Here I have an Apple Cinema Display 23" I bought. It was sold as non-functional and it was having this quite regular problem that the LED was blinking short-long-short, indicating a problem with the voltage input. Now, I have repaired several of these beauties and those which has this specific problem, a LM1117-3.3v voltage regulator was ALWAYS showing around 4v on the output... so, easy fix.
But not this time.... The LM1117 (800mA max) was outputting 4.059v as expected so I replaced the voltage regulator with a LM1084 (better power ratings = 5A max) as I normally do and the 3.3v is fixed but the monitor itself isn't detected when I connect the DVI plug to my computer. Normally the screen on the primary monitor flickers and there is a secondary monitor detected. With this screen nothing happens so I don't get an image either (Apple monitor only gives an image when it detects a signal on the DVI plug). This detection also works when the Apple monitor isn't connected to power, so only connecting the DVI plug must work.
Testing another identical monitor on the same DVI cable works, so it is definately the monitor itself which is at fault.
someone have a clue what to check?
