Another re-build (Codegen 450 W)
  • c_hegge
    • Sep 2009
    • 5219
    This is the first time I've re-built a power supply since my success with the Rexpower. It was a "450W" (more like 450mW) Explodegen. Here's what I did to it.
    2A 4 diode treatment - 6A Rectifier
    470uF HEC primary caps (now, what the hec were they doing there?) - 680uF Panny HC
    No-name 13007 TO-220 switchers - TO-247 Fairchild 13009s
    Extra X-cap and coil on the input filter
    ERL-33 transformer - ERL 35
    16A fast recovery rectifier (for 12V) - 2x SBL2060CT 20A schottky rectifiers
    12A schorrky rectifier (3.3v) - SBL3040PT 30A schottky
    30A schottky rectifier (5v) - 2x STPS3045CW 30A schottkys
    2x 1000uF 10V HEC caps ov 5v and 3.3v - 2x 3300uF 6.3v Panny FK
    1x 1000uF 16V HEC on 12V rail - 3300uF 16V Samxon RS (thx topcat)
    1x 1000uF 10V HEC on 5vsb - 1200uF 6.3V Chemi-con KZE
    470uF 16V HEC on -12V - 470uF 16V Ruby ZL
    Tricod science fan - Delta DSB0812H
    New sleeved connectors (All 18AWG):
    1x 20+4 pin ATX
    1x ATX12V 4 pin
    1x PCI-E 6 pin
    4x SATA
    6x Molex
    1x FDD
    New case from an exploded Bestec
    And last but not least, a new 400W label
  • dmill89
    • Dec 2011
    • 2534
    Re: Another re-build (Codegen 450 W)
    Nice, I'm kind of suppressed they used a 12A rectifier on the 3.3V since most of these cheaper PSUs are older designs and use higher amperage parts on the 5V and 3.3V, I guess they figured the 3.3V rail wasn't that heavily used anymore and there was another place to cut costs.
    • c_hegge
      • Sep 2009
      • 5219
      Wait... did I say 12A? I meant 20A. In any case, though, 30A is an upgrade
      • dmill89
        • Dec 2011
        • 2534
        Ok, that seems more normal.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Well done!
          Now go and load-test it
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            C heegge I am goinggb to make you a nicer psu logo thingy... 'k?
            • c_hegge
              • Sep 2009
              • 5219
              I like that CH PC power one.
              • Newbie2
                • Sep 2005
                • 885
                Very nice PSU rebuild there c_hegge. Doesn't resemble a cheap gutless Codegen anymore at all, excellent work there.
                My gaming PC:
                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                ASUS M4A77TD AMD 770 AM3 Motherboard
                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                ASUS Xonar DG 5.1 Channel PCI sound card
                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                Antec Three Hundred Mid-Tower Case
                Microsoft Windows 10 Pro 64-bit
                Microsoft Windows 7 Ultimate SP1 64-bit
                • Shocker
                  Banned
                  • Dec 2011
                  • 635
                  Somehow I'm not certain it's going to manage 400 watts...
                  • Newbie2
                    • Sep 2005
                    • 885
                    The 35A rating on the +12V rail he has on his label is a pretty bold statement as well...
                    My gaming PC:
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      Mind you he fouled up the math. 35A at 12V is 420W.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Not at all. With two 20A rectifiers, it will do 40A.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          You're right. I didn't even think of that. I just went "I have 40A capacity, so I'll just de-rate the 12V rail by 5A"
                          • c_hegge
                            • Sep 2009
                            • 5219
                            If you use efficient rectifiers, you can pull even more than 400W from TO-247 13009 switching transistors.
                            • Shocker
                              Banned
                              • Dec 2011
                              • 635
                              So you didn't actually do the math, huh???
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Explodegen. I like that.
                                • Newbie2
                                  • Sep 2005
                                  • 885
                                  c_hegge should get this PSU on the load tester to see how close his rebuilt Codegen can do compared to his sticker.
                                  My gaming PC:
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    Yes he should.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Looks like a pretty decent PSU now.
                                      I still wouldn't pull more than 300W continuous from it, though, just to be safe. Perhaps 350W peak. Also, 35A on the 12V may or may not be possible, even if the 12v rectifiers and the transistors on the primary allow for that kind of power. The winding on the transformer for the 12v rail may not be just up to the task for that. The other possible limitation is the SG6105 PWM controller - you will have to check what the OPP is set to.
                                      Definitely a nice rebuild, though .
                                      • bauto601
                                        KDM 480W PSU upgrade succes! (opinions?)
                                        by bauto601
                                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                        A "nice" YoungYear unit? - Badcaps
                                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                        12-26-2023, 03:05 PM
                                      • Steph.hen
                                        Bridge rectifier identification part number KPB305G
                                        by Steph.hen
                                        Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                        I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                        08-29-2024, 09:52 AM
                                        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                        by momaka
                                        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                        http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                        What mostly drew me into buying it is its 2x PCI-E power connectors...
                                        03-29-2022, 11:34 PM
                                      • Lien1454
                                        Belkin F5D4076-S v2 Powerline Adapter. Bad Cap and SCHOTTKY RECTIFIER
                                        by Lien1454
                                        Firstly I'm quite the amature at fault finding.
                                        I have a pair of Belkin F5D4076-S v2 powerline adapters. One is working the other is dead.
                                        On opening the dead one. I spotted a bulging cap which is a 6.3v 2200uF.
                                        Measuring it with a MM reads 1900 uF.
                                        There is also next to it a SM SCHOTTKY 399F SM340C. On testing this for continuity there is none. However on testing the other powerline there is continuity. So looks like I need to replace that also.
                                        I cannot find any Schematics for the powerline. I've been able...
                                        12-12-2020, 05:03 AM
                                      • howardc64
                                        QN75QN85BAFXZA no backlight
                                        by howardc64
                                        2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                                        PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                                        07-03-2025, 05:08 PM
