12v 1uo941243c Relay repairable?
  • bohaboha
    • Nov 2012
    • 1003
    • sweden
    Is it possible to repair this relay?
    the three resistors look like they have purple color on the bands is that correct? and one of the small diodes is broken. i ask because it is said that normal relays are not serviceable
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: 12v 1uo941243c Relay repairable?
    easy to fix or even fully rebuild if the mood takes you .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      what the heck...what's the switching element in this "relay" ... why aren't these diodes and resistors potted with the rest of the circuitry if there's more in the base?
      Without more data...that can't be a relay even if the encapsulation looks like one.
      Seems this PN crosses to other relays but no specs found yet. Probably has parts embedded in plastic (SSR) making it that much harder to replace the switching components if they're there.
      • bohaboha
        • Nov 2012
        • 1003
        • sweden
        Thanks for the reply. can you confirm the colour of the resistor? yes it looks to be. but what is under the surface? I don't see anything special other than the traces under a black cover hard to show with pictures
        • bohaboha
          • Nov 2012
          • 1003
          • sweden
          yes it is a relay that belongs to a scoda octavia. "Probably have parts embedded in plastic (SSR) which makes it much more difficult to replace the clutch components if they are broken." exactly what i was thinking but there doesn't seem to be more than traces in the plastic protection
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Take a photo of it in sunlight...
            You know, maybe we need to start poking people to do this when they take pictures of resistors asking what color bands they are, so we don't have to trust the CRI of their light source as well as the "CRI" of the photosensor... enough trouble as it is that our monitors tend not to be color calibrated either.
            • bohaboha
              • Nov 2012
              • 1003
              • sweden
              [QUOTE=eccerr0r;1166070]Take a photo of it in sunlight...
              You know, maybe we need to start poking people to do this when they take pictures of resistors asking what color bands they are, so we don't have to trust the CRI of their light source as well as the "CRI" of the photosensor... enough trouble as it is that our monitors tend not to be color calibrated either.[ You're right, but right now I can't trust my eyes. it's 4 bands not 3 as I said before
              • diif
                • Feb 2014
                • 6978
                • England
                You could remove one and measure it's resistance.
                • bohaboha
                  • Nov 2012
                  • 1003
                  • sweden
                  I'll thank you
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Might be easier to see the colors in sunlight too, it's not only cameras that benefit from better CRI!
                    • redwire
                      • Dec 2010
                      • 3910
                      Oh, I see the PC board trace is melted and lifted up, it must have fused due to a short circuit in the car somewhere. It might have also blown a 1N4004 diode.
                      The resistors are not a problem, I see the middle as gray-brown so possibly 680Ω the first stripe I thought purple but no parts exist like that i.e. 780Ω.
                      • bohaboha
                        • Nov 2012
                        • 1003
                        • sweden
                        ya there is a broken IN4005 but I measure 180 ohm po resistance with a lifted foot. In4005 Sy309 is the 2 small diode one is blown
                        • redwire
                          • Dec 2010
                          • 3910
                          You know I'm saying the copper track has melted
                          There is a problem with the car. It will just blow the relay once you repair it.
                          OK the resistor first stripe is brown then for 180Ω, and they are 1N4005 and a 1N5404.
                          • bohaboha
                            • Nov 2012
                            • 1003
                            • sweden
                            "You know I say the copper strip has melted." you mean on the relay itself ?
                            ok you say there is a problem with the car. Do you have any idea what the problem could be in the car? lol now we are going from elektronic to car mecanique but note that i don't see any abnormality on the traces that are remotely visible on the cap
                            • redwire
                              • Dec 2010
                              • 3910
                              Yes, inside the relay the track looks to have melted. I would say it was overloaded- which melts the PCB trace and pops the diode.
                              I would say a new relay or fixing this one and it will just melt again.
                              There must be a short circuit, such as a light bulb (socket) or cheezy LED lighting added to the car, or maybe some damaged wires. I can't tell what goes to the cracked diode.
                              Can you post a clear picture of the circuit board trace side AND the relay pins (numbers). Do you have a wiring diagram for any of the car that involves the relay?
                              Škoda Octavia - 1U0941243C, AEV0306, VK7 relay, it seems to be for the power door locks (was the car in an accident?) and alarm system?
                                • 31048
                                door lock motors sieze or jam,
                                i'v replaced a number on ford and bmw - total shit
                                it's a tiny brushed electric motor with a BRASS gear on it driving a PLASTIC rack that extends or retracts.
                                i cant see one drawing enough current to do that though.
                                i'v never seen a bad one damage anything.
                                • bohaboha
                                  • Nov 2012
                                  • 1003
                                  • sweden
                                  redwire I don't want to disagree . but the tracers look to be intact and equally thick across the small circuit and no deviation. it's really hard to show in the picture. No I don't have information because I can't find anything about this car it's my own. now I know about this relay thanks to your information.
                                    • 31048
                                    before it failed, did all your doors lock and unlock reliably?
                                    including the fuel filler cover?
                                    • bohaboha
                                      • Nov 2012
                                      • 1003
                                      • sweden
                                      no problem att all with doors
                                      • petehall347
                                        • Jan 2015
                                        • 4427
                                        • United Kingdom
                                        think those relays are also used for dash lights
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • Crystaleyes
                                          LCD TV Power Supply Board question
                                          by Crystaleyes
                                          First off,
                                          Happy New Year everyone!
                                          Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                                          A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                                          01-01-2025, 09:40 AM
                                        • Nikolai Danylchyk
                                          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                          by Nikolai Danylchyk
                                          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                          Thanks in advance!...
                                          05-08-2025, 06:18 AM
