ThinkPad T14 Supervisor password
  • 69d0b913
    • Mar 2018
    • 146
    • BR
    #121
    Re: ThinkPad T14 Supervisor password
    Originally posted by Maxpower3
    you lose your info when you flash the "Mec16XXX".
    may want to reprogram better before the info!
    instead of using the maintenance diskette
    give me 2/3 dump for compare
    yes, at least in T14 the information is lost, and it is necessary to write back using the LMU to repair.
    • 69d0b913
      • Mar 2018
      • 146
      • BR
      #122
      Originally posted by simkard
      So just to sum it up and be sure that I've totally understood how these new models are built/working regarding the supervisor password removal :
      After reading/writing MEC16xx chip with a blank/empty dump, there are some things that needs to be reconfigured.
      Technically, from my understanding, MEC16xx chip contains these informations (nothing else to declare ?) :
      • Machine type
      • Model Type
      • Country code
      • S/N / Serial Number
      • BIOS/Supervisor password
      • Computrace informations maybe ?
      While using the Lenovo HMD (Hardware Maintenance Diskette) v1.90, there are ways to fulfill these informations using option 20 or C0 and typing this sequency : 1STTTTMMMMCCSSSSSSSS which is composed of :
      • TTTT > Machine type
      • MMMM > Model Type
      • CC > Country code
      • SSSSSSSS > S/N / Serial Number
      So chronologically, steps would be :
      1. Solder wires on JTAG pins (close to the MEC16xx chip on the motherboard)
      2. Write an free from password dump of a MEC16xx chip
      3. Boot on the Lenovo HMD (hopefully no BIOS errors will be preventing from booting on an USB stick at that time)
      4. Use the option "20" or "C0" to fulfill the informations into the MEC16xx chip memory
      5. That's it ?
      Am I correct ?
      after doing the MEC16xx writing procedure the machine loses the information, so when using the LMU to write back, just writing some information fills the others, just start writing back the SN then the SN of the motherboard, vera that some other information will already be there, the UUID code is generated automatically by the LMU, that is, you only need to know the SN of the motherboard, the SG and the machine model, nothing more.
      • simkard
        • Jan 2022
        • 15
        • France
        #123
        Thanks for your precisions/details on that one.
        Anyway, couldn't find out what is behind the acronym "LMU" ; May I ask for your help on that ?
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1356
          • France
          #124
          have you many EC dump of differents machines ?
          information is cryted, but SER# is présent in bios and EC . it's a mirror map
          you need several dumps to compare(bios +EC)
          • evserv
            • Jun 2014
            • 362
            • Russia
            #125
            DMI information and password is stored in eeeprom. Only programmer Vertyanov can work with eeprom. That is, you read the eeprom, delete the password, write the modified eeprom back to the chip. After that, you have an unlocked laptop and all DMI information is intact.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              #126
              https://www.youtube.com/watch?v=Bt-sblFhxCM
              • cgtec
                • Feb 2014
                • 56
                • France
                #127
                the size corece of MEC1663 is 290K the program svod or vertyanov or rt809h can read just 288K or 256K ... the 4k have all information of laptop.
                • echow2001
                  • Dec 2016
                  • 45
                  just did a lot of t14 intel with rt809H programmer, use the provided pinout and solder jumper to the jtag. move the 10k resistor to enable jtag program and then dump EC memory, erase, write.
                  • echow2001
                    • Dec 2016
                    • 45
                    I've got the ryzen/AMD model of t14 gen 1 (board number NM-C801) on the way and apparently the pw also stored in EC ITE8300 and there's no JTAG connector. Can't find too much info on this chip online but RT809H seems to support programming it in circuit.
                    http://www.ifix.net.cn/thread-56902-1-1.html has some stuff on pinout
                    found this similar p/n online with more info IT8320
                    chromium OS source: https://chromium.googlesource.com/ch..._chip_it8320.h
                    https://chromium.googlesource.com/ch...il/iteflash.md
                    https://www.ite.com.tw/en/product/view?mid=96
                    • echow2001
                      • Dec 2016
                      • 45
                      Originally posted by echow2001
                      no JTAG connector
                      looks like this IC is programmed by parallel port interface rather than jtag, too many pin to practically solder, best to have breakout on keyboard zif
                      from datasheet of similar ITE embedded controller:
                      7.18.3.2 In-System Programming Operation
                      In-system programming takes place when VSTBY is supplied (other power is don’t-care) and both EC chip and
                      the flash are soldered on PCB. Parallel port interface occupies the same interface pins as KBS to use the
                      existing KBS connector.
                      IT8511 enters in-system programming mode if it detects parallel port signals when VSTBY power on or
                      hardware strap pin PPEN is pulled high. It can be disabled by OVRPPK/OVRPPEN bit in the KSICTRLR
                      register
                      If Parallel Port cable is detected by internal hardware strap, the following functions will be disabled.
                      1. ROM Address Match Interrupt
                      2. Internal/External Watchdog
                      will also have to see if the IT8300 uses internal or external flash for EC, if its external itll be ez just dump it with any 25xx flash tool like tl866ii, ch341a, rt809x etc etc
                      • andrew25
                        • Feb 2016
                        • 224
                        • Malawi
                        #131
                        what would be a "prom dmi utility" the EC has already been extracted and edited from the bios downloaded from the site.
                        can you share me the ec file please... its urgent
                        • b4rdock
                          • Jun 2017
                          • 106
                          • usa
                          #132
                          After a lot of persistence I was able to remove the bios password from T14! I believe that few here know how to do it and no one shares it, I understand that certain types of information are not shared and are sold! But I persistently come to inform you that the (Thinkpad T14 1st 20S1) was unlocked by an RT809H the only programmer I have. Here are photos in the attachment, now all that remains is to reverse the bios information, but I had taken a photo first of all.
                          after read mec , how you unlock the bin file ?
                          regards
                          • Verlengsnoer
                            • Sep 2016
                            • 110
                            • Netherlands
                            #133
                            Can someone unlock my t14?
                            i tryed the autopatcher but keeps flying away, and dont get any patched file,
                            hope someone can help
                              • 21998
                              Read through some of the previous posts, only possible via JTAG ,as far as i know.
                              • am123321
                                • Mar 2022
                                • 1
                                I am your companion in misfortune. Help me, please.
                                • onizzbox
                                  Banned
                                  • Nov 2018
                                  • 604
                                  • Brazil
                                  #136
                                  @am123321
                                  Not being money or solving the war in Ukraine, we can try to help them.
                                  • datodati962@gmail.com
                                    • May 2020
                                    • 48
                                    • alb
                                    #137
                                    Can you share more information about t14 Gen1 the way correct how to make remove supervisor password and how to read with rt809h,if is possible to be more specific,thanks!
                                    • simkard
                                      • Jan 2022
                                      • 15
                                      • France
                                      #138
                                      Any update on how to remove supervisor password in EC / ITE ?
                                      Pretty sure it's just a procedure similar to MacBooks with replacing "FF" to some region in the dump.
                                      Thanks !
                                      • simkard
                                        • Jan 2022
                                        • 15
                                        • France
                                        #139
                                        Hello 69d0b913,
                                        Is there any way to read the configuration before overwriting it using the HMD/LMU ?
                                        By the way, what is the difference between HMD and LMU ?
                                        • danito
                                          • Jun 2016
                                          • 1108
                                          • Romania
                                          #140
                                          Originally posted by onizzbox
                                          @danito
                                          Yes, for all Lenovo models
                                          How? Are you kind enough to tell me? I have TL866II plus. Does it work? What do I need?
                                          Thx
                                          • badzymandiaz
                                            Thinkpad P14s Gen 4, BIOS Supervisor Password
                                            by badzymandiaz
                                            I have a laptop that was purchased second-hand, and I am able to boot Windows on and extract the BIOS dump (ONLY the BIOS region, I was unable to dump anything else due to an FCERR I received trying to dump the other regions) and use normally. However, because the BIOS is locked with a supervisor password, I am unable to use anything else except for Windows, and it has also disabled some hardware features of the laptop itself, such as the fingerprinting module, etc. that I really do wish to use.
                                            I have been digging around for nearly 2 weeks trying to find any mention of the same model...
                                            09-28-2025, 10:49 AM
                                          • Andreasandreou
                                            Lenovo Thinkpad T14s GEN 4 Supervisor Password Bypass
                                            by Andreasandreou
                                            Hello, I have Lenovo Thinkpad T14s GEN 4 serial number GM-0FK2ER laptop. It was brought to me by a customer to reinstall windows. The problem is it is locked with a superviser password. Can anyone please give instructions on how to reset the bios or bypass the supervisor password? Thank you.
                                            09-02-2025, 09:45 AM
                                          • vijayppatel017
                                            Lenovo Thinkpad X13 Gen 6 BIOS Supervisor Password Remove
                                            by vijayppatel017
                                            i have Lenovo Thinkpad X13 gen 6. with supervisor password enable. anyone know how to remove it. as i am starting this thing first time so dont know. but i am good in solder.
                                            10-12-2025, 09:04 AM
                                          • Badpatch02
                                            Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                            by Badpatch02
                                            Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                            So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                            I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                            11-30-2024, 05:22 AM
                                          • AppleLover123
                                            Lenovo Yoga X380 22LH Supervisor Password removal
                                            by AppleLover123
                                            Hey guys,
                                            have a laptop here that has a supervisor Password (dump in Attachements).
                                            Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                            the laptop works but everytime it wants me to type a supervisor password i never set.
                                            I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                            Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                            04-17-2025, 03:42 PM
