E470VA Flickers
  • rogmiller
    • 15
    E470VA Flickers
    I have a E470VA Vizio that about every 16 seconds looks like it winks at you. Picture goes in then out. I have replaced TCon , Main , Power Board someone said could be a bad panel. Is there a way to test inverter to see if it could be problem.
    Re: E470VA Flickers
    I've heard of this being a software problem...
    • rogmiller
      • 15
      Re: E470VA Flickers
      I work on tv"s but did not find any software updates
      • rogmiller
        • 15
        Re: E470VA Flickers
        Here is video of problem i replaced main board so software should not be problem.
        http://youtu.be/_TA-eLfNOY4
        • awyatt2
          • Feb 2012
          • 407
          • america
          Re: E470VA Flickers
          roger, it is dewey the one with the sanyo mainboard. from what i know about these displayswhen they go bad they leave stripes or bars. budm would be the one to ask. he seems to be the resident expert on led/lcd tv's. i have tinkered with and fixed a few and as you well know i have one here in my storage building with a bad main. was the main you replaced new or used? and does it do the same with both boards? if you want to try either main in the one i have you are welcome to do so. would have to be in the morning or on sunday, have to work at 4:00 till midnight. this one lights up dut dosent even render the vizio logo.
          • rogmiller
            • 15
            Re: E470VA Flickers
            ok would like to try panel because seems like backlight never goes out. So i think its panel did you find out if guy would part with panel. I do not want to spend much it is a risk still may not work. May try main in yours see what happens. I tried inverter you gave me still the same. Tv was having problem from start replaced Main and power first refurbished boards im sure but problem was same next we replaced T-con still the same. Then i tried inverter got from you still does same thing.
            • awyatt2
              • Feb 2012
              • 407
              • america
              Re: E470VA Flickers
              roger you may have gotten a bad main. i got one once for a hitachi that was supposed to be good but it was bad. i spent more than i got out of it because of the bad main. every board in it was replaced, and the main was first. after a total 360 inside i let it sit for awhile. ran across a junker and when we changed the main it was perfect.have not gotten in touch with tony because he was out of town visiting his parents. wont be back before sometime next week. they live in detroit and i dont have a number for them.
                Re: E470VA Flickers
                It looks like the T-CON board is getting the voltage that comes and go, and the backlights do stay on and did not go out from what I can tell from looking at the YOUTUBE. You can monitor the voltage at the T-CON fuse to see if it has either 12v or 5v on the fuse when it acts up. The T-CON voltage is fed through a switched transistor which is turn on/off by the main board micro controller, the voltage is turn off when TV is in standby or when TV is powered down.
                • rogmiller
                  • 15
                  Re: E470VA Flickers
                  ok i will check this weekend and see if voltage is 12v or 5v and post thanks
                    Re: E470VA Flickers
                    Some T-CON uses5v to run, some may use 12v to tun, but the bottom is we are looking to see if the voltage comes and goes when it acts up.
                    • rogmiller
                      • 15
                      Re: E470VA Flickers
                      K this model connects from main to sub main to tcon.
                        Re: E470VA Flickers
                        Right now pictures would be really useful.
                        • rogmiller
                          • 15
                          Re: E470VA Flickers
                          I will try to get pics up.
                          • rogmiller
                            • 15
                            Re: E470VA Flickers
                            here are pics i checked for voltages seen small change like 1 volt now tv gives backlight but no menu.
                              Re: E470VA Flickers
                              So what voltage do you get at that white fuse on the T-CON board?
                              • rogmiller
                                • 15
                                Re: E470VA Flickers
                                On fuse of T-con i get 11.88 then flickers voltage goes up 11.94.
                                • rogmiller
                                  • 15
                                  Re: E470VA Flickers
                                  Originally replaced main but seems i must have got bad main. replaced main again now TV plays beautiful.
                                    Re: E470VA Flickers
                                    Thanks for the repair feedback, glad to hear you got it working.
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                    • SS454
                                      vizio e650i-a2 backlight flashes then turns off
                                      by SS454
                                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                      panel: au optronics T650HVN05.4
                                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                      08-20-2020, 03:57 PM
                                    • mrtek
                                      Vizio M65-C1
                                      by mrtek
                                      Hi.
                                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                      07-14-2025, 07:28 PM
                                    • howardc64
                                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                      by howardc64
                                      Failure Symptom
                                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                      Where is the short?
                                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                      05-27-2025, 02:56 PM
                                    • howardc64
                                      Vizio SmartCast TV software bug that looks like hardware
                                      by howardc64
                                      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                      11-16-2024, 05:17 PM
