Sharp LC-70le660u shuts off power light blinks
  • nwcs
    • Dec 2015
    • 311
    • usa
    I need some help on this one. Original problem was the backlight would flash then the power led would go out then start blinking a slow single blink. I now get it to turn on with a picture but when it gets past the sharp splash screen the tv shuts off like before and the single slow blink starts. Voltages are correct when the tv is on but I am not sure what they should be at PWM1, Dimmer and OFL. Any way looking at the picture it does not appear to have any bad led's so I think that is out of the question but I know these tv's are known for bad tab's but I am leaning towards a bad main board. Has anyone had any experience with this issue on these tv's.
  • nwcs
    • Dec 2015
    • 311
    • usa
    Re: Sharp LC-70le660u shuts off power light blinks
    I am back looking at this tv and would like to know if anyone can help with some voltages. I need to know what pwm1 and pwm2 should be as well as ofl. They all read 0V and I believe they should have some value. Also an update I did pull the panel off and tested the led's and they are all working.
      Can you provide the Voltage readings of all the pins?
      PWM can be between 1vdc~4VDC range. I do not know what OFL is.
      • budwich
        • Jul 2015
        • 3097
        disconnect one of the tcon cables (going from tcon to panel) and see what happens. Do the same "test" with the other. Go from there.
        • nwcs
          • Dec 2015
          • 311
          • usa
          Wow I never thought of that. I disconnected the cables to the panel from the tcon and it now lights up. I then hooked up each side separately and it would light up. I then connected both cables and it lights up for maybe 30 seconds then shuts off. I do not get anything to display though. And the one light error blink appears to be gone.
          • nwcs
            • Dec 2015
            • 311
            • usa
            Sorry, I talked too soon. It does display a picture and now it shuts off and gives the one blink code. I will try to reset it and see what that does.
            • nwcs
              • Dec 2015
              • 311
              • usa
              The voltages are as follows:
              pin 1 and 2 are 12v, pin 3 and 4 0v, pin 5 thru 8 13v, pins 9 thru 12 0v, pin 13 and 14 are 3v, pin 15 is 3.3v pins 17 and 18 are 0v, pin 19 is 3v, pins 19 thru 23 are 0v and pin 24 is 3v.
              • budwich
                • Jul 2015
                • 3097
                OK... I think... sorry can't follow your "observations"... maybe restate them.
                further when you have one side disconnected, is there a picture on the other side (feed some thing in or hit "menu").... do the same with the other side. Post pictures of your results if you see something.
                • nwcs
                  • Dec 2015
                  • 311
                  • usa
                  Yes there is a picture on the other side and when the picture comes on the tv shuts off and gets the one blink code. is is too quick to post a picture of it though.
                  • budwich
                    • Jul 2015
                    • 3097
                    ok... is the response the same for either cable disconnect?
                    I re-read your post / observations. With just one cable disconnected, does the tv stay on? Don't worry about connecting both at this point.
                    • nwcs
                      • Dec 2015
                      • 311
                      • usa
                      Yes the same no matter which side is disconnected. I think it stays on longer with both connected but not much longer. after the sharp logo it goes to what I believe is the multimedia logon and then shuts off.
                      • budwich
                        • Jul 2015
                        • 3097
                        you need to provide a better format for your voltage readings...
                        pin x voltage y ... label bl-on whatever.... people don't know what pins are what unless you tell them.
                        ... and when the readings were taken... ie. with display / after it dies / etc. In your case, you need to get them before the flashing code starts and then another set there after.
                        • nwcs
                          • Dec 2015
                          • 311
                          • usa
                          Sorry about that. Here they are
                          pin 1 and 2 pnl 12v, pin 3 and 4 gnd, pin 5 thru 8 ur13v, pin 9 thru 12 gnd, pin 13 ac_det3v, pin 14 ps_on3v, pin 15 BU5V, pin 16 pnl_pow 3.29v, Pin 17 pwm1 0v, pin 18 nc, pin 19 dimmer 3v, pin 20 nc, pin 21 ofl 0v, pin 22 error 0v, pin 23 pwm2 0v and pin 24 stb 3v.
                          • nwcs
                            • Dec 2015
                            • 311
                            • usa
                            Readings were taken when the display is on. I did not take the readings with the tcon disconnected. Maybe I should since it stays on longer. The voltages do start dropping when the flashing starts.
                            • nwcs
                              • Dec 2015
                              • 311
                              • usa
                              Thanks budwich for all of your help. The customer got tired of waiting so I no longer have the tv for testing. I just wish I could have narrowed the problem down. I am still pretty sure the panel is bad.
                              • BookWormStud
                                • Aug 2017
                                • 17
                                • India
                                I have the same problem but my TV is panasonic. In my case backlights are flashing ON and OFF. I did the flashlight test with backlight disconnected the Panel stays ON.
                                OP could have made the TV stay on longer if he could somehow be able decrease the backlight and brightness settings. That's what I did and now it stays ON with backlight flashing but TV doesn't go to standby.
                                If OP and Repliers could help me. I'd post more info about my TV.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  I would say you have bad led's breaking down under load
                                  • BookWormStud
                                    • Aug 2017
                                    • 17
                                    • India
                                    Is there any way to jump the wires and turn on the Backlights without giving any power Main Board. Cause I read somewhere you could but couldn't understand how to do it.
                                    Image shows the O/G post about jumping wires.
                                    I have the schematics for my TV if anyone could tell me I'd grateful.
                                    • nwcs
                                      • Dec 2015
                                      • 311
                                      • usa
                                      I hope this will help someone with the same problem I had. The customer brought the TV back to me to recycle and as luck would have it I had the same TV in with a broken panel. I replaced the main board from the broken screen tv and now the TV works fine. Thanks all who helped.
                                      • Elecfronicsssss
                                        DA0NJJMBAG0 charging light blinks
                                        by Elecfronicsssss
                                        Laptop motherboard DA0NJJMBAG0
                                        PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                        CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                        GUIDE ME WITH THE PROBLEM..
                                        SUMMARY-
                                        1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                        2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                        05-12-2025, 02:32 AM
                                      • mecha1166
                                        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                        by mecha1166
                                        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                        07-01-2024, 05:47 PM
                                      • roxboy1984
                                        Lenovo ideapad 3 no power, orange light blinks once when charger inserted
                                        by roxboy1984
                                        Hi guys,
                                        I wonder if anyone has encountered this. I have a Lenovo ideapad 3 that shows no signs of life except when the charger is first inserted the orange charge light comes on for a brief second and then goes off. There is no other sign of life and no fans or lights come on.
                                        if I check the voltage going to the battery it spikes when I insert the charger and then hoes back down.
                                        i tried injecting 2V but nothing gets hot. Any ideas? Im still a noob.
                                        Yesterday, 06:00 AM
                                      • kca
                                        Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                        by kca
                                        Hello all ~
                                        I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                        This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                        No picture. No sound.
                                        I tested all the voltages coming out of the power supply...
                                        10-12-2023, 05:23 PM
                                      • Alicat
                                        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                        by Alicat
                                        Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                        Model number is TH-50PZ85U
                                        Power comes on and the red power light stays on solid.
                                        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                        I also hear a few clicks.
                                        I also think my parents said there was a thunderstorm and the TV failed after that.
                                        Section 6 in the service manual talks about power and no screen,...
                                        10-30-2024, 10:09 AM
