Asus x202e need bios dump.
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    asus x202e rev 2.0 , i need bios dump.. please help me..
    thanks in advance ..
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Asus x202e need bios dump.
    here the dump...
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      Originally posted by kazia
      here the dump...
      thanks a lot men,,,
      • vandehaai
        • Nov 2013
        • 24
        • Nederland
        thank you
        • bajinchi
          • Jul 2012
          • 14
          • Argentina
          Thank you!!!
          • katfish
            • Jul 2016
            • 76
            Older post. But thanks ... worked great here.
            • inter_cyber
              • May 2014
              • 8
              • turkey
              thanks
              • Watz
                • Sep 2014
                • 21
                • Kenya
                Thank you
                • bhuwan_vibha
                  • Feb 2016
                  • 10
                  • india
                  thanks...
                  • rein2017
                    • Jun 2017
                    • 35
                    • Philippines
                    • boss juben
                      • Oct 2016
                      • 37
                      • philippines
                      thanks
                      • x_menekse
                        • May 2016
                        • 11
                        • Turkey
                        very very thanks. its worked.
                        • fyaagoub
                          • Dec 2016
                          • 269
                          • maroc
                          very thanks
                          • casaba
                            • Apr 2014
                            • 25
                            • morokko
                            thanks
                            • fgh34
                              • Sep 2017
                              • 6
                              • Portugal
                              thank you very much
                              • enversefa
                                • Oct 2016
                                • 26
                                • istanbul
                                Thank you so much
                                • rager007
                                  • Feb 2016
                                  • 106
                                  • Usa
                                  Thank you so much
                                  • yasiu_kam
                                    • Nov 2017
                                    • 4
                                    • Poland
                                    Thanks man, everything works fine.
                                    • oman ame
                                      • Dec 2016
                                      • 4
                                      • indonesia
                                      thanks bro...
                                      • turgay
                                        • Aug 2016
                                        • 3
                                        • türkiye
                                        teşekkürler
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                          by DynaxSC
                                          I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                          The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                          Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                          Usually on ASUS boards it worked...
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
