Fiber Converter NMN-M19-CN100-S20SC Power Supply Dead
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    I've got a 100/100Mbps connection in my apartment, been real satisfied with it.
    It's connected to a Linux firewall acting as a router and WiFi access point.
    This Sunday morning it abruptly stopped working though, firewall reported that the NIC dropped the link.
    Only positive thing with the power supply was that it was held together with a screw.
    It has no S marking and not even a faked CE marking, only the CCC marking but that's only for China. It also has a SA mark but I think it might be fake.
    Especially seeing how they even managed to make the polarity drawing incorrectly, I mean really the whole PSU is a big short circuit!?
    Main cap had failed, managing to kill the fuse in the unit.
    After finding a new cap I went looking for a fuse but found a much nicer D-Link PSU with twice the capacity and all Japanese UCC caps.
    So I moved the cable over to that and installed it, now the fiber converter worked great again!
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Fiber Converter NMN-M19-CN100-S20SC Power Supply Dead
    Badcaps strikes again . And that is one shitty-looking power adapter! I'll give the manufacturer some credit, though - at least it has an input common-mode RF choke.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yea it really is crap, desoldered the secondary caps now too, they had started to fail as well, 0.15 vs 0.25 ESR in them...
      It's almost amazing how cheaply built it is, yet they still went to the trouble with some safety caps and filtering, it's puzzling!
      What's more puzzling is an ISP using this shit in their equipment, think how many unnecessary service calls and service visits it creates!
      I guess "a cent saved but a dollar wasted" is a logic they live by....
      • mariushm
        • May 2011
        • 3799
        The company making the fiber converter doesn't make the power adapter, they just buy it from a third party because they don't want to bother with certifications, approvals, ul listings etc, they're not a power supply company.
        In theory, they would pack the converter with a quality power adapter but some cheapen out.
        A few years ago when I moved into a new apartment, I was lucky to have an installer from the ISP that actually lived in the apartment building my apartment was in, so he was in a talking mood.
        I asked about the cable modem quality and what fails most often.. with those modems, he said the power adapters were the main cause of failure. But, with every box of 20 cable modems they bought, they received 24 or 25 power adapters in the package so they didn't care. If user was complaining, they came with new router and power adapter and replaced them on the spot, a 5 minute job, so it didn't cost the company much. At their service center, the old modems were tested and if good, put back in service to other customers.
        The new cable modems come with serious power adapters, they don't get hot so I think they'll last quite a lot.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          That is quite funny indeed.
          Definitely a candidate for the the gutless, bloated, and fried power supply hall of shame thread.
          Probably a decision made by the a manager or some bean counter rather than the engineering department at the ISP company. I've seen this practice a lot in IT as well. A power supply or battery for something dies, and the usual solution is to go online and buy the cheapest item that comes up first.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            So I borrowed a ladder from a neighbor to look at the fiber converter which the landlord had conveniently installed in the attic...
            All I could see was that mine was dead but my neighbors was working.
            Heard some noises from my attic yesterday, turns out my neighbors fiber converter had finally failed three weeks ago and a local electrical contractor was here replacing it
            Spoke to the guys that were here, they had a refurbished one from the ISP with them...
            They gave me the old failed one to have a look at, same 400v "XJ" bulk capacitor and same failure mode, who could have guessed
            They came back only an hour or so after having replaced it, apparently the "refurbished" one was not working.
            So they gave me that one too and guess what? Yea same cap failed again! Third's time the charm right?
            I took a look at some more of those he had in his car, at least a few had a redesigned PSU with more safety markings.
            They had removed the choke though so the credit momaka gave them needs to be retracted!
            I actually tried to locate the manufacturer of the power supply, on the PCB is written: 中山泽龙电子
            But turns out that is just a company that you can custom order PCB's from, i.e. not the real manufacturer...
            This time I also took a look at the PCB inside the fiber converter, it uses the same Chengx capacitors with no model marking rated for 105°C, 4x 100uF 16v 5x12mm and 1x 1000uF 16v 10x13.5mm.
            The small caps ranged in ESR between 0.35 > 0.80 while the large one in each converter was 0.1 vs 0.6 respectively, so one converters caps had degraded significantly more than the others.
            So we can conclude that at least low ESR caps should be used, but good luck finding an actual datasheet for these caps
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Well, I can't edit my post anymore, but I do (verbally) take all I said back .
              • mariushm
                • May 2011
                • 3799
                Well, the fiber converter looks OK.
                You have the input which is 5v, the voltage goes through D1 as a basic reverse voltage protection so the whole fiber converter will already see only about 4.3-4.6 volts (due to voltage drop on the diode), then you have the L1 inductor doing some small filtering and you have the big capacitor doing bulk energy storage and then the power goes into the linear regulator AIM 1084 something.
                That's an adjustable linear regulator, you can figure out the voltage based on the two small resistors above it (RP1 and RP2 in the picture).. basically the output voltage will be 1.25 * ( 1 + R1/R2).. My guess the output voltage for that linear regulator will be 3.3v or lower, because the linear regulator has an internal voltage drop of about 1-1.1v so at best the output voltage will be 4.5v - 1v = 3.5v
                Anyway, the point is that only that big 1000uF capacitor kinda has to have low esr as the energy comes from a switching power supply (the power adapter). The designers chose well a capacitor rated for 16v even though the connector is supposed to take in just 5v (so in theory you could use a 6.3v or 10v capacitor).
                If there isn't any other circuit using the raw voltage of 5v (you could check by following the traces from the connector) then in theory you could have powered the fiber converter even from a more common 7.5v DC power adapter but that has the potential to overheat the 1084 linear regulator.
                The linear regulator would have a relatively clean output voltage so there's no need for low esr capacitors after it, basically it makes no difference what you use after. In fact, some linear regulators actually need some ESR on the output, some regulators specify in datasheets that capacitors should have esr above 0.1 ohm or something like that.
                So basically don't rush to change those small capacitors on the fiber converter, the esr is normal for such small value capacitors and for how they're used in their circuit (to the best of my knowledge and limited analysis from the single picture posted)
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Thanks for your insight mariushm, I should clarify better what I meant in the conclusion of my last post.
                  One of the fiber converters had degraded more than the other, so what I meant was that I think the lower of the ESR readings I got;
                  0.1 for the big cap and 0.35 for the small caps is in the ballpark of what they should be...
                  I attached a new top-down picture of the unit, the linear regulator is an AIC 1084PM RP1 & RP2 are 100Ω each.
                  The converters PCB is designed to accept both SMD or through hole caps, and since the latter was used it's very easy to check the voltages without having to turn the PCB around
                  The large bulk cap has 5v across it.
                  CP3 & CP4 which are the two small caps near the input have 2.5v across them.
                  The other two small caps that are near the fiber connector have 5v across them.
                  The controller is a IC+ IP113C LF and it needs 2.5vdc
                  • Andreas_de
                    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                    by Andreas_de
                    Hello!
                    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                    04-12-2025, 10:38 AM
                  • kevin_allein
                    Samsung QE 75 Q 7 FGMTZG Power Supply dead
                    by kevin_allein
                    Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                    In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                    Does anyone have schematics for that board ?
                    Any good tip, what could be the issue ?
                    02-27-2025, 12:15 PM
                  • khalillll
                    maxipower 400W Dead power supply repair
                    by khalillll
                    The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                    After checking, I replaced the UTC7606D IC to restore the 5VSB.
                    I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                    Replaced it again with another UTC7606D.
                    Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                    After checking again, I think the issue was with the UTC7520D IC.
                    Replaced it with a WT7520.
                    Result: PSU fully working again
                    09-27-2025, 05:06 AM
                  • KYBOSH
                    Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                    by KYBOSH
                    I have a floodlight-security camera that recently died on me.
                    its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                    Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                    07-01-2024, 06:54 AM
