Sanyo DP42848 Dead
  • 1beertap
    • Mar 2009
    • 219
    Sanyo DP42848 Dead
    I picked up a Sanyo model# DP42848 Chassis# DP42848-00 freebie that doesn't come on. The unit's green light comes on then goes off and the sound of a relay click can be heard when on, also when cuts off. I have checked all of the power supply caps using both esr and capacitance meters and they tested fine. When I remove connector K8L located on main board, the back light comes on but still unit cuts off. I am thinking main board or tcon. Any ideas to isolate possible bad component? Attached are pictures of the boards.
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: Sanyo DP42848 Dead
    Usually if a Tcon is bad, the tv will still power on. I would be looking at the power supply more and possibly the inverters. Check for fuses on the inverters. Some tv's will not power on if they have a bad inverter or if the cable is now installed properly.
    • rmoody
      Learning Member
      • Jul 2011
      • 262
      What is K8l cable running to? Your pictures aren't good enough for me to tell.
      • 1beertap
        • Mar 2009
        • 219
        K8l has a black and a white wire running between the main board and CN1 on the inverter board. When I unplug this at the main board the backlight will come on but of course, TV does the same either way plugged in or not, won't stay on as it clicks off. I know I won't get a back light but should the TV come on with the inverter board unplugged or does the power supply need the feedback from the inverter?
        • 1beertap
          • Mar 2009
          • 219
          Checking the power supply voltage (while unit is briefly on):
          needed actual
          24vdc 24.7vdc
          12vdc 11.99
          5vdc 5.04vdc standby
          All signal grounds from power supply to chassis ground test good.
          • rmoody
            Learning Member
            • Jul 2011
            • 262
            I'm not sure if it will power on with the inverter unplugged in or not. The last set i worked on would not. If your voltages coming out of the power supply are what they should be according to what is printed on the board, you know the power supply is good. Have you checked the fuses on the inverters? or the caps?
            • 1beertap
              • Mar 2009
              • 219
              I have checked both inverters. The fuses and caps are good.
              • 1beertap
                • Mar 2009
                • 219
                On control board going to display. I do not have 12v when turning on tv but instead the voltage tries to build until tv shuts down. The most I've tested was about 2v. Again, it's not always the same. I do have 12v at power supply. Any ideas?
                • 1beertap
                  • Mar 2009
                  • 219
                  Does anyone know where I can get a schematic for this tv?
                  • 1beertap
                    • Mar 2009
                    • 219
                    Hey guys just a little update. I thought I would try this and I can turn tv on and off a few times and after about 3sec. just before tv cycles off, I can briefly see a picture with "HDMI3" in a blue block. Would I be getting a picture if the TCON was bad? Thanks for your help.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Probably not. It appears you have an backlight problem.
                      PlainBill
                      • 1beertap
                        • Mar 2009
                        • 219
                        PlainBill, thanks for taking the time to help us learn. See attached photo. When I disconnect this connector (K8L) with two wires (one black and one white) off of the main board, the backlights will come on when the tv is first turned on. It stays on until the tv cycles off. Is there a reason why the backlights come on this way? I'm pretty sure that this connection (K8L) is for a sensing/feedback line.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Good job of troubleshooting. Let's see if I can explain this coherently. Usually there are two control lines going to an inverter - On/Off and Brightness. There may also be a status (error) line returning from the inverter. The usual design is that the main board drives the two inputs. It is very easy for the design engineers to add a high value resistor to turn the inverter on if the input cable is disconnected. It is such a good idea I'm a little surprised more inverters don't have that feature.
                          Of course, that kicks the problem back to me, to explain WHY the main board is holding the inverter off. And I honestly can say I don't have any idea. I know my way around power supplies, I'm barely bright enough to troubleshoot a main board with a schematic; no way am I going to tackle a main board without a schematic.
                          PlainBill
                          • 1beertap
                            • Mar 2009
                            • 219
                            PlainBill, I'm going replace the main board because like you, it's difficult to work on main board without a schematic. It'll be a 50/50 shot in the dark. Thanks for the information. I'll keep you and others posted on the results as soon as the replacement board arrives.
                            • dumpystig
                              • Jul 2011
                              • 485
                              I had a similar intermittent fault (also on a Sanyo, Vestel PSU and Signal board). Inverter/backlights would power up for a split second then turn off - TV would then go into fault mode with the dreaded flashing LED. After much head scratching and fault finding I had one more idea - it was a last resort and it worked a treat, I suggest you try this yourself.
                              On the interconnect between the PSU and Signal board I removed the female receptacle from within the moulded sockets at each end of the wiring for the BL-ON wire (I did this on all the wires, but this particular one was the solution for me). This was fiddly as f*ck but once removed I then used a sewing needle to push the inner clip of the brass receptacle so it would have a more positive grip on the corresponding pin within the plug on the board at each end. Once reconnected and powered up my set now works as it should. Been running it for 9 days now with no probs whatsoever. Like I said, it's a very fiddly task but in my case it's been well worth it.
                              System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                              • 1beertap
                                • Mar 2009
                                • 219
                                Thanks for your input, but I don't get a flashing green led on this unit. When the tv is on, the green led is on and when the tv cycles off, green led is off. I did try what you suggested though but with no success.
                                • dumpystig
                                  • Jul 2011
                                  • 485
                                  My apologies - I misunderstood your original problem. Guess I need my sleep now...
                                  • 1beertap
                                    • Mar 2009
                                    • 219
                                    After replacing the main board with a new one, I am happy to report that the tv is now working. I wish I could fix it to the component level, but without a schematic forget it. Thanks again guys for your help.
                                    • dumpystig
                                      • Jul 2011
                                      • 485
                                      At least you did fix it - much more fun and plenty cheaper than paying someone else to do the job.
                                      • amfornal
                                        • Oct 2011
                                        • 1
                                        I have this same TV. I am a novice at electronics so please forgive me if I ask something stupid. My TV just went out last week. TV will power on, (get green light up front) and I get sound but no picture. I have taken the cover off and briefly looked at all the components and can't find any " busted caps" anywhere. I have taken good pictures of all the components and going to post soon. In the mean time, anyone have any ideas?:
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
