Cyberpower DX800E UPS bad cap
  • csh
    • Mar 2015
    • 38
    • Croatia
    USP is 4 years old, simptoms were:
    - on power loss it would not switch to battery but reported error instead
    - sometimes the pwrstat service would turn off the computer on boot, as soon as the service started, UPS told it battery was low and it would issue a shutdown signal
    First I thought it was the battery, opened it up and found a bulged cap. It seems it also leaked brown fluid around the case (last picture).
    It was Su'scon 4700uF 16V SD series (low ESR), replaced with Yageo SC series 4700uF 16V 16x25mm that I had at home. The big cap is right under the small PCB with fuses.
    Now, the other caps are all su'scon SK series - standard, not low esr.
    Cap replaced, cleaned interior with alcohol, UPS works fine for a couple of weeks now
    Now, should I replace the other caps too?
    Here is the list:
    5x 22uF 50V 5x10mm
    3x 47uF 25V 5x10
    1x 100uF 25V ~6x15
    2x 1uF 50V ~5x10
    I don't know how this crappy brand behaves in UPS, it is 4 years old, but the battery (old one) holds somewhere around 10 min on my machine running linux and powering PC, LCD monitor, ADSL modem and router. It has a console utility, it is a proprietary blob but works fine. Can be scripted easily to send email on power failure and another email on batt low and then shutdown a machine nicely. Enough for me. Have a new battery I got from a friend and if I have to open it again, would probably replace all su'scons.
    What do you think, is it worth the effort?
    Re: Cyberpower DX800E UPS bad cap
    I would replace the other caps as well.
    I replaced lots of bad cap in Cyberpower, see pictures of the bad caps I tested, as you can see, lots of them are failed due to ESR and lost the capacitance. I replace them with LOW ESR Panasonic FM/FC series. Some of those caps are used in the charger circuits.
    https://www.badcaps.net/forum/showth...ght=cyberpower
    • csh
      • Mar 2015
      • 38
      • Croatia
      So, the capacitance was reading ok, but the ESR was too high, were those low esr caps or standard?
      Can i use low ESR caps in my UPS?
        Those crappy caps in the pictures are su'scon SK series. I replace them with better brand, PANASONIC low ESR, 105c FM/FC series.
        Some of them read 31uF instead of 47uF (+/- 20%).
        • Behemot
          • 4845
          • CZ
          Must Power crap.
          Some of the smaller caps go bad after about 5 years. But it is incredibly difficult to replace them. The paths are too tiny and often when you pull the cap out a piece just disappears. I do not know if it gets torn off, maybe it just dissolves in solder, who knows from what they make it, I don't believe it is pure copper. The transformer has aluminium winding so everything is possible.
          Those caps are general purpose, I use Nichicon VZ or NCC KMG instad. They are ten times better anyway.
          • csh
            • Mar 2015
            • 38
            • Croatia
            I saw some Panasonic FCs at a local shop (everything except 1uF cap). I could try to recap with those like budm suggested.
            Hope the low esr would not cause problems
              • 31304
              1uf FC series are dicontinued.
              • Sean Devine
                Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
                by Sean Devine
                UPS turned off one night and it seemed that the 3 year old batteries gave out.
                Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
                ...then I found various Cyberpower threads here with some guidance on what to check.
                C1 (22uF) tested at 2, so I replaced that.
                Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
                03-03-2025, 08:23 PM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
              • pete_c
                CyberPower 1350AVR and 1500AVR - Repair
                by pete_c
                Both are older than years old now.
                Pooling info here from what I have read.
                Cyberpower 1500AVR takes 4-5 days to charge batteries after test depletion.
                Made an RPi Nutserver for the rack and using PFSense for the telco area with an APC.
                Using Nutserver with Home Assistant.
                Last week ordered
                33uF 200v Rubycon Electrolytic Radial Lead Capacitors
                22UF 50V Electrolytic Radial Lead Capacitors
                VIPer22A "Original" ST 8P DIP IC 2 pcs
                Noticed that the old Cyberpower UPS's output...
                05-06-2022, 04:10 PM
              • timakaze
                CyberPower Smart-UPS OL2000ERTXL2U not charging.
                by timakaze
                So i have this UPS Cyberpower OL2000ERTXL2U that is no longer charging the batteries and i would like to try and figure out if its fixable ? It did throw up and error message on the LCD saying Charger Failure and so i powered it off and back on again and it no longer shows the error and seemed to be fine. But the batteries just go flat now and it dose not show any errors other than batteries low.
                Have taken some pictures but i dont know where the charging circuit is or what parts to look out for to replace. Everything looks good. No swollen or leaking caps. No burnt or discolored...
                09-28-2024, 05:28 PM
              • carrzkiss
                Cyberpower cps1500avr not charging batteries
                by carrzkiss
                Hello, all.
                Cyberpower Battery Backup Unit.
                I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                Checking the voltage, it was down to 22v.
                I quickly removed everything...
                06-15-2024, 02:10 PM
