40" LCD Rank Arena (rebadge?) has standby, V+ seem OK, but wont turn on.
  • amacel
    • Nov 2013
    • philippines
    #61
    Re: 40" LCD Rank Arena (rebadge?) has standby, V+ seem OK, but wont turn on.
    hi masters... any progress on this thread, i have the same TV and also got the same problem... i wonder if this problem was solved? thanks.
    • Shane711
      • 493
      In reply to this topic. What if the PS board gets all the voltages with the inverter board not plugged in and the TV turns on, you can hear sound from the speakers. But when the inverter board is plugged in the power board will not power up and there is a pulse sound coming from the speakers every 3 to 5 seconds. I changed some of the caps on the power board and that seemed to make a difference because there was no standby voltage until I did change them. Also the 1 transformer on the inverter board that is smaller than the rest is reading low ohms, .366 and .666 where the others are reading 1.400 to 1.600 so I am guessing that one transformer might be bad. But I am still thinking the power supply could have another bad cap. There are three 2.2uf and three 1000uf I have not checked yet. What do you think?
        More likely to have shorted or leaky power MOSFETs that drive the inverter transformers.
        You need to upload good clear pictures of the inverter board.
        The inverter may be drawing too much current so it causes the 12V/24 power supply to go into shutdown restarting mode, since the 12V is used for the audio amplifiers that is why you are hearing pulsing from the speakers due to 12V is going on and off.
        BTW, you should stick to one thread with the correct model number instead of posting the same question on multiple threads, it causes confusion.
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • Crystaleyes
          Samsung BN44-00259A standby question
          by Crystaleyes
          Hi all.
          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
          08-11-2023, 05:15 AM
        • psssst
          Yamaha TSX 120 Standby Problem
          by psssst
          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
          03-01-2024, 07:25 AM
        • reessi
          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
          by reessi
          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
          Years ago it had some bulging caps...
          04-26-2021, 11:42 AM
