i bought a ps5 board on ebay to experiment with. the console that it came from was suspended from psn and i was seeing if i could changed compoenents to get it connected again. I've replaced the bios and the wifi module and still no luck. Does anyone know how how to PSN identifies the console?
ps5 unable to access PSN
Re: ps5 unable to access PSN
unique id stored in the secure area,
https://playstationdev.wiki/ps5devwi....php/Main_Page
by gabri2211Hello everyone,
Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
This NEXUS connector broke.
Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
The Xbox has a power supply that provides 12 volts on all outputs, so the power... -
Disclaimer
This is my first time at attempting such repair and troubleshooting, so I apologize in advance if I do something wrong or misunderstand some things. I will attempt my best to research more information to better understand everything.
Issue
Laptop was unable to charge the battery, but was able to boot up without it, when powered on it had unstable CPU clocks while under load due to sudden throttling when reaching 70C. Upon visual inspection, a blown capacitor PCI8601 was discovered near MOSFET PQH8601, which has been replaced. The MOSFET... -
by KevinWysockiHi there,
My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
Flash upgrade didn't seem to work,... -
by tasoHi everyone:
Anybody know anything about a N.switch without resistance in 6 & 19 pin (D+) in USB C conector? This is a HAC-10 board, all conector pins al good. Console runs ok but charging in very very slow 005 mAp.
Thx!!!... -
Hi all, I'm newbie, i have a customer's laptop that is ASUS G733Q-RHG062T can turn on can charges, but unable to boot any bootable drive / usb , during boot just black screen only, tested different ram and different SSD still same problem. Any idea which part i can start diagnose?
- Loading...
