LG flatron L1718S - shaky picture when not in native resolution
  • bocca
    • Mar 2012
    • 107
    • Serbia
    Hi!
    So I have one of these, and it's got a shaky picture when not in native resolution, which is 1280x1024 btw. In a matter of fact, any 1280xXXX resolution stops the shaking and makes picture normal.
    I looked over the PCB, ali it looks ok. No bulging caps, no busted fuses.
    If you need a video of the thing, i'll make it.
    Here's a pic of the PCB attached
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: LG flatron L1718S - shaky picture when not in native resolution
    Hi - so what resolution did you want to use?
    Did you try changing the refresh rate?
    What Video card are you using?
    What OS are you using?
    Have you got the correct drivers for the Video Card and for the monitor/system.
    Can you try the monitor on a different sytem.
    Did it just start doing this or is it a new to you monitor
    • bocca
      • Mar 2012
      • 107
      • Serbia
      1. 1024x768, 800x600, it's all the same. As I said any 1280px by long side works fine
      2. Yup. Tried 60hz, 75hz, no difference
      3. Tried several of them, no change. Some are middle class, some are strong gaming ones
      4. win xp
      5. yes, drivers are correct. Problem is not software based, i'm pretty sure
      6. tried it, no difference
      7. Old problem. Monitor stood on a shelf for half a year, and now I tried to repair it.
      thanks for replying
      • retiredcaps
        • Apr 2010
        • 9271
        1) Post a picture of your logic board. There may be some voltage regulators that are failing?
        2) Are your voltages on the power board stable? I see the connector says 5V DC. Is that stable going to the logic board?
        --- begin sig file ---
        --- end sig file ---
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          That is usually the fault of a bad cable, or weak signal coming from the video card. Before messing around inside the monitor, have you tried another cable and another computer?
          A working TV? How boring!
          • bocca
            • Mar 2012
            • 107
            • Serbia
            @retiredcaps:
            i attached the logic board photo
            i measured the two voltages, and they are both 5.21v. seems normal to me
            @Th3_uN1Qu3
            i tried few cables, including test cable that's 100% working. As i previously said, tred switching video cards but to no avail. I also tried another computer completely.
            One thing i noticed is, when i switch refresh rate from 75 to 60 hz shaking is reduced by about half but still clearly visible across whole screen
            • bocca
              • Mar 2012
              • 107
              • Serbia
              Just to note one more thing. When I enter the display menu, the menu part is not shaky but normal
              • retiredcaps
                • Apr 2010
                • 9271
                Originally posted by bocca
                @retiredcaps:
                U101 and U102 are your voltage regulators.
                1) Put your multimeter on 20 V DC if manual range.
                2) Put your black probe on a ground screw (any one on the logic board will do fine).
                3) Put your red probe on each voltage regulator pin EXCEPT the big fat tab. If the middle pin is "cut" and not touching the board, we want to measure that pin as well.
                4) Report the part number for each regulator.
                5) Report all your findings like the following example,
                U101 - part number AL1117-33
                pin 1 = 0.00 V,
                pin 2 = 3.3 V,
                pin 3 = 5.0 V
                • bocca
                  • Mar 2012
                  • 107
                  • Serbia
                  U101 - part number:
                  A1
                  AS1117L-33
                  B0612
                  pin 1 = 0.00 V,
                  pin 2 = 3.28 V,
                  pin 3 = 5.19 V
                  U102 - part number:
                  A1
                  AS1117L-18
                  B0544
                  pin 1 = 0.00 V,
                  pin 2 = 1.63 V,
                  pin 3 = 5.17 V
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    U102 - part number:
                    A1
                    AS1117L-18
                    B0544
                    pin 1 = 0.00 V,
                    pin 2 = 1.63 V,
                    pin 3 = 5.17 V
                    U102 is bad. The -18 in the part number denotes the output voltage should be 1.8V DC. Most regulators are +/- 1% tolerance suggesting a good regulator is
                    1.8 x 0.99 = 1.782
                    1.8 x 1.01 = 1.818
                    Your regulator is (1.8 - 1.63)/(1.8*100) = 94.4% or more than 5% out. Replace it and hopefully that will solve your problem.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Before replacing the regulator try replacing the output capacitor of that regulator, bad caps on reg outputs will give lowered voltage and a whole slew of issues. Had one monitor that put on all kinds of psychedelic color shows because of a bad cap on - coincidence - the 1.8v reg.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        I just got one of these yesterday. If you want, I can give you a list of capacitors to use to replace the ones on the PSU and the logic board... This model uses all Su'scon caps.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Alternatively, you can disconnect the power supply and apply a 9V battery battery directly to pin 3 and measure the output of pin 2 and see if it is 1.8V DC or not. Pin 1 is GND.
                          • bocca
                            • Mar 2012
                            • 107
                            • Serbia
                            @retiredcaps:
                            Thanks. Seems you are right. Will try the caps first and if that doesn't do, I'll search for the new regulator.
                            edit: 9V battery is so hard to find here, I'll sooner find caps and regulator and replace them. But thanks thou', interesting technique. I'll sure do good to remember it!
                            @Th3_uN1Qu3:
                            Will do. Just need to find the right one, or maybe I will replace them all. Any idea how to find the exact one of that regulator?
                            @mockingbird:
                            That would be great, mate! I appriciate it
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              @retiredcaps:
                              Sorry, I meant 2 AA cells in series for a total of 3.0+ V DC.
                                PlainBill had a similar problem with an LG TV: https://www.badcaps.net/forum/showth...&highlight=ldo
                                1.8V regulator read slightly low (1.76V)... Coincidence...? Turned out to be a bad cap on the LDO output causing some oscillating weirdness on the output. Some LDO regulators have an ESR requirement something like 1 ohm < ESR < 10 ohms. So replace any cap on the LDO output with a general purpose one (not low-ESR) with ESR within the range specified.
                                The datasheet says "The recommended value for ESR is 0.5 ohms." So I would find a decent Panasonic NHG cap to replace it with ESR and capacitance closely matching.
                                  Only do this if the regulator can withstand 9V input and power dissipation is not exceeded.
                                  Power dissipated is approximately (Vin - Vout) * Iout.
                                  The scaler probably draws around 200mA and assuming maximum 1W dissipation for a temporary test:
                                  Max Vin = 6.8
                                  I would use two AA's in series, not a 9V battery.
                                  The datasheet doesn't mention a maximum input - I know some regulators are limited to just 6V in! - so try and stay within this limit.
                                  • bocca
                                    • Mar 2012
                                    • 107
                                    • Serbia
                                    @retiredcaps:
                                    will do that right now! thanks
                                    @tom66:
                                    ufff, good caps are almosty impossible to find in this hellhole I live in, and no one ships to serbia without at least 50 bucks worth of postage costs so that's out of option.
                                    Best caps I can find are Yageo. Haven't found anything better for now.
                                    BTW, how do I find ESR of the cap if it's not written on it?
                                      In this application, Yageo may be okay. They are formerly Philips/Vishay caps so better than no-name junk. Do you have a datasheet for the caps in question?
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Probe around with your multimeter set to continuity mode (buzzer). One lead on the output of the regulator, with the other lead check the + of nearby capacitors. Hold the probe at least 5 seconds on each lead to avoid false detection. Some caps not actually connected to that trace will charge from the current provided by your multimeter, making it beep for the first couple seconds, then it'll read disconnected. When it keeps beeping after a few seconds, and also beeps when the test leads are switched around, you've found it.
                                        Alternatively you can probe with the monitor on, and see which cap you get the 1.63 volts on.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                          I ordered a supposedly β€˜new' Tcon board this time, and
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
