ps5 unable to access PSN
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i bought a ps5 board on ebay to experiment with. the console that it came from was suspended from psn and i was seeing if i could changed compoenents to get it connected again. I've replaced the bios and the wifi module and still no luck. Does anyone know how how to PSN identifies the console?
    • 31214
    Re: ps5 unable to access PSN
    unique id stored in the secure area,
    https://playstationdev.wiki/ps5devwi....php/Main_Page
    • kjchatman
      • Dec 2012
      • 213
      • united states
      it looks like there is information permanently stored on the internal SSD
      • gabri2211
        Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
        by gabri2211
        Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
        This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
        This NEXUS connector broke.
        Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
        The Xbox has a power supply that provides 12 volts on all outputs, so the power...
        07-28-2025, 07:13 PM
      • Syph1979
        PS5 EDM-031 1216A BIOS Issue
        by Syph1979
        Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
        I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
        I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
        09-25-2025, 05:48 AM
      • Peter Toropov
        GL702VM not charging/unable to power on
        by Peter Toropov
        Disclaimer
        This is my first time at attempting such repair and troubleshooting, so I apologize in advance if I do something wrong or misunderstand some things. I will attempt my best to research more information to better understand everything.
        Issue
        Laptop was unable to charge the battery, but was able to boot up without it, when powered on it had unstable CPU clocks while under load due to sudden throttling when reaching 70C. Upon visual inspection, a blown capacitor PCI8601 was discovered near MOSFET PQH8601, which has been replaced. The MOSFET...
        03-11-2024, 11:43 AM
      • KevinWysocki
        Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
        by KevinWysocki
        Hi there,
        My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
        At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
        After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
        Flash upgrade didn't seem to work,...
        08-20-2023, 09:45 AM
      • taso
        N. Switch HAc-10, no resistance on usb C 6 & 19 pin (D+), console not charging
        by taso
        Hi everyone:
        Anybody know anything about a N.switch without resistance in 6 & 19 pin (D+) in USB C conector? This is a HAC-10 board, all conector pins al good. Console runs ok but charging in very very slow 005 mAp.
        Thx!!!...
        07-15-2025, 12:37 PM
