Sceptre X322BV-HD*XVNO5 blue light only
    Re: Sceptre X322BV-HD*XVNO5 blue light only
    Originally posted by weinernation101
    My voltage reading coming out of the T.RSC8.10B 12305 board going into the TV BACKLIGHT INVERTER BOARD - VIC91801.BZ seems to be good. My question is "what should my voltage be coming out of the VIC91801.BZ board (see pictured) pink & white wires?
    So you do have 24VDC feeding the inverter board but how about the BL-ON (INV-ON) and DIM signals? Fuse on the inverter board is OK?
    What are the numbers as printed on the barcode sticker?
    Do not try to measure the HV outputs unless you want to damage the meter.
    Are you working on the same make and model of the OP's TV?
    • Tomylee
      Nintendo 2DS XL – Orange light, no blue light, signs of overheating
      by Tomylee
      Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
      Here's what I've observed:
      All ribbon cables are properly connected
      Battery is present and in good condition
      No reaction even with screens disconnected
      There's a visible burn mark / overheating sign on the metal shield, right above the CPU
      I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
      06-26-2025, 02:33 PM
    • tom_h
      Sceptre X505BV, blue LED, no display
      by tom_h
      Hello all,
      I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
      and longer to come on, now it will no longer display any image. Original symptoms
      are the red standby LED would turn to blue immediately when pressing the power on
      button, but there would be a delay for the "SCEPTRE" image to appear on the screen
      and backlight to come on. The delay kept getting longer, then it would go from blue
      LED back to red. Then when I pressed the power on button again it would bring the
      display up and work fine....
      10-05-2023, 06:53 PM
    • blind2reply
      proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
      by blind2reply
      proscan 40ld45q
      Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
      After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
      No sound, no picture (used flashlight test).
      No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
      Digital voltmeter;...
      06-06-2021, 01:16 PM
    • TurboTundra
      PS5 EDM-033 Blue Light 2 Sec then Powers Off
      by TurboTundra
      Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
      The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
      Thank you for any input...
      06-10-2025, 08:51 PM
    • icareservicezone
      Synology DS918+ blue light blink
      by icareservicezone
      Synology DS918+
      Model name : GDI41L2
      p/N: 08-06GDI4116
      Version: V1.6
      Problem : blue light blink...
      05-24-2025, 11:53 PM
