Lenovo G560 LA-5752p NO Power No Light
  • torla
    • 76
    HI,
    Lenovo G560 LA-5752p rev1 2009-11-30
    NO Power No Light any solution
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Lenovo G560 LA-5752p NO Power No Light
    remove battery and memory module, try to power with other dc adaptor,
    if no result, take out the mobo check if there is 3/5volt
    this is the schematic diagram:
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      and you should try bios reprogram after checking for main system power...
      • torla
        • 76
        where to check 3/5 volt on bios or ...where?
        • Ramee
          • Jul 2014
          • 218
          • Israel
          On page 39 of the schematic
          • torla
            • 76
            I checked, no volts on BIOS
            • torla
              • 76
              ON page 39 v5 v3 v1.5 is ok..
              • polytek
                • Dec 2013
                • 496
                • TUNISIA
                backup your old bios and try to flash with this dump:
                • torla
                  • 76
                  did not help with flashin bios
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    if 3 and 5 volt alwon are present , then bios must be supplied with 3.3VALW
                    you say, no volt on the bios how ?
                    try flashing EC bios U3 with this file:
                    • torla
                      • 76
                      not help flash
                      pj10 3,3 V
                      pj12 5,1 V
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        what do you get at pin 7 of PU2? You should get 5v there. if not, replace the chip.
                        • torla
                          • 76
                          Thx for help pu2 is Ok.
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            voltage at pin 1 PU4A?
                            • polytek
                              • Dec 2013
                              • 496
                              • TUNISIA
                              if LID_sw# is low laptop can not power on
                              check this:
                              • Ramee
                                • Jul 2014
                                • 218
                                • Israel
                                Hi, did you fix it?
                                Remove the bios ic and check the pads if you are getting 3v, if yes, replace the bios ic.
                                • ghass
                                  • Apr 2014
                                  • 45
                                  • lebanon
                                  try to replace isl6251 ic
                                  • mehtabbukhari
                                    Lets help
                                    • May 2016
                                    • 26
                                    • India
                                    I Have similar board with different problem.
                                    After pressing the power button Power ON LED comes on and shuts down.
                                    After checking the M/B found that SUSP# is not coming from EC. I have already Tried flashing the EC.
                                    Any idea...
                                    • palady
                                      • Jan 2014
                                      • 21
                                      • si
                                      Also SUSP# = 0.Programing EC didn't help. CMOS battery reset solve the issue.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Any idea...
                                        Facing exactly this issue on the very same mobo. Anybody knows the solution??
                                        PS: cmos reset didnt helped. Bios(Main+EC) flashed but didnt helped. Powers up for 3 seconds and shuts down. No 3V VS or 5V VS. Alw present. +3v/5v VS line is not shorted though. SUSP# on pin 116 of kbc is missing.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
                                        • SoulFreeze
                                          Lenovo Slim Pro 7 14ARP8 83AX No Power
                                          by SoulFreeze
                                          Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
                                          Behavior - Pressing power button results in three second led blinks on the button,
                                          Connecting charger lights up orange as normally would while charging.
                                          Connecting charger without battery blinks orange.
                                          No fanspin.
                                          Tried flashing bios, no change.
                                          I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits...
                                          05-01-2025, 09:04 PM
