samsung 32 ln32b360c5d no power no indicator
    hi i have samsung 32 ln32b360c5d that i bought off craigslist hoping it was bad caps. that was not the case all of the caps look good and all the fuzes are good. i tested the power boards output pins and all tested 0 dc v except three pin4 (e-pwm) pin6 (13v (m)) and pin7 (13v (m)) tested 5 m volts. thank you in advance for all your help.
    Re: samsung 32 ln32b360c5d no power no indicator
    i retested the power board thinking i should use the ground pin as a ground and when i did that there was 0 v on evey pin. i also tested the three big diodes and they are good.
    Can you test a zener diode with a dmm diode test because i am trying to test all of the diodes and one zener diode reads .361v and .193v
    The model of the power board in hv32hd_9ss bn44-00289B
      check the startup cap in the power supply, it will usually be a smaller cap 10 to 47 uf somewhere close to the main filter cap(big ones)
        Please upload the pictures of all the boards so we can see how they are connected, then good clear pictures of the power supply board both top and bottom.
          here is the pics and power board schematic
            What DC voltage do you have at the main DC filter CP815, 100uF 500VDC.
            This TV has PFC circuits, when the TV is off, you should have about 170Vdc on CP815, when the TV is on, you should have about 400Vdc on CP815.
            The standby power supply (always on) is generated by IC UM801S (ICE3BR0665), produces 5V and 13V standby voltages.
              cp815 reads 162.3 vdc
                zd804 reads 1430ohm and 4670ohm is that bad
                  what is the voltage on the cp815 when you turn on the set? if it does not rise the smps is not starting
                    the set does not turn on and cp815 reads 162.3 vdc
                      how do you test a zenner diode.
                        Since you have the diagram, do you get the 5V and the 13v standby voltage as I mention in post6?
                        ' i tested the power boards output pins and all tested 0 dc v except three pin4 (e-pwm) pin6 (13v (m)) and pin7 (13v (m)) tested 5 m volts" What is the 5m volts, 5 millivolt (mV), or 5 Volts? same for the 13V.
                          no there is no voltage at any of the pins
                            So the 5V power supply is dead. Your TV looks almost th same as one I am working now with bad screen, I will see if it has the same power supply/inverter combo board.
                              See here: https://www.badcaps.net/forum/showth...202#post255202
                              It may give you some ideas what you should have.
                              Or here:
                              http://s807.photobucket.com/albums/y...20LN32B540P8D/
                                I think i found three shorted diodes. (zd804, dm852, zm804) I ordered the parts and will hope that will fix it.
                                  it is fix
                                    Glad to hear, what voltage zeners did you use in the end?
                                      the same as stock specs
                                        Which were what voltage rating?
