First reset signal on computer, how to work !
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    FIRST RESET SIGNAL ON COMPUTER CIRCUIT
    RSMRST#
    When the Power,Bios,Ec are OK, the RSMRST# will go Hi. In the other word,this pin go Low only when the systemreset.If BIOSdata is error,RSMRST# won't go HI.
    When SIO(EC) get +V_RTC
    thecrystal will work.
    1. RTC have to be oscillating(32.768KHz).
    2. RTCRST# have to be high.
    3. RSMRST# have to be inactive (high).
    4. PWRBTN# have a trigger.
    5. LOW_BAT# have to be inactive (high).
    If this 5 present, then EC will issue SLP_S3# /SLP_S5, in the old ICH SLP_S3 and SLP_S5 will generate directly to ICH.
    When All+V?S/+V? powers are ready, PWR_GOOD will tie to high to turn on CPU powers(+VCCP and +VCC_CORE).
    SB/PCH Power good--->SB/PCH pwr_btn--->PCH RUN
    SUSB# from PCH toSIO pull up the signal SLP_S3# The signal is used to shut power off /on through logic gate transistor or IC
    SUSC# from PCH to SIO pull up the signal SLP_S5# The signal is used to shut power off /on through logic gate transistor or IC
    ICH/SB,MCH & CPU Signal Checking
    IMVP_PWRGD => CLK_ENABLE# => RESET_OUT#=> ICH_PWRGD => PLTRST# => PCI_RST=> H_PWRGOOD
    CPU generate the first cycle to read the BIOS code
    CPU bus DMI LPC SPI
    CPU ===> GMCH===> ICH===>SIO ===> BIOS
    CPU MASTER POWER
    VR_ON Enable--->+VCCORE 08VS to 1,5VS
    Memory +VTT and +V1.5VS (DDR3) is ok, the PGOOD VTT_PWRGD pull high to CPU first than ICH will tie H_PWRGD to high ,then NB will tie CPURST# to reset CPU.
    Crystal clock Oscilator CLOCK SUMMARY
    (1) 32.768KHz to SIO Required +V_RTC and to ICH(chipset) also Required +V_RTC
    (2) 49.152MHz to (audio controller) Required +V3S
    (3) 27MHz to Graphic chip (video controller )Required +V3S
    (4) 14.318MHz to (clock Generator) Required +V3S
    Make sure crystal is oscillating for EC(SIO),SB/ICH/PCH and VGA or it will no post
    Clock Generator
    Elementary required
    1) Power : +V3S
    (2) Crystal : 14.318MHz
    (3) Control : PCISTOP# , CPUSTOP#_ is HI
    When +VCC_CORE is ready, CLKEN#will go high to enable clock-Generator and turn all clock.
    PCI_STOP# and CPU_STOP# must beat high otherwise some clocks will be turned off.
    Clock out -->SIO(EC)-->PCH/SB-->NB-->CPU
    LPC_Frame-->SB output signal is high
    Note High signal can be identified by measuring 3.3V available
    Power by experiences of adiedkhaz
  • shijeesh
    • Mar 2011
    • 65
    Re: First reset signal on computer, how to work !
    Highpulse thanks . It is very useful to all. Please upload other topic
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      always i got a nice subject i usually post ,
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        ty im a noob at this stuff.. nice guide, tnx
        Im Back... sort of...
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          sure mate , we are for help , this is not from myself , credits goes to the name below the following infos.
          • Ramee
            • Jul 2014
            • 218
            • Israel
            Here is the link, found it.
            http://adiedkhazbook.blogspot.com
            • Siddig
              • Jun 2017
              • 264
              • Sudan
              Good. Thanks
              • Techtiger
                • Oct 2014
                • 1602
                • france
                • Lapy
                  • Dec 2018
                  • 15
                  • algeria
                  Many thanks
                  • charafmak77
                    • Oct 2017
                    • 81
                    • jijel
                    thanks
                    • gmacz
                      • Jun 2018
                      • 40
                      • Sri Lanka
                      Thank you very much Sir.
                      • Gau_saha
                        • Feb 2020
                        • 35
                        • India
                        Thanks Sir ��
                        • bhaskar
                          • Nov 2015
                          • 13
                          • India
                          what about slp s3 and slp s5
                          • danro
                            • Aug 2011
                            • 54
                            • Serbia
                            very interesting and useful post
                            thank you!
                            • aaabddoo
                              • Nov 2021
                              • 17
                              • egypt
                              thank you
                              • mitu_sharma
                                • Jul 2015
                                • 182
                                • india
                                wow thanks
                                • mmccomputer
                                  • 75
                                  • France
                                  big thanks bro
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    32.768KHz if missing what might it be the prolem?
                                    • Gau_saha
                                      • Feb 2020
                                      • 35
                                      • India
                                      Thanks Sir
                                      • kofe
                                        • Sep 2013
                                        • 32
                                        • Estonia
                                        Thank you very much!
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • Kooopa
                                          Acer Nitro 5 AN515-43 Turns on Then Off..
                                          by Kooopa
                                          Hi! I'm back again... so I solved my previous issue but now it's back with a vengeance...
                                          First, history... previous issue was dead motherboard, blinking power LED, no fan spin nor LED backlight, which was caused by a missing SLP_S5#. This was fixed when I replaced the RTC crystal.
                                          Which brings us to the present. The screen started glitching every other 2 seconds. The screen corruption looks like the horizontal pixels/scan-lines are being shifted to different spots. This also happens on the BIOS setup. So I thought, "Okay, this might be my LCD since the thing has...
                                          10-06-2024, 09:44 AM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                          MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
                                          Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
                                          The nonvolatile...
                                          10-07-2024, 04:55 AM
