DFI-ITOX G4S600-B with Chemicon KZGs - compatible caps?
  • jesscat606
    • Feb 2015
    • 18
    Hey guys,
    I've got a G4S600-B (this board) that has about 2 dozen UCC KZG caps on it. This is in a digital audio encoder used at a radio station, so it's been on/powered pretty much 24/7 for a number of years. recently it's been getting flaky, so I pulled it apart and noticed that 7 of the 16 1500uF caps on the board are bulged. Did some more research, (signed up for this board!) and find that the KZGs are pretty much despised here.
    So I'm looking to recap the motherboard. The KZGs on it are all 6.3V, 105degrees:
    1500uf 8x20mm marked 5(7) 7S- 10
    1500uf 10x20mm marked 6(7) 6G - 4
    1500uf ~10x12mm marked 6(k) 8E - 2
    470uf ~5x11mm marked 5(k) 6c - 3
    470uf ~5x11mm marked 5(k) 6V - 3
    I'm assuming that I ought to replace the 470uf caps too?
    (EDIT: looks like all the rest of the on-board caps are Nichicon HM(M) or OST RLG)
    I'm looking through Digikey, most of what I'm seeing is Nichicon/Panasonics/Rubycon. I'm not very knowledgeable on ripple currents, esv, etc., so I'm hoping someone on here can help me out with some compatible replacements. Here's where I'm looking:
    I've never seen a MB with this many popped caps!
    Thanks guys,
    -J
  • trshaner
    • Feb 2015
    • 2
    Re: DFI-ITOX G4S600-B with Chemicon KZGs - compatible caps?
    The Panasonic FR series is a good choice for switching regulator applications such as on this motherboard.
    Just make sure the diameter and lead spacing will fit and the same or higher working voltage.
    There is a known issue with the Chemicon KZG capacitors. More info here:
    https://www.badcaps.net/forum/showthread.php?t=30329
    Ripple current and high-ESR is what caused these caps to fail.
    • lti
      • May 2011
      • 2548
      Nichicon HM series is a direct replacement, and HN and HZ series have lower ESR. I think any of those three series would work.
      The 470uF caps in the second picture are KY series, which don't need to be replaced.
      Are you sure they are all rated for 6.3V? The larger 1500uF caps might be rated for 16V.
      • trshaner
        • Feb 2015
        • 2
        Along with low ESR you want a capacitor with a high Endurance rating. The Panasonic FR series is now rated 5,000 hours at 105° C. Most are listed as 2,000 hours at 105° C.
        Choose a cap that has a 105° C 'Lifetime @ Temp' or 'Load Life' rating of 5,000 hours or higher if you're looking for long service life.
        BTW - I worked at the manufacturer of your motherboard (DFI-ITOX) for 7 years. We and many other MB manufacturers had a slew of MB returns due to bad caps. Flatscreen TV manufacturers were also affected.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i use polys in those.
          the ones i fix from harris hdradio exporters seem to have had a rough life.
          • jesscat606
            • Feb 2015
            • 18
            Hey, thanks! I wondered about the 470s. All the Chemicons are 6.3V; the 16v ones are all OST.
            The HM/HN/HZ don't have the failure issues the KZGs do?
            • jesscat606
              • Feb 2015
              • 18
              Yeah, this one is a BE xpi10 HD Radio exporter - looks like it needed some TLC; I've already replaced a flaky PSU on it. I'm guessing the polys have higher heat tolerance? do you have any recommendations for poly replacements?
              • jesscat606
                • Feb 2015
                • 18
                Thanks! I was talking with the manufacturer of the unit (who used the dfi-itox board), and they were saying they had a lot of those units come in with this problem. wanted $2000 to replace the MB - apparently the working stock of these is really low!)
                • mockingbird
                  • Dec 2008
                  • 5484
                  The lifetime rating on the Panasonic FR is meaningless in this application, in the sense that if the Panasonic FR capacitor is meant to withstand all the ripple of an ultra-low ESR cap, it's lifetime rating wll probably be equal to or less than the ultra-low ESR cap. Moreso, FR has a lower ripple rating (not to mention that it will also get hotter because of its higher ESR), so it could last significantly less time.
                  You should use HM/HN/HZ. You mentioned you were looking at Digikey. They may or may not have what you need in an electrolytic cap. You might try doing a polymer re-cap.
                  Since this machine seems to be from 2006, it's robably worthwhile to have a look inside the PSU to check if the caps in there are OK. That way, you can order both the motherboard and PSU caps together and save on shipping.
                  • jesscat606
                    • Feb 2015
                    • 18
                    Yeah, this is an old machine. as I had noted above, I had already replaced the PSU with a new one a number of months ago...wasn't looking for cap problems at the time, so didn't notice them.
                    Several people have mentioned going with polymer caps. I dunno much about them - would something like this work?
                    EDIT: Oh, wait, that's SMD - not the right mounting style.
                    Digikey doesn't seem to have the HM/HN/HZ caps, you're right.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      I think you meant those 4 caps were 16V, not 6.3V. So for the 16V 1500uF caps, here are the choices:
                      this, this, or this. (Nichicon HM/HN)
                      If you want to experiment with polymer, this, or this should work, maybe even overkill.
                      For the 10 6.3V 1500uF capacitors:
                      this, this, this, this, or this.
                      Polymer:
                      For the 2 short 1500uF caps:
                      this, or this.
                      Polymer:
                      • jesscat606
                        • Feb 2015
                        • 18
                        i think you meant those 4 caps were 16v, not 6.3v. So for the 16v 1500uf caps, here are the choices:
                        this, this, or this. (nichicon hm/hn)
                        if you want to experiment with polymer, this, or this should work, maybe even overkill.
                        overkill? I note that those are 1000uf, not 1500...is there a reason this is ok, other than that's the nearest size Digikey has? (I'm not tied to digikey, I'm just more familiar with them.)
                        for the 10 6.3v 1500uf capacitors:
                        Polymer:
                        these are all 2.5v, not 6.3v. The only 1500uf/6.3v/8mm polys i saw were smd.
                        for the 2 short 1500uf caps:
                        this, or this.
                        Polymer:
                        Those look like they would work.
                        Are there any likely problems or concerns with mixing poly/non-poly caps on a board? I like the extended life of the polys, but don't wanna cause issues.
                        -j
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Because when you replace VRM high caps, you usually use polymer equivalents with a much much lower capacitance. This has mainly to do with the fact that 16V polymers don't go very high in capacitance, especially at 8mm. Since yours are 10mm, I chose 1000uF to be safe, eventhough you can probably use as low as 270uF here.
                          The reason that you can get away with this on the VRM high, is that with the VRM high, low ESR and high ripple are important, and not bulk capacitance, or at least that's what I have been told.
                          Pentium 4 VCore is less than 1.5V. That's why 2.5V is more than sufficient on the VRM low. If you bought 6.3V ones in 8mm, you'd just be spending a whole lot more money for no reason.
                          Nope. At least not in your case.
                          I've done it myself. I have an Asus P5B I use almost on a daily basis. For the VRM high, I used ordinary Nichicon HM, and for the VRM low, all UCC PSC 2.5v 820uF polymer caps.
                          • jesscat606
                            • Feb 2015
                            • 18
                            So, I picked up the Panasonic polys, just got them...and the leads are 1.2mmm wide - and won't fit the holes. Returning them and will likely go with the HMs - which have 0.6mm leads.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Really? Which ones did you get? The leads on all polies I've seen have been the same 0.6mm as HM.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Bullshit!!
                                You can get a 5960X with an X99 motherboard for less than that!
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • jesscat606
                                  • Feb 2015
                                  • 18
                                  Actually, I need to retract that last. I was thinking the leads were too big; what happened was I was getting leftover solder in the mounting holes, not letting me get the new caps in. which is being a real PITA, because these caps mount on a huge copper plate (on both sides of the board!) and it's almost impossible to heat it long enough to use my solder sucker.
                                  Bullshit!!
                                  Yes, well, this is in an HD Radio encoder; it's got a custom, proprietary linux build that expects all the IRQ / PCI / Northbridge / Southbridge / CPU settings of this motherboard.
                                  So I'm pretty much stuck with this specific motherboard. Which, since it's long since discontinued, is horrifically expensive.
                                  • jesscat606
                                    • Feb 2015
                                    • 18
                                    Bam!
                                    Now to see if it will boot back up. Here's hoping I didn't screw it up!
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Looks good! The caps all look like they are installed correctly. Fire it up and see how it goes.
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        Nice job! Any reason you chose not to replace the 5 or so 6.3mm OST caps, most of them near the northbridge?
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          Hi everyone,
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
