Tv tucson 26hd782
  • sebuncle
    • Jun 2010
    • 46
    • France
    Tv tucson 26hd782
    Hi ,
    i have a problem with a tv tucson 26HD782
    mainboard is a 17MB12-3
    colors are distorted (see photos )
    can you help me please to find problem
    Many thanhs
    JOVY RE7500
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Tv tucson 26hd782
    Hello what Tcon is used in this tv ?
    • sebuncle
      • Jun 2010
      • 46
      • France
      Hi ,
      T-CON is inside mainboard.
      JOVY RE7500
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Can you take pictures of the boards and how they are laid out please, looks to me like a fault gmma Ic or the Lvds setting is wrong in the service menu.
        • sebuncle
          • Jun 2010
          • 46
          • France
          here's photo of mainboard
          JOVY RE7500
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Hmm can you remove that card where the Lvds plugs in ?
            • sebuncle
              • Jun 2010
              • 46
              • France
              here's without card :
              JOVY RE7500
                I like to see the other end of that white flat LVDS cable that goes to the panel, it looks to me the panel may have integrated T-CON, and that board is just the connector converter. Are there SMD components on that board?
                Is there a model number sticker for the LCD panel to look up the spec sheet?
                • sebuncle
                  • Jun 2010
                  • 46
                  • France
                  heres's photos
                  in menu only images are distorted , letters are ok
                  JOVY RE7500
                    Panel with Integrated T-CON.
                    V260B1-11 REV. C1
                    Not much you can do to fix it.
                    You need to get access to the board to do the Gamma Voltages check.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Corrupt firmware possibly?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Also try checking the Lvds mode in the menu:
                        Press menu
                        Then 4725
                        A service menu will appear
                        Go through the options till you find Lvds Mode
                        Try changing the Lvds mode and see what the screen does
                        If not this is possibly a hardware failure.
                        • sebuncle
                          • Jun 2010
                          • 46
                          • France
                          Press menu
                          Then 4725
                          yes!!
                          i have change Lvds mode and screen is ok
                          thanks a lot
                          JOVY RE7500
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Nice one Common issue on these Vestel boards Lvds mode messes up, I have no idea why just guess that the firmware glitches nice fix ! Also the lcd panel used in that tv is very problematic so let us know if you have any issues again.
                            In the mean time enjoy the tv
                              Nice fix, so what mode was it in to cause that symptom? and what mode did you change it to?
                              • sebuncle
                                • Jun 2010
                                • 46
                                • France
                                i go to video ---> lvds mode , it was on "yes" , i have change to "no"
                                JOVY RE7500
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  I think when its on yes the mainboard inverts the gamma voltage, no idea why Vestel included this though.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Nice fix good job!
                                    • Mirenia
                                      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                      by Mirenia
                                      Hi everyone,
                                      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                      03-30-2025, 06:47 AM
                                    • orcic
                                      MASTER TL240 and new mainboard LW36BKC01
                                      by orcic
                                      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                      Now I have some doubts about how to connect the new mainboard to the old power supply.
                                      First of...
                                      05-12-2023, 08:10 AM
                                    • Devonavar
                                      Vizio M43-C1 - How closely do I need to match the mainboard number?
                                      by Devonavar
                                      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                      So, I've ruled out the PSU for now.
                                      The reboot loop...
                                      08-14-2022, 08:46 PM
                                    • Malva
                                      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                                      by Malva
                                      Hi everyone,
                                      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                                      Mainboard model: EAX65684604
                                      PCB marking: EBT62954607
                                      SPI chip: Winbond W25X20CLNIG Problem description:
                                      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                                      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                                      • I bought another
                                      06-25-2025, 02:07 PM
                                    • l0lhaxz1
                                      QN65QN90A - Mainboard MLCC failed - now bootloop
                                      by l0lhaxz1
                                      Hi
                                      I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                                      Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                                      Came to learn after a bit more research...
                                      02-06-2023, 08:59 AM
