CyberPower Smart-UPS OL2000ERTXL2U not charging.
  • timakaze
    • Sep 2024
    • 13
    So i have this UPS Cyberpower OL2000ERTXL2U that is no longer charging the batteries and i would like to try and figure out if its fixable ? It did throw up and error message on the LCD saying Charger Failure and so i powered it off and back on again and it no longer shows the error and seemed to be fine. But the batteries just go flat now and it dose not show any errors other than batteries low.
    Have taken some pictures but i dont know where the charging circuit is or what parts to look out for to replace. Everything looks good. No swollen or leaking caps. No burnt or discolored components.
    If anyone can point me in the direction of the charging section i might be able to check its components and see if i can find what might have gone bad ?
    Cheers.
  • timakaze
    • Sep 2024
    • 13
    I think i found it (the charging circuit). And i also found a diode that's gone bad on that board. Measures continuity in both directions.
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • luca773
      Cyberpower CP900EPFCLCD UPS not charging
      by luca773
      I have a problem with a Cyberpower CP900EPFCLCD UPS unit that seems not charging the battery.
      With AC power connected I measure 13,50V on battery terminals.
      If I unplug AC cord, voltage drops below 10V after no more than 30 seconds causing UPS to shut off.
      I'm testing with a load of 20W.
      Plugging AC power again UPS turns on and battery charge level indicates 100% (even if I disconnect battery!!!!).
      Tried with new battery same behaviour.
      Therre is no sign of blown components. Could you help me troubleshooting...
      05-20-2023, 09:39 AM
