
                            • Italia
                            #53
                            I apologize, but the resistance was withdrawn and I lost it ... I apologize ��������
                            • KvnTM
                              • May 2018
                              • 434
                              Doesnt matter.. Just replace it with a 22 Ohm resistor (read my edit in last post) and you should be fine
                              Please do my measurements. There has to be a reason why the old resistor burned. Something is drawing too much current. Either the chip or PC16.
                              • antony.ag
                                • Nov 2019
                                • 59
                                • Italia
                                #55
                                do I have to first weld a 22 ohm resistor and then take the measurements or can I take the values even without resistance?
                                • KvnTM
                                  • May 2018
                                  • 434
                                  Without resistor in place please
                                  Put one probe on each pad and one on gnd. Screw holes most of the time have large gnd circles around them. Or use any metal case on a connector as gnd.
                                  • antony.ag
                                    • Nov 2019
                                    • 59
                                    • Italia
                                    #57
                                    ok i'll take the measurements ... i'm out of the office ... as soon as i'm back i'll tell you all the information you asked me ... thank you so much you're really kind i hope i can solve the problem ... thank you so much .. just I'll go back to the place I'll tell you everything
                                    • antony.ag
                                      • Nov 2019
                                      • 59
                                      • Italia
                                      #58
                                      should I take the measurements with the plug attached?
                                      • KvnTM
                                        • May 2018
                                        • 434
                                        Only measure resistance while the board is off. Always! Never measure resistance with a powered board.
                                        You're welcome. Just post your measurements when done.
                                        Are you going into the office today or tomorrow? It's pretty late already
                                        • antony.ag
                                          • Nov 2019
                                          • 59
                                          • Italia
                                          #60
                                          ehehe I hope as soon as possible ehehehe ... another question I wanted to ask you those capacitors that I removed I can leave them without or I'm forced to put them
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • Anooc7
                                            Samsung UN75NU6950 no backlight but leds works when checked individually!
                                            by Anooc7
                                            Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
                                            09-16-2021, 06:16 PM
                                          • lpraderi
                                            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                            by lpraderi
                                            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                            In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                            11-25-2023, 09:31 AM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
