sanyo dp42740 no startup no powerlight
  • awyatt2
    • Feb 2012
    • 407
    • america
    anyone got a manual for this tv, only a little over a year old. voltages are not marked on ps. darfon powersupply, good news is a pabnasonic screen. no relay click when you try to start it only when you plug it in all fuses ok, all caps check out good,all diodes, resistors and the mosfets check ok. thinking maybe digital board but need sm to confirm.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: sanyo dp42740 no startup no powerlight
    What is the voltage on the PFC capacitor in the power supply?
    Does the power supply have the correct output voltages?
    Muh-soggy-knee
    • awyatt2
      • Feb 2012
      • 407
      • america
      yes the power supply is working it has all voltages as it should it's hung in on with no video i need the print on the mainboard.
        But what voltage do you get on the PFC cap? We need that number to know if the PFC Voltage booster is working or not.
        • awyatt2
          • Feb 2012
          • 407
          • america
          bud the power supply is working all the voltages are there, where they should be the tv is stuck in on position. when you plug it in it tries to start up went sour while i was out and took some other board out. get a dim glowing screen no pic all voltages are where they should be. this one is under extended warranty and hasnt made a year yet. i would have attemped repair if i could have found a service manual and dont think the manual is out if so no one has it. lest none of the pay sites do. this one is not power supply, leaning toward main board, i will know tomorrow service man will be here.
          • awyatt2
            • Feb 2012
            • 407
            • america
            confirmed control board or panel, tech just left. extended service contract paid off on this one. anyway i have it to play with.only wish i had the print on the cntrl board so i could really get it fixed. it is surface mount but no bga arrays on it.
            • Scuse
              • 50
              When you say the control board was the problem. Is that the same as the logic board? Also does yours have the analog and digital tuner boards separate but connected? That's how mine is set up
              • johnboy1313
                • Nov 2012
                • 1959
                awyatt, did the new control board fix the problem? I have the same set with the same issue.
