HP6735s "invalid serial number", bios needed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Hello. Have this HP6735S with error "invalid serial number". i read about serial changers booting from usb, but i cannot make any usb booting from it. I see that bios ic was touched.
    Bios bin from hp website have 2MB but i have only 1MB chip so bios is needed.
    Its full AMD/ATI system
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Re: HP6735s "invalid serial number", bios needed
    in schematic i found that there may be 2mb biios ic so maybe it was changed. but bios menu work ok even with 1mb bios ic
    • dj_ricoh
      • 2073
      • uk
      try this
      type in folder NbDmiFit
      and good luck
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3553
        • slovakia
        allready have it, but cannot boot to any device. when i show the boot order, no device is show.
        anybody can me prove that this motherboard have 2MB bios?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          give full motherboard code, or your dump before you wrote that bios with error message
          when i have trouble i take serial and rest dmi data from on working bios, insert it to new bios from web and then write bios fixed with serial and everythig, do no error and no need for DMI tool
          Im Back... sort of...
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3553
            • slovakia
            i want to do it too, but on hp website is 2mb bios rom and i have 1mb bios ic. but in schematic is 2mb ic so im bit confused
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              sometimes it so simple that thay put 2mb eprom, but bios is 1mb size so 1mb empty (0xFF hex)... ive seen it few times
              pls give motherboard code to be sure, i can find dump from other working laptop
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3553
                • slovakia
                i found only this mark /photo/
                i attached original rom that showing error. bios ic is 1mb
                ps: why i cannot post bin file and must rar it?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  underneath that sticker is a motherboard code which is i guess 6050A2235601-MB-A03
                  all dumps i found are 2 mb.... schematics also says 2mb SST_25VF016B...
                  why not take eeprom from other non working board and put it in... its worth a try.... any 2mb spi eeprom should work
                  did you see traces of soldering when opened? maybe someone did some work before you... :/
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3553
                    • slovakia
                    i found the right ic in hp 625 board. programming with origo hp rom.
                    ill let u know how it goes
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3553
                      • slovakia
                      Solved.
                      i bad check bios id. it was 2MB, but it was corrupted. Cannot program it to end. So i took the same from HP 625 and program it. now i can see boot devices and can boot to DMI and change the sn.
                      I attach DMI with usb format tool.
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        glad to hear its working
                        • buddie97
                          • Jan 2015
                          • 5
                          • Italy
                          Hi,send me the Hash code after you tried 3 attempts,then i iwll give yoy the password to unlock it free of charge.
                          • thesleepwalker
                            • Jun 2014
                            • 12
                            • Vietnam
                            i have a same problem on my HP Folio 9470 but this doesn't work, it seems my lap is suppose to be retattoo by this tool
                            • rioreno
                              • Feb 2009
                              • 540
                              • Indonesia
                              for newer hp , like 9470M use wndmifit or biosconfigutility
                              • rioreno
                                • Feb 2009
                                • 540
                                • Indonesia
                                Originally posted by mrwab
                                hello please can you explain this process for new model of hp
                                try find readme folder, depending your model,
                                • mrwab
                                  Banned
                                  • Jan 2014
                                  • 83
                                  • morocco
                                  i'm testing writing serial and sku number in hp elitebook 8560W and hp envy 17 but NOT save after the process show message programming successful
                                  • polytek
                                    • Dec 2013
                                    • 496
                                    • TUNISIA
                                    you need the correct program with the correct platform,
                                    • thesleepwalker
                                      • Jun 2014
                                      • 12
                                      • Vietnam
                                      thanks for the tool bro
                                      • rioreno
                                        • Feb 2009
                                        • 540
                                        • Indonesia
                                        you welcome...
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • iulik17d
                                          Intel Arc A380 videocard power limit remove - BIOS needed
                                          by iulik17d
                                          Hello everyone!
                                          The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                                          The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                                          01-10-2025, 02:33 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • lalle-
                                          Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                          by lalle-
                                          Hello!
                                          I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                          [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                          I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                          The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                          I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                          08-11-2024, 02:01 PM
