Voxicon K550WDC2 no Backlight
  • nomoresonys
    • 12241
    • U.S.
    Re: Voxicon K550WDC2 no Backlight
    Not sure what you did already, I'm no pro but I would take it down to backlights and check them out with backlight tester or multimeter, MUST be very careful not to break panel they are very flimsy, maybe checkout some youtube videos on teardown if needed.
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      Thank you very much for the answer, it is backlight but there is something else with the cold side of power supply or rather something with backlight driver for which I need help
      • nomoresonys
        • 12241
        • U.S.
        Would need a much better picture with sharp detail of the designators on the board, short of that you need to determine which parts are bad by testing, which means testing all diodes, resistors, transistors and caps etc. sometimes you need to remove a component to get a true accurate reading on it.
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          Now all the LEDs are lit.it is the first LED in the second row in the upper part from the V sign that was broken I changed it but I need to know what glue to use on the candle hat so that it does not fall with the heat
          if anyone who can give tips very grateful
          • nomoresonys
            • 12241
            • U.S.
            Well you don't want to use superglue[Cyanoacrylate] because of the potential for lens clouding. There's some examples of the glue they sell for the job, can probably find some like it closer to home than china tho, and you MUST make sure the lens is oriented correctly, if any of that has cyanoacrylate probably best to skip that product, you can find many choices on ebay also: https://www.aliexpress.com/w/wholesa...lens-glue.html
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              #26
              thank you very much i have found something at home now this tv is basically ready have to get a remote control for it but it is an odd brand so it will not be easy maybe a universal
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                #27
                Hi Everyone who helped me with this repair the TV is fixed it was backlight problem that got fixed: it was just one broken led in a strip and I have only replaced it instead of a new kit because this tv is very odd brand and it is not worth spending much money on it but I must say that it has a really nice picture.
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • canadaboy25
                  LG Flatron 24EN33TA No Backlight When Cold
                  by canadaboy25
                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                  03-07-2023, 12:23 AM
