Emerson LC320EM2 not powering up
  • aasnowskate
    • 118
    • usa
    I have an Emerson LC320EM2 that will not power up. No LED or anything.
    I purchased a power supply replacement kit that had a resistor, 2 diodes, a mosfet and a transistor.
    The problem I found was that Diode D607 was shorted and when I would replace it, it would keep shorting.
    the kit I used included:
    D607, D610, D604, D640, Q601, Q600, and R608.
    After replacing all these parts, I am still having no power, no LED.
    Also D607 and D610 are shorted again.
    Has anyone seen this before or have any suggestions?
    Thanks in advance for any help.
  • aasnowskate
    • 118
    • usa
    Re: Emerson LC320EM2 not powering up
    here is a pic of the board and a close up of the power supply part of the board.
    • JimmysTGP
      • May 2012
      • 45
      • US
      I ran into this train wreck last month. and the only conclusion I made is not the one your looking for, I never found the true problem, so I tossed it. Got to be to much time invested for such a small set. I replaced everything that I could find defective and still no power, same as yours it kept blowing the zeners. Sorry I couldn't be of any help.
      • aasnowskate
        • 118
        • usa
        Thanks for the reply. I think that is the road I am going to end up taking. I can't find the exact board replacement and everyone I talked to said you have to have the exact board replacement for this power supply.
        • kevinm34232
          • May 2012
          • 1884
          I successfully did one of these very similar models, it was a Sylvania and the parts I replaced were very close to yours but some more. Check to see if you have a D640 on the bottom of the board, it's an SMD diode and was bad on mine, I beleive causing same issue.
          • aasnowskate
            • 118
            • usa
            I have replaced the D640 diode. It was in the kit i had ordered. Still not powering up.
            • kevinm34232
              • May 2012
              • 1884
              Heres a list of what I replaced
              Q600 - FET MOS TK10A50D - Mouser
              Q601 - TRANSISTOR 2SC2120-Y(TE2 F T) - Ebay
              D604 - DIODE ZENER 27BSB-T26 - Part # 568-5893-1-ND
              D607 - SWITCHING DIODE 1SS133(T-77) - Part # 1SS133T-77CT-ND
              D640 - DIODE SCHOTTKY SMD SK2B-TR - Part # SS210-TP
              R602 - CEMENT RESISTOR 5W J 2.2 OHM H 10MM - Part # 280-CR5-2.2-RC
              R605 - RES CARBON FILM T 1/4W J 220 OHM - Part # 291-220-RC
              R606 - RES CARBON FILM T 1/4W J 180 OHM - Part # 291-180-RC
              R608 - METAL OXIDE FILM RES. 2W J 0.18 OHM - Part # PNP300JR-73-0R18
              R611 - CEMENT RESISTOR 5W J 2.2 OHM H 10MM - Part # 280-CR5-2.2-RC
              F601 - 4A /125V SLO Glass 5x20MM Fuse - Part # F3594-ND
              • sansonet
                • Nov 2013
                • 236
                • US
                I just fixed 32" Emerson TV and it had the same problem. Thanks to this forum and advises here and in another long thread https://www.badcaps.net/forum/showth...t=25477&page=6
                I was able to do it without ordering parts because I already have not working 19" Emerson and found two of those on it's board. One tested with beeps using diode/ continuity tester, the same as one on board from 32", and another one not and had readings that appeared to be correct. So I used it to replace one on 32" board and it came back to life. Now I want try to fix that 19", but I will need two of SK2B since I removed one and another one appears to be bad too. I found them in this listing http://www.ebay.com/itm/5pcs-SK2B-EI...-/171118518069 and another one when I use part number in search SS210 http://www.ebay.com/itm/20pcs-100V-2...-/181155902148
                I just not sure if second listing is correct part? It's is cheaper so I prefer buy those if they are the same.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8330
                  Repaired one of these Emerson TV's today, so saved another one from the junk pile: I used parts I already had on hand and had to cheat a little.
                  Q600 TK10A50D shorted, replaced with K2698 (had to bend the legs and drill new hole through the heat sink and added isolation mat)
                  Q601 2SC2120 open, replaced with 2sc5344
                  D604 27BSB shorted, replaced with 1N4749 1W 24V
                  D610 1ZB36 shorted, replaced with 1ZB43 43V
                  D640 SK2B shorted, replaced with FR207
                  R608 2W 0.18 OHM open, replaced with a 0.18Ohm 5W cement resistor
                  F601 4A /125V SLO open, replaced with same
                  Got another working TV!
                  • Dmaltz
                    • Aug 2013
                    • 2
                    On my model R605 & R606 were both 120 ohms.
                    Since D640 appears to be the cause of all the other components going bad I decided to use a schottky diode with greater current capacity to avoid another failure. Digikey had one that handles 5 amps rather than 2. Their part number is SB5100DICT-ND.
                    This is a through hole diode so I carefully drilled a couple holes through the circuit board and installed it from the top. So far so good.
                    • art_dodger
                      • Nov 2013
                      • 18
                      I just repaired one of these as well. What a bloody nightmare!
                      Initially purchased the typical repair kit, replaced 12 components, promptly re-blew Q600, Q601, D604 & D610. Problem child turned out to be D640. (It wasn't initially obvious because everything else was on the cold side.) I finally ended up pulling T600 from the board just to circuit-trace and tracked down a shorted D640. Re-replaced blown stuff, *poof*, I was finally able to call my customer for pickup of a working TV.
                      A little trick when trouble-shooting this board - I lifted a leg on R605 to isolate and traced with voltage measurements. Surprisingly, the schematic for this set is quite good, with reference voltages, etc.
                      No real new info here for anyone I guess... I was just so excited about finally getting this set out of my shop, I had to tell someone! :-)
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8330
                        On these TV sets, D640 is what causes the problem. So I hope you did upgrade D640 with something beefier. I had the FR207 originally in there, but I did take it out again and used a 4A 200V diode instead. This TV that I repaired is still running to date.
                        • culcuhain
                          • May 2016
                          • 186
                          • U$@
                          Got another one of these this week. Ordered the shopjimmy kit. D640 is the culprit. Both sets. Easy fix.
                          • Carlos tce
                            • Sep 2020
                            • 1
                            • Mexico
                            friend Could you help me I have the same card the same problem that no electrical current comes out and I would like to know who can help me to detect the voltage output how much voltage should I reach the regulator and from the regulator to the cold card because I do not know how much voltage must handle or must reach the regulator so that this regulator feeds the cold card I need help because I already rectify everything that would be my friend's list here below and replace all the parts but not yet I do not have cold current in The cold card I do not have power and this I would like to know who can help me with this detail because this time I am going to send you a photograph so that you can see How it is In what state is my card and the specific area where I would like to know if someone Can you help me with a diagram or something to identify the electric current lines, what would be the value of each line? Thanks
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8330
                              Here is the service manual. BTW the TV i repaired is still going!
                              • valvashon
                                LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                by valvashon
                                The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                11-24-2024, 12:08 PM
                              • DarKHawK
                                Asus 2021 ROG Strix G17 G713 not powering on and not charging.
                                by DarKHawK
                                I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
                                When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
                                07-11-2025, 05:24 AM
                              • serious_electron
                                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                by serious_electron
                                Hello Everyone!
                                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                06-28-2025, 02:57 PM
                              • ShadowAi12
                                ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                by ShadowAi12
                                I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                • The board enters a "ready to power on" state after plugging in the PSU.
                                • Pressing the power button increases power draw.
                                • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                Measurements:
                                (taken after pressing the power button, while the board is attempting to start)
                                • H_SKTOOC#
                                06-11-2025, 01:05 PM
                              • TechSplendid
                                MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                                by TechSplendid
                                Hi All,
                                I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                                Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                                04-09-2025, 02:13 AM
