Vizio VW42LFHDTV10A
  • Chancey
    • Aug 2012
    • 25
    Vizio VW42LFHDTV10A
    I read a recent post by drpj23 and am suffering a similar problem. I chose to make a new thread as to not hijack his thread. The information I have below is from what I posted on another site and figured a C&P would suffice. I also viewed the pdf that Mr Bill posted on that thread and the DC-DC Converter testing procedures differ from the ones I have. So that may add some level of error for my testing...
    C&P
    OK...Page 9-5 of the manual indicates the step by step procedure to diagnose the DC-DC Converter. The problem I am having, is when powered on...no powerup.
    I checked the first step that claims J1 pin 10,11 and 12 should have 5v. In fact, it does. Next step says to power on the TV. The only indication I have of power up is the vizio orange light that turns white. Then u must check J1 pin 2,3,4 and 5 for 12v. (On the VW42L, pin 5 is not populated...must be in general for all TV;s that follow this design scheme.) There is no voltage on these pins and PIN 1, shows NO voltage for PSON and F2 is good that provides the 12v.
    I found a 3.3v reference on the power supply, removed pin1 from connector on mainboard, to prevent back feeding voltage, and jumpered to trick PS to come on. BAM!! TV powers up on I have FULL functionality and menu's and the 12v is present on 2,3 and 4.
    Here's my question...pin1 is not fed from the power supply but the main board? The walkthrough say's to check the PS. Is pin 1 not in fact a toggle that is triggered from the mainboard to power on the switch mode?
    To add some more information, the PS is: FSP254-3M01 and the mainboard is a 0171-2272-2434
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VW42LFHDTV10A
    Some Vizios have bad voltage regulators on the main board. See my sig file below on how to
    1) post pictures of your boards
    2) test voltage regulators
    3) report your readings as per my guide
    --- begin sig file ---
    --- end sig file ---
    • Chancey
      • Aug 2012
      • 25
      Here's the pictures...I'll post the regulator readings in a sec.
      • Chancey
        • Aug 2012
        • 25
        Ok...Updating pictures of the regulators and also the readings of the IC's. My apologies for not having the info up sooner. Got side tracked on another project.
        All reading were done with TV on (assuming orange standby light turning white means TV is on)
        U16
        AZ7805T
        Pin 1-0
        Pin 2-0
        Pin 3-0
        U44
        1117L
        Pin 1-0
        Pin 2-0
        Pin 3-0
        U17
        AMC1117
        Pin 1-2.09
        Pin 2-3.35
        Pin 3-5.13
        U21
        AMC1117
        Pin 1-0
        Pin 2-1.25
        Pin 3-2.50
        U22
        AMC1117
        Pin 1-2.07
        Pin 2-3.33
        Pin 3-5.18
        U20
        1084
        Pin 1-0.54
        Pin 2-1.79
        Pin 3-3.27
        U15
        1084
        Pin 1-2.05
        Pin 2-3.30
        Pin 3-5.12
        U19
        1084
        Pin 1-1.25
        Pin 2-2.50
        Pin 3-5.12
        • retiredcaps
          • Apr 2010
          • 9271
          U16
          AZ7805T
          Pin 1-0
          Pin 2-0
          Pin 3-0
          U44
          1117L
          Pin 1-0
          Pin 2-0
          Pin 3-0
          Recheck the above two. They is something obviously wrong with those.
            So if you forced the PS to come on and all he functions on the TV works with good pictures and sounds, then what voltages do you get at those UXX that shows 0V reading on all three pins if you leave the jumper in place?
            PS_ON signal is generated by the Main board when TV is turn on and this signal is fed into the PS (Power Supply) board PS_ON pin, >3VDC = ON, 0~.5V = OFF.
            • Chancey
              • Aug 2012
              • 25
              I agree...I checked and rechecked. Obviously one is a 5 volt regulator and it's right next to the audio amplifier IC. Odd that when I trick the PS in coming on everything works...gonna jumper again and get back with ya on that one.
              • retiredcaps
                • Apr 2010
                • 9271
                For U44 and U16, see if they are shorted. With power off and lcd unplugged, measure the resistance between pins 1-2, 1-3 and 2-3. Report your resistance measurements for all 3.
                • Chancey
                  • Aug 2012
                  • 25
                  With system jumpered:
                  U16
                  pin 1-11.44
                  pin 2-0
                  pin 3-5.01
                  U44
                  pin 1-8.43
                  pin 2-9.69
                  pin 3-11.46
                  Resistance readings:
                  U16
                  1-2 I stopped @ 10k...acted like charging a cap
                  2-3 2k and rising, cap again
                  1-3 15k and rising
                  U44
                  1-2 .300 ohms <----maybe??
                  2-3 18.4k steady
                  1-3 5.4k and rising
                  Uncertain with the IC U44 being .3 ohms without looking at the datasheet. What gets me, and also worries me cause I know it will cause damage if I leave the TV on while jumpered, why is the stupid thing initializing post when jumpered if the IC's r bad..granted it's the 3.3v not being satisfied. The power button, un-jumpered, will only turn TV on and then I have to kill AC and wait 3 minutes to try again. Power button will not turn TV off. However, jumpered, the TV will power on and off with the button.
                  You think you know electronics and you get something like this thrown in your lap.
                  • Chancey
                    • Aug 2012
                    • 25
                    Best guess from anybody would be better than what I have. Trying to help out a 75 y/o man on SS without having to buy him a new main board.
                    BTW, off subject, LOVE the site. Never seen so much information with this high success rates. If I get this fixed or not...gonna def donate to the sites fund.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      U16
                      pin 1-11.44
                      pin 2-0
                      pin 3-5.01
                      U16 is working fine as it is a 7805 type so pin 3 is correct.
                      U44
                      pin 1-8.43
                      pin 2-9.69
                      pin 3-11.46
                      Technically U44 is doing its job of pin 1 + 1.25V = output voltage.
                      U44
                      Hmm, that indicates that something might be shorted. Or there could be a low ohm resistor between pin 1 and 2. What is the resistance of R478 and R479? What is the resistance of C217?
                      • Chancey
                        • Aug 2012
                        • 25
                        Ok...I need to go to DMM reading class. My meter isn't autosensing and pins 1-2 on U44 are 300 ohms.
                        R478 300 ohms
                        R479 1.99K (2K)
                        C217 1.14K
                        The initial readings of U16 and U44, PS unjumpered are zero on all pins. The voltage readings I gave after intial readings are with me jumpering the A1 on the PS to J1 pin1. So, factory setup...those two IC's have no in, adj or out voltages.
                          According to my calculation, the output voltage of this U44 should be 9.583V.
                          1.25 x (1 + (2000/300)) = 9.583V.
                          "However, jumpered, the TV will power on and off with the button" but if you check the 12V and the 24v OUTPUTS, they will still be there even when you turn off the TV (jumper in place).
                          • Chancey
                            • Aug 2012
                            • 25
                            I agree with the calculations...just wanted to clarify that the first readings were indeed correct and 0 volts. (Post #4)
                            On the second part, negative ghost rider...power off, no 12v or 24v. Power on, voltages are present.
                            You are talking about J1 for 12v and the plug going to inverters for 24v, right? I attached picts...
                            I can program and Allen Bradley PLC5, SLC500 and ControlLogix with my eyes shut...but for some reason, this is kicking my rear....Please don't take my humor as harsh, I am very appreciative of any knowledge I can gain from yourself or retiredcaps....or anyone for that matter
                            Just reread your post on #6...From some of the information I have been reading on this site, is that a normal voltage for PS_ON for every TV? (granted some will be different I'd imagine...gonna remember that one)
                              Yes, about 3Vdc for PS_ON to Bias on a transistor in the power supply section, it is not at logic level like the digital circuits. That does not make sense that the 12 and the 24V go away when the TV is off since we are forcing it to be on by jumping the PS_ON pin, now when I look at the way you are jumping the PS_ON, you use the 3.3V form one of the power supply pin which I have never see 3.3V power supply section on this board before. The way we force the power supply to be on, we use 1~3K resistor between the 5VSTBY and the PS_ON pin to turn on the power supply.
                              I am curious to know if that 3.3V feeding the PS_ON is turning ON and OFF by the main board. Can you tell me which pin on the connector you are using is putting out 3.3V for the jumper?
                              This is how I test the power supply by itself:
                              http://s807.photobucket.com/albums/y...ply%20testing/
                                The pins labeled with C1, B1, A1; they are feed through connections, the power supply board is used as the junction box only, those pins are not connected to the power supply circuits at all.
                                They are
                                Dimming signal (0~5V, 5V= max brightness) if inverter board is setup for analog dimming controlled.
                                PWM Dimming (it uses PWM for brightness control) if the inverter board is setup for PWM dimming controlled.
                                Backlights ON/OFF (for turning on the inverter, >3V = on).
                                To have backlights work, it needs two voltages, one is the swiched 24VDC which is controlled by the PS_ON, and then the Inverter ON/OFF signal.
                                So right now you are using the Inverter ON/OFF to turn on the power supply AND then inverter ON/OFF, that is why the 12/24 go away when you turn off TV. There is no 3.3V power supply section on that power supply board.
                                If you look at the bottom side of the board you will see how A1, B1, and C1 are routed, this is very common setup for most TV to keep the wiring clean. I can draw you the simple diagram if you need it.
                                • Chancey
                                  • Aug 2012
                                  • 25
                                  Would it help if I took some pictures of the inverter board? To determine whether or not it's PWM or analog...the diagram may help. But I may end up having to remove the main board and tracing where pin 1 originates from. At somewhat of a loss...
                                    If you can get the LCD panel model number, then you can get the spec sheet which will tell you all the pin out of the Inverter board and the T-CON board.
                                      Simplify diagram.
                                      Example of LCD panel spec, see page 15 for control signal for the inverter board.
                                      We know the inverter board is OK so no use to look at it.
                                      You need to figure out the PS_ON pin on the Main board, and since the TV functions OK when the PS_ON is forced ON, more likely the transistor interface that control the PS_ON line is stuck ON so it grounds the PS_ON line.
                                      • Chancey
                                        • Aug 2012
                                        • 25
                                        WOW!! LOL, I feel a tad in over my head...but, will force on through the madness and try to whip this puppy. Thnx budm...I'll report back what I find on the main board. Little overwhelming...only a hobby repairer
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
                                        • maricm
                                          Vizio P65 with P55 mainboard
                                          by maricm
                                          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                                          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                                          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                                          04-23-2024, 08:25 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
