Burn in question
  • tibimakai
    • Jan 2012
    • 3680
    Burn in question
    Somebody is selling a TV (Samsung LN37A550) and he is claiming that the TV was left paused and they realized that after two days and now the screen is bunt in.
    Is this possible with today's LCD TVs?
  • Dang
    • Aug 2013
    • 440
    Re: Burn in question
    I've seen quite bad burn in with a Samsung LE37R74, so yes, very possible. From what I remember of a few years ago it's something to do with the screens being over driven to get a better response rate, I guess if an image is left for too long it can "hold" the pixels in that position. I have an LE46A556 at the moment and I do see image retention if an image is left static for a few hours, it will only last for an hour or so if used though.
    • tibimakai
      • Jan 2012
      • 3680
      So, you are saying that in time it should go away?
      • Dang
        • Aug 2013
        • 440
        I don't think so, not from my experience anyway. Image burn and image retention are different, image burn is permanent, image retention is usually temporary and will fade over time, usually within a few minutes to a few hours. If a static image has been left for days, even with an LCD, I'm sure it would be classed as image burn and so is there forever.
        • R_J
          • Jun 2012
          • 9588
          Some people say that it should be turned off for at least as long as the image was left on. Others say to play a high saturation color video like a cartoon that will exercise the lcd and help cure the problem. I guess its like the cure for a hangover, everyone has one but do they work.
            It can happen if the LCD VCOM is set incorrectly which is a problem with crappy Funai based sets and with certain older ChiMei/Chungwha panels. It may or may not be reversible.
            AFAIK, it does not happen with Samsung 37" A550 FHD sets...
            • freakaftr8
              • Oct 2012
              • 3743
              I have seen that on a 47 inch Vizio lcd my father in law has. It's an lcd and has the cartoon network logo on the panel always. It seems to dissipate when he watches other colorful things for a while though.
              It was a repaired tv I gave him a few years back
              • tibimakai
                • Jan 2012
                • 3680
                Here is the person's ad:
                The picture has a slight shadow and the colors are off.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  color saturation issues won't be attributed to a burned panel, that looks more like a tcon problem or a main board issue if it is a ti con problem it could be the gamma IC or its a main board issue it could be just a problem in the board itself
                    That is most likely AUO gamma chip AS15F fault, or VGL/VGH are poor.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I'm thinking about the AS15F issue myself.
                      I will check it out later on today.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        So I picked it up.
                        It shows as in that picture mostly red. Other colors seem fine.
                        I can see the previous screen words from the menu for a while. To me it doesn't seem like it's a burn in issue. More like a slow refresh issue.
                        I have done a factory reset, changed settings in the screen size/model section, LVDS output, without any result.
                        I'm guessing that I will have to replace the AS15F chip on the T-con board.
                          First check gamma voltage curve before replacing AS15. Many demos on how to do this on this forum posted by myself and others.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I have found one of your post, where you explain what to check for and where are the measuring points, but 'm having problem finding those points on this board. Here is a shopjimmy picture.
                              In this instance the points are top right, the array marked VGAMA1 thru VGAMA22. The gold dots to the right of the labels.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Thank you.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have replaced the AS15F chip, twice. It seems, like the first time didn't go well, so I had to remove it and re-install it.
                                  Second time it worked, but it didn't fix the red tint. It's the same as before.
                                  I may have damaged the chip the first time or there is a mainboard issue?
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Here are some picture with the screen as of now, after replacing the gamma chip, it was the same before.
                                    If I select Dynamic the screen brightens up, if I chose Movie mode, it becomes dark.
                                    Before I did a factory reset, the background on the menu it was red.
                                    The EDID should be on or off? It was off and all the positions were saying Failed. I have refreshed those settings and they turned on Successful.
                                    After this,the menu background became black.
                                    I have tried switching the screen size and model number, but the present one shows the best picture. Switched the LVDS setting, but became worse.
                                    Boards are rare and expensive. T-con is $85 on Ebay, same goes for a main board.
                                    Any ideas?
                                      Did you do voltage checks before replacing it, as instructed elsewhere? That will tell you if AS15 is bad, or if another fault exists.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        The voltages were all over. In some spots were dropping, but then went up and down again.
                                        I haven't checked that now, good point. I will do that tomorrow.
                                        Thanks.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • Pinky Deepak
                                          Vizio M60-C3 Left Edge problem
                                          by Pinky Deepak
                                          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                          09-27-2024, 05:11 PM
                                        • armoured_smiler
                                          Panasonic Tx-40cx400b top left half screen not displaying correct
                                          by armoured_smiler
                                          Trying to work out if this is TFT problem or TCon issue.
                                          The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                                          Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                                          04-08-2024, 03:40 PM
