Voxicon K550WDC2 no Backlight
  • bohaboha
    • Nov 2012
    • 1036
    • sweden
    Hi i have found this set and at first try it worked backlight and apparently everything .after 10 minutes i turned it off and switched to a better place this time nix no backlight only the blue pointer but when you turn it off the logo flashes and sometimes when you press the on button same thing.it is clear that it is backlight problem thought to test without opening it how do you do it?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Voxicon K550WDC2 no Backlight
    Looks like 2 sets of leds. You would measure from the led + on each of led sets. Turn on tv and measure each one. for max. voltage. You will repeat for the second set.
    • bohaboha
      • Nov 2012
      • 1036
      • sweden
      There are 4 cords black and red on one side and two white on the other how do I go about this please
        • Jul 2011
        • 6070
        You need to take a better closer picture of the power supply board so I can see the wires from the transformer connections to the board make sure that it is in focus when enlarged thanks
        Also if can take another picture of the same exact board but with the connectors on the right side of the board remove but be very careful not to break the connector pry the bottom of the connector on each corner do not pull on the wires to remove it
        I need to see the writing on the board where the connectors are this is the reason for asking you to remove them so I can read it
        • bohaboha
          • Nov 2012
          • 1036
          • sweden
          Hi I hope these pictures are good enough for you .the label is on the back as you can see
          • dskall
            • Oct 2016
            • 2905
            • usa
            Looks like 2 led wires towards outside are positive. Need to monitor each one as you turn on tv and see what they go up to.
            • nomoresonys
              • 12331
              • U.S.
              its not rocket science, do the test as Dskall explained, then tell results.
              • bohaboha
                • Nov 2012
                • 1036
                • sweden
                Certainly not but to test properly I wanted to know what the white wires are. There is a black one which should be -(Gnd) and a red one which in its turn should be+(current) and then the other white they are plus or minus?
                • nomoresonys
                  • 12331
                  • U.S.
                  Go ahead and put the pos. probe on all of them, neg probe on metal chassis, 2 of them should give about the same voltages, a good one usually goes up when first turned on then settle down to a certain voltage, according to your tv specs, they are sometimes written on the board, it wont hurt anything to put your probe on all of them tho.
                  • bohaboha
                    • Nov 2012
                    • 1036
                    • sweden
                    i don't get anything from any wire when i press the on button versus i get a
                    gradual downgrade from 80v from the black/and last white wires. i have done a led test that gives the light on the left half (i sit behind tv) and if you remove the right ribbon from the Tcon i get the half left tv light (facing the tv) only when you press the off button otherwise black square. if you remove the left ribbon you get two stripes on the middle only on the off button otherwise black. led test made power plug unplugged in
                    Translated with www.DeepL.com/Translator (free version)
                    • R_J
                      • Jun 2012
                      • 9624
                      If you remove the flat ribbon between the t-con and the panel and half the panel lights up (white screen) the problem is not with the led's
                      • bohaboha
                        • Nov 2012
                        • 1036
                        • sweden
                        No The half panel only lights up when you turn off the TV
                        • R_J
                          • Jun 2012
                          • 9624
                          How can half the panel light up if the tv is turned off? If you can see half the panel then the backlights must be on, if the backlights did not work, you would have a black screen.
                          • bohaboha
                            • Nov 2012
                            • 1036
                            • sweden
                            Please if you have half the TV lit then it should be on all the time. but this one lights up right at shutdown
                            • R_J
                              • Jun 2012
                              • 9624
                              What is the voltage on the red wire going to the backlights when you turn the tv on, and then when you turn it off. You need to keep the meter connected to see what the voltage does. It should be around +200 volts then drop if there is a backlight error
                              • bohaboha
                                • Nov 2012
                                • 1036
                                • sweden
                                se post 11 please
                                • bohaboha
                                  • Nov 2012
                                  • 1036
                                  • sweden
                                  se post 11 please
                                  gradual downgrade from 80v/90v from the black/and last white wires
                                  • bohaboha
                                    • Nov 2012
                                    • 1036
                                    • sweden
                                    It looks like it is open or short in all that is red highlighted in the picture which should I loosen first to eliminate
                                    • bohaboha
                                      • Nov 2012
                                      • 1036
                                      • sweden
                                      This TV is waiting to get a push forward I haven't been able to do anything due to illness now I'm on my way and want to see pictures on this screen.on this video he says it's better to make some change or an external backligth driver instead of changing the part https://www.youtube.com/watch?v=aeqkIYifdjU&t=1206s
                                      what do you think?
                                      • bohaboha
                                        • Nov 2012
                                        • 1036
                                        • sweden
                                        no one interested in helping out for this Tv
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
