Hard drive failures in an HR20-700 HD-DVR - solved.
  • PlainBill
    • Feb 2009
    • 7034
    About 6 months ago I noticed a 'stuttering' during playback of recording on my HR20-700 DirecTV DVR. Since I had upgraded the internal drive to a 1 Terrabyte drive 3 years ago, I had assumed the replacement drive was developing problems. The replacement drive was full, so I elected to upgrade to a 2 Terrabyte drive. Initially, that worked well, but after a few months the problem resurfaced. At this time I took a closer look at the power supply area and realized that the drives weren't dying, they were being killed!! Note the three caps on the right in the picture.
    A closer examination showed the caps were United Chemi-Con KZG series. Since UCC's KZG series has been 'problematic', I ordered Nichicon HM series from Digi-Key. After replacing all 5 KZG caps I found the two in the signal processing area were fine, reading 0.01 on an ESR meter (spec is 0.013). However the three in the power supply area were 'slightly' out of spec. One read over 100 ohms, the other two were in the 80 - 90 ohm area.
    At this point the DVR has been working well for over a month.
    PlainBill
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Hard drive failures in an HR20-700 HD-DVR - solved.
    And thus the oft asked question 'can bad caps damage a hard drive' is definitively answered.
    Thanks for the report.
    Mann-Made Global Warming.
    - Dr Seuss
    • japlytic
      • Oct 2005
      • 2086
      Talking about the often asked question, damage can happen if a unmonitored rail goes dangerously high.
      This happened in a PVR I have handled too.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        your old drives may be ok.had a noname chinese dvr here with 5 hdd's marked bad.
        the real problem was caps but it was locking up with "hdd possible fail replace"on the screen.engrish preserved.
        the owner thought the footage of someone trying to turn the place into a drive through was gone due to a bad drive.much to the dismay of the punks in their dads pickup i got the drives going in it and exported the attempt including good face shots and the plate!
        imagine the look on their faces when the cops show up 6 months later to serve a warrent!
        • PlainBill
          • Feb 2009
          • 7034
          Not a chance on the 2 Tbyte drive. Even the WD diagnostics couldn't reallocate the bad sectors.
          PlainBill
          • Toasty
            • Jul 2007
            • 4171
            HDD Regenerator
            Has fixed many a "bad" drive.
            A 2T would likely take 7-10 days 24/7 depending on how much is truly "bad".
            veritas odium parit
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by Toasty
              HDD Regenerator
              Same experience with Active Killdisk.
              When a drive has other problems sectors that aren't bad can get marked bad.
              The drive won't recheck them later even with most HDD diagnostics.
              Those two mentioned products ignore and overwrite 'the bad list' along with the whole drive [every bit] including the MBR and partition tables.
              That forces the drive to create a new list of bad sectors from scratch.
              Sectors that were erroneously reported bad earlier are restored to use.
              [That isn't the program's goal, it's a side effect.]
              Obviously it won't fix all drives but I've had something like a 75% success rate.
              I also have not had issues with drives 'fixed' that way 'breaking' again later.
              Killdisk more or less does a 'once-through' by writting every bit once, which is enough to cause the firmware to recheck previously marked sectors.
              [If I remember correctly a 1TB drive takes like 12-16 hours.]
              If your goal is to try to fix -actually- bad sectors then HDD Regenerator is the way to go.
              It works by being extra persistent with those that don't want to play [read/write] immediately and by witting each bit more than once.
              That's why it takes so much longer to run.
              Western Digital's 'wipe' function -might- achieve the same thing but I don't trust it to -actually- wipe/overwrite every bit like Killdisk does.
              - Convenient example:
              I'm on the ancient 'kitchen system' right now.
              2 or 3 years ago the RAID card decided one of the drives was bad.
              Pulled it, ran kill disk on it, put it right back in the array.
              The array rebuilt it and not a problem since.
              - Dr Seuss
              • lti
                • May 2011
                • 2549
                I guess I was lucky to just have a really high Ultra ATA CRC error rate on a hard drive that was in an unstable computer. That drive has no bad sectors.
                My parents' DirecTV DVR has always been unstable and is almost full, but I am not going to take it apart. It needs to be reset once a month because the sound or video will start stuttering (even during live TV playback) or it will stop responding to the remote (pressing any button causes the "invalid entry" sound to be played).
                • Toasty
                  • Jul 2007
                  • 4171
                  Isn't Active KillDisk just for wiping though? I just read their site and I don't see anything about preserving the data...?
                  HDD Regenerator does -not- overwrite or destroy data. It will, as pointed out, try to read a sector for an extended time and rewrite the info back to the sector. It runs on the drive before any OS loads and does not care how the drive is formatted, same as AKD. As with AKD, it's low-level.
                  Available at your local "heavy-downpour" site in both diskette and CD ISO images...
                  veritas odium parit
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Yes it wipes it. Writes all zeros.
                    Has other functions I've never looked at.
                    I thought it alternately wrote ones and zeros until the sector was responsive.
                    An 'exerciser' so to speak.
                    For data recovery I've used Ontrack Easy Recovery Pro - because it doesn't attempt to write TO a bad disk.
                    Once I have what I need off of it I wipe the drive with killdisk and then test it.
                    Haven't had a need to do data recovery in a very long time because anything that important is on RAID now.
                    - Dr Seuss
                    • Toasty
                      • Jul 2007
                      • 4171
                      Here's the info on the 2011 version (which I just d/l'd):
                      http://www.dposoft.net/hdd.html
                      Now makes a bootable Flash drive too. Nice
                      It also claims to have what appear to be some nice improvements. One's I see that look to be promising are the prescan mode, faster scanning speed, and process resume except from CD/DVD. (Must need to write where it left off.)
                      Toast
                      veritas odium parit
                      • federalhouse
                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                        by federalhouse
                        Hi everyone,
                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                        **Background:**
                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                        **What I've Tried So Far:**
                        1. I accessed
                        08-01-2024, 07:03 PM
                      • madura2010
                        DAY11AM6E0 hard disk drive and optical disk drive not detected
                        by madura2010
                        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                        i checked the connectivity of ribbon=good communication with hard and motherboard
                        changed hard disk and checked=3f0 error persist
                        sata power=+5v available
                        Then checked data capacitors=all good
                        Then checked data lines path connectivity to pch=all good
                        reflashed...
                        03-12-2023, 09:09 AM
                      • ash91
                        Hp pavilion 15 not detect hard drive
                        by ash91
                        Hello gentelmen .... this is my first post and sorry for my bad english,
                        so my proplem is my laptop keep losing hard drive even if i but the
                        hard disk in the cady (the box that can replace the dvd rom with hard disk)
                        when i turn the laptop on the massage that said no boot media found pop on
                        the hard disk is fine and to be sure i try another hard
                        i also update my bios to the last update
                        the 5 volt is present on the hard connector on the motherboard
                        the dvd rom work fine when i but a windows dvd in it
                        also when i boot from flash...
                        06-07-2023, 01:45 PM
                      • ChaosLegionnaire
                        bug of the month: write caching setting for the hard drive in device manager
                        by ChaosLegionnaire
                        i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                        so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                        10-06-2019, 01:39 PM
                      • karto95
                        Repairing a Seagate hard drive with damaged logic board
                        by karto95
                        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                        If anyone has any suggestions or experience with this...
                        03-21-2023, 04:05 AM
