Alba TV LCD32880HDF Picture issue
  • fosjih41
    • Mar 2015
    • 18
    • England
    I have an Alba tv which when turned on shows a picture but top half is darker than the bottom half which is lighter. Possible inverter?
    Re: Alba TV LCD32880HDF Picture issue
    Most likely it's a bad LCD panel unfortunately. Got a picture of the fault?
    • fosjih41
      • Mar 2015
      • 18
      • England
      Attached picture
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Is that an lta320ap06 lcd panel ?
        • fosjih41
          • Mar 2015
          • 18
          • England
          Its n Alba LCD32880HDF model TV. Where would I find the LVD panel model number?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            [QUOTE=fosjih41;546644]Its n Alba LCD32880HDF model TV. Where would I find the LVD panel model numb
            You will have to take the back off the tv to see what panel it uses.
              It is a bad panel IMHO.
              • fosjih41
                • Mar 2015
                • 18
                • England
                Yes it is the lta320ap06 panel
                • fosjih41
                  • Mar 2015
                  • 18
                  • England
                  I have earlier model of an Alba TV. Would the lcd panels be interchangeable? The model number of the other LCD panel is Sharp LK315T3LA57
                    No, probably not unfortunately unless you can find a compatible main board.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Them panels are pure junk seen lots of them fail, not worth replacing as the new one wont last long either.
                      • fosjih41
                        • Mar 2015
                        • 18
                        • England
                        The Alba TV has a 17PW26-3 PCB. Can anyone advise if the 17PW25-4 is compatible with this TV. The model number are the same. The first is around 4 years old and the 25-4 is froma TV just over a year old.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          More than likely it wont be, as normally the connectors are wired differently and things like the peak current draw are different.
                          • fosjih41
                            • Mar 2015
                            • 18
                            • England
                            I've replaced most of the capacitors on the board. It comes off stand by thinks for a bit then I have no picture and it stays off stand by. Now and again it comes on. I've checked the voltages through the board and it all seems fine. More scratching of the head required.
                            • fosjih41
                              • Mar 2015
                              • 18
                              • England
                              Also. when I unplug the TV from the mains the stand by light comes on for a short time
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                So your saying that the backlights go off ?
                                • fosjih41
                                  • Mar 2015
                                  • 18
                                  • England
                                  The backlight doesn't come on initially. When first plugged in the stand by light comes on. The stand by light then goes off as if its searching for an input but no backlight or anything. I've just plugged it back in and I now have a picture. Its a very intermittent fault.
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • Tr0ll
                                    by Tr0ll
                                    Original T-con:
                                    First replacement T-con:
                                    10-07-2023, 07:48 PM
                                  • scubacamper
                                    Sharp Aquos LC-70C6400U Half Screen Dark
                                    by scubacamper
                                    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                    05-03-2025, 12:19 PM
                                  • Fly_Among_Stars
                                    VIZIO E70-E3 Half picture with half TCON
                                    by Fly_Among_Stars
                                    I have a VIZIO E70-E3.
                                    Symptoms: Black screen, no picture, but LED backlights are working.
                                    I probed the power board and voltages are as listed on the board.
                                    Main board appears fine, too.
                                    I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                    There are two separate ribbon cables feeding the LCD.
                                    If both are connected, the screen is black.
                                    If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                    04-24-2023, 08:20 PM
                                  • gavric
                                    Vizio M70-C3 Half picture is bad, main board on its last leg?
                                    by gavric
                                    Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                    When tv powers on vizio V logo shows nice on whole screen. picture 1
                                    When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                    When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                    When i click video to start playing picture goes black(like when you change...
                                    09-02-2021, 08:55 PM
