Vizio E371VL Dead Lightning
  • Ltank
    • Jun 2013
    • 776
    Well the set was dead. Power Supply was a 0500-412-1020 No Orange Vizio label on front, No 5vdc stby voltage. My first step was to find a Service Manual, found one but no schematic was included. So I checked all the diodes, transistors, transformers and caps in the HOT section. Had 165 vdc output on the Bridge Rectifier no 380v from the Boost circuit. I did not have any of the variations in the SMD parts normally associated with it, but I did have a Q0465R Resonant Power IC. (U101) I happen to have one in new spare parts kit, so I put it in. Then the power supply developed 5v stby was tested, then I put the board back in the set and it all came bac to life.
    I put this post because I saw alot of post about EEPROMs and other parts but none with this part for this model tv or power supply. I thought it might help others who do a search when trouble shooting sets that use this power supply.
    Re: Vizio E371VL Dead Lightning
    Great work, you are lucky that the surge did not go through the HDMI ports which I seem to see lots of them lately.
    • cooltallchick
      • Feb 2014
      • 3
      LTank I am greatful for your post. I moved my TV to a different plug for a video game tournament and didnt plug it up to a surge protector, lucky me that night there was a storm and the lights went out, when they came back on I believe the power supply was blown. Or at least that is what I gather from all of the research I have done on different forums. Is this similar to what happened with you?? Is this something that a person with limited knowledge of electronics could fix themselves???
      • Ltank
        • Jun 2013
        • 776
        It has a screw to a heat sink on power supply. Remove screw then tin the tip of soldering iron to help transfer the heat. Get some solderwick then put wick on solder joints then use iron to heat the wick. You should see the old solder wick up into the braid. Be careful
        Not to damage the traces. That part I got from mouser $1.65 . It has 5 leads that need to be soldered. Look at U-Tube to see how to use wick to unsolder and to resolder. Keep part in protectve antistatic bag then ground yourself prior to soldering.
        In my case there was no 5vdc standby voltage. If you have it with chassis ground reference this will not fix your set. You have other problems
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • kevin_allein
          Samsung QE 75 Q 7 FGMTZG Power Supply dead
          by kevin_allein
          Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
          In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
          Does anyone have schematics for that board ?
          Any good tip, what could be the issue ?
          02-27-2025, 12:15 PM
        • KYBOSH
          Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
          by KYBOSH
          I have a floodlight-security camera that recently died on me.
          its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
          Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
          07-01-2024, 06:54 AM
