Panasonic TCP50S1
  • Rustifer134
    • Dec 2016
    • 19
    Panasonic TCP50S1
    Merry ( day after ) Christmas !
    This 2009 Plasma tv, Panasonic TC-P50S1 went dark on me this past Sunday evening. A loud pop was heard just before the screen turned black. I am getting the "seven blinks of death".I would like to repair this set. I really like the display, even at 720p. And of course, I'd like to do it as inexpensively as possible. The search results (via Google) tells me it could be one of several boards. Which board is it likely to be ? There were no lightening storms that evening. No black out. No power surges, as far as I know. I suspect enough dust was collected to form a bridge on one of the boards, though I really don't know.I have already removed the "thousand" or so screws from the back cover. And it's not too dusty IMO. Purchased in late 2009. Is this set worth saving ? Advice would be appreciated.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TCP50S1
    If you were happy with the tv and want to keep it ...then yes its worth saving! Could you please take some pictures of all boards?
    Use the paperclip function to upload files. ( advanced ) Don't use external websites for uploading pictures.
    7 blinks can be any board but my guess is the SC Board.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Good research, Im already out.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Reecey m8 , its not a vestel! 17IPs is your speciality
        Service manual says 7 blinks is SC / SU or SD board. This means the 3 boards on the left.
        You heard a loud pop....good chance the SC board is bad!
        Do you have a multi meter?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          service manual link
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ive fixed prolly more pannys than you have lol, I dont normally go into complex voltage lists as I cant be arsed to type it just this thread nothing at all to help us so I quit :
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Haha depends , i only repair Panasonic plasma's
              Anyways remove the power cable and the SC20 cable from the SC board and get a multimeter. Measure for short on the white prong connector of the SC board. Constant beep is bad.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ahh shit, you mind getting yourself on my TNPA5105 thread then haha
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  I have fixed two of these with similar symptoms. SU and SD board took out the SC board. Also found many what I would call loose screws on all boards.
                  My $.02
                  LJ
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    http://www.ebay.co.uk/itm/TCP50S1-TX...-/191245600496
                    • Rustifer134
                      • Dec 2016
                      • 19
                      I do have a multimeter.
                      • Rustifer134
                        • Dec 2016
                        • 19
                        Here are the requested photos.
                        • Rustifer134
                          • Dec 2016
                          • 19
                          No short detected on the white prong connector of the SC board.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            What about SS ?
                            • Rustifer134
                              • Dec 2016
                              • 19
                              No short detected on the white (3) prong connector of the SS board
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Ok now remove the buffers from SC and jumper SC50 connector pins on the SC and see if the set comes on. If it aborts again check what Vsus does and Vsc.
                                • Rustifer134
                                  • Dec 2016
                                  • 19
                                  I just noticed, that I actually checked the SC2 connections of the SC card and not the SC20, as instructed by Moreno83. SC20 looks like a ribbon kind of connection. So, my question here is, how do I test these tiny connections ?
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    No no. You need to remove the SC20 ribbon cable from the SC board and remove the cable thats connected to the white prong connector going to the PS.
                                    Remove the buffer boards from the tv or make sure that they DO NOT TOUCH the SC board.
                                    Now measure in beep/diode mode on the white prong connector. No beep is usually good , same for SS board.
                                    With the buffer boards disconnected from the SC board , search for a harddisk jumper and use the SC50 jumper. ( short 2 pins ).
                                    Turn on the TV , does the set stay on or do you get a blink ?
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      Ps , the SC50 connector is on the bottom left corner next to the black connector going to the buffer boards.
                                      The buffer boards are connected to the SC board with these big bolts , remove the bolts and flip the buffer boards out of the way. Short the SC50 connector and turn on the tv.
                                      • Rustifer134
                                        • Dec 2016
                                        • 19
                                        The black connectors you are referring to. How are they removed from the pcb ?
                                        Never mind. I got it. So far.
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
                                        • Mnawar27
                                          Panasonic CF-H2AU24EF3 bios locked
                                          by Mnawar27
                                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                          I need help to remove it,
                                          thankyou all.
                                          SN; 2FKCA26876...
                                          11-16-2024, 08:00 AM
