Samsung LN46C600 audio but no pic
  • aztheroth
    • Feb 2015
    • 12
    • usa
    Hi. Been reading some similar problems on this forum but others seems to have something on the screen. Mine doesn't show anything at all on the screen. Was watching TV one day... left for 5 mi and when I came back, TV screen was black and no pic at all. However it sounds. Even the sound when I turn it on and off works. But screen black all the time. Don't know what to test first, if someone can guide me I will appreciate it. Thanks
    Re: Samsung LN46C600 audio but no pic
    Can look at the back of the LCD panel to see if it does have backlights or not?
    Did you check the fuse (it is the fuse for the backlights inverter circuit) at the middle of the board?
    You can also remove the cable between the main board and the power supply/inverter board and then power up the TV, the backlights should come on right away (the power supply board has built-in pull-up resistors).
    • nicholas1110
      • Aug 2012
      • 127
      • usa
      I had one of these come through my shop recently. Just above the fuse in the middle of the board is capacitor ci818. I had a pile of about 5 of these boards from previous repairs that I ended up replacing the whole board. All of them had the same faulty capacitor. If removed from the board, you can feel a bump on one side of it where it bulged. Hope this info helps you out.
        That is one of the common failure cap in SAMSUNG, it must be replaced with High pulse capacity cap type.
        CI818 (0.47uf 450V), if it is bad, I would go for 630V or higher. Lead spacing is 22.5mm, need to verify the one you have on your board.
        http://www.mouser.com/ProductDetail/...kZC3w2sd0ag%3d
        • aztheroth
          • Feb 2015
          • 12
          • usa
          I will try theses advices as soon as I get hone. Appreciate the quick responses. Will get back to you with findings asap.
          • aztheroth
            • Feb 2015
            • 12
            • usa
            Ok. I just tried removing the right top cable on the board and turning TV on. Still black. Just hear the on and off sound. What fuse do I need to check and what capacitor?
            • sordids999
              • May 2013
              • 2149
              • uk
              i have circled the capacitor i think they mean for you
              • aztheroth
                • Feb 2015
                • 12
                • usa
                I zoom in the pic I posted of my board and see that Ci818 with some white stuff and looks like some black on it. What's that white stuff? Sorry, not familiar with this. If I need to replace it, what do I need? Thanks
                  That is the one.
                    I cannot tell from the picture, but at this point you need to make sure the fuse is OK first.
                    You will need the capacitance meter to check its value, when this cap goes bad, the capacitance will drops a lot.
                    • aztheroth
                      • Feb 2015
                      • 12
                      • usa
                      What do I need to check that fuse? Any multimeter works? Planning on buy one. Any instruction on how to check it?
                        So you do not have any test equipment, how about soldering equipment?
                        Digital Multi meter (DMM) will be needed, once you get one then you need to read user manual and go on line on how to use Ohm meter, Volt meter.
                        You are dealing with Voltage that can kill you so if you are a beginner, you should at least plug the TV into GFCI outlets.
                        You will have to remove the cap to check the capacitance, so I hope you really know how to solder.
                        • Krenzy
                          • Feb 2015
                          • 45
                          Aztheroth, being in Iowa, there should be a Menards relatively close. I picked up my digital multimeter there for $12, and it's proven to be sufficient for these tests.
                          • aztheroth
                            • Feb 2015
                            • 12
                            • usa
                            Honestly... last time I solder was on high school. 22 years ago. I need a fine solder pencil? And what tipe of soldering material? Going to Menard to get the dmm. And whatever else I would need.
                            • aztheroth
                              • Feb 2015
                              • 12
                              • usa
                              After I get a miltimeter. How do I test this ci818 capacitor? Remove the board and test it from the backside? Dies that white cap cones off? Do I need to desolder the capacitor? Thanks
                                You need to remove the cap from the board without damaging the traces and the board, but as I indicated, check the fuse first.
                                • aztheroth
                                  • Feb 2015
                                  • 12
                                  • usa
                                  The fuse below that capacitor? How do I check if it's working or not? Sorry for so many questions. And I appreciate your patience and time.
                                    You have to get the meter first then you set it to Ohm mode (resistance testing mode) at 200 Ohms range scale, the reading of the fuse should be about the same as the reading when you touch the two probes together.
                                    You may want to take the board to local TV repair shop and ask them to check the fuse and remove the cap to test the capacitance.
                                    • aztheroth
                                      • Feb 2015
                                      • 12
                                      • usa
                                      I got a multimeter. Put it on 200 ohms and the fuse under that ci818 reads the same as the probes together. But what I put boar upside down and try on the 2 pins of ci818 it doesn't read anything. Or do I have to select something g different on the dmm?
                                        The capacitor will show as open circuit when check with Ohm meter (if it shows resistance, then it is bad. Look up how the cap is constructed), you need capacitor meter to test capacitance, the cap has to be removed from the board.
                                        So what kind of DMM did you buy? Any user manual comes with the meter?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                          Samsung 9 NP900X5T-K02US Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung 9 NP900X5T-K02US Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP900X5T-K02US boardview and NP900X5T-K02US schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:34 AM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
